Acorn Archimedes A305
The Acorn Archimedes A305 was the entry-level model in Acorn's revolutionary Archimedes range, released in June 1987. Distinguished from its sibling A310 primarily by shipping with 512 KB of RAM instead of 1 MB, the A305 offered the same groundbreaking ARM RISC processor technology at a lower price point, making it accessible to educational institutions and home users transitioning from 8-bit systems.
| Acorn Archimedes A305 | |
| Type | Personal Computer |
| Released | June 1987 |
| Discontinued | 1989 |
| Intro price | £799 (1987) |
| CPU | ARM2 @ 8 MHz |
| Memory | 512 KB RAM (expandable to 1 MB) |
| Storage | 3.5" floppy drive (800 KB), optional hard drive |
| Display | 640×512 (16 colours), 640×256 (256 colours), 1152×896 (monochrome) |
| Sound | 8-channel stereo, 8-bit logarithmic DAC |
| Dimensions | 415 mm × 355 mm × 104 mm |
| Weight | 8 kg |
| OS / Firmware | Arthur 0.30 (later RISC OS 2.00) |
| Predecessor | BBC Master |
| Successor | Acorn Archimedes A310, Acorn Archimedes A3000 |
| Codename | Fairway |
| Model no. | A305, A310, A440 |
Overview
editThe A305 represented Acorn's strategic decision to offer multiple price points for their new 32-bit architecture. Physically identical to the A310 and sharing the same motherboard design, the A305 simply populated fewer RAM sockets, allowing users to upgrade to full A310 specifications by adding additional memory modules. This approach minimized manufacturing costs while providing a clear upgrade path.
Despite the reduced memory, the A305 delivered exceptional performance compared to contemporary machines. The ARM2 processor's efficiency meant that even with 512 KB, the system outperformed 68000-based computers with twice the memory. Educational buyers particularly appreciated this value proposition, as many BBC Micro applications had been designed to work within similar memory constraints.
Architecture
editThe A305 utilized the same four-chip VLSI architecture as the entire Archimedes range. The ARM2 processor provided the computational core, while MEMC (Memory Controller) handled memory management and DMA operations. VIDC (Video and Sound Controller) generated display output and processed audio, and IOC (Input/Output Controller) managed peripherals and system timing.
Memory Configuration
edit| Configuration | RAM Chips | Total Memory | Upgrade Path |
| A305 Standard | 2× 256K×9 SIMMs | 512 KB | Add 2 more SIMMs |
| A305 Upgraded | 4× 256K×9 SIMMs | 1 MB | Equivalent to A310 |
The 512 KB configuration occupied only two of the four available SIMM slots, using 256K×9-bit modules with parity checking. Users could add two additional SIMMs to reach 1 MB, effectively converting the machine to A310 specifications. The MEMC chip required no reconfiguration, automatically detecting the installed memory capacity at power-on.
Hardware Specifications
editThe A305 motherboard was identical to the A310, with the same component layout and expansion capabilities. The four-layer PCB design ensured signal integrity for the high-speed digital circuits, while the modular SIMM approach allowed flexible memory configurations.
System Timing
editAll system timing derived from a single 24 MHz crystal oscillator, divided down to provide:
- 8 MHz - ARM2 processor clock
- 8 MHz - MEMC memory controller
- 24 MHz - VIDC pixel clock (maximum)
- 2 MHz - IOC timers and slow peripherals
- 1 MHz - Econet clock (when fitted)
The synchronous design eliminated clock domain crossing issues, improving reliability and simplifying the design compared to asynchronous multi-chip systems.
Power Requirements
edit| Component | Current Draw | Notes |
| ARM2 CPU | 120mA @ 5V | Including cache |
| MEMC | 250mA @ 5V | With 512 KB RAM |
| VIDC | 400mA @ 5V | Active display |
| IOC | 100mA @ 5V | All ports active |
| System total | 3.5A @ 5V | Typical operation |
The reduced memory of the A305 resulted in slightly lower power consumption than the A310, improving thermal characteristics and power supply margin. This advantage disappeared when users upgraded to 1 MB, as the additional SIMMs drew approximately 400mA.
Display Capabilities
editThe A305 supported all standard Archimedes display modes through the VIDC chip. However, the limited memory affected usability of higher resolution modes, as screen memory reduced available application space.
Memory Impact by Display Mode
edit| Mode | Resolution | Memory Used | Remaining (512 KB) | Remaining (1 MB) |
| 0 | 640×256×2 | 20 KB | 492 KB | 1004 KB |
| 12 | 640×512×16 | 160 KB | 352 KB | 864 KB |
| 13 | 640×512×256 | 320 KB | 192 KB | 704 KB |
| 15 | 640×512×16 | 160 KB | 352 KB | 864 KB |
| 21 | 640×512×256 | 320 KB | 192 KB | 704 KB |
Mode 13 and 21 proved particularly challenging on the 512 KB A305, leaving insufficient memory for serious applications. Most A305 users operated in Mode 12 or 15, providing good color depth while preserving adequate application memory. Educational software typically defaulted to these modes, ensuring compatibility across the range.
Operating System Considerations
editArthur, the initial operating system, loaded entirely into RAM on the A305, consuming approximately 160 KB for the core system and desktop. This left roughly 330 KB for applications in Mode 12, comparable to enhanced BBC Master configurations but with vastly superior processing speed.
System Memory Usage
editThe operating system memory footprint varied significantly between Arthur and RISC OS:
| Component | Arthur 0.30 | Arthur 1.20 | RISC OS 2.00 |
| Kernel | 48 KB | 52 KB | 64 KB |
| Desktop | 64 KB | 72 KB | 96 KB |
| Font cache | N/A | N/A | 32 KB minimum |
| System heap | 32 KB | 40 KB | 48 KB |
| Module area | 16 KB | 24 KB | 32-64 KB |
| Total | ~160 KB | ~188 KB | ~272-304 KB |
RISC OS 2.00's increased memory requirements made the 512 KB configuration marginal for desktop use. The font manager alone could consume 100 KB when using outline fonts, leaving minimal space for applications. This limitation drove many A305 owners to upgrade to 1 MB, particularly after RISC OS became available.
Software Compatibility
editThe A305's limited memory affected software compatibility, particularly with newer applications designed for 1 MB systems. Early Archimedes software typically supported 512 KB configurations, but this changed as developers targeted the larger installed base of A310 and later machines.
Educational software publishers maintained 512 KB compatibility longer than commercial developers, recognizing the substantial number of A305 machines in schools. Popular educational titles like Podd, Arcventure, and Geordie Racer included special 512 KB modes with reduced features or simplified graphics.
Expansion Options
editThe A305 provided identical expansion capabilities to other Archimedes models, though memory limitations affected the practical use of some peripherals.
Podule Slots
editFour 96-pin expansion slots accepted the same range of podule cards as the A310:
- SCSI interfaces - Adding hard drives often required memory upgrade
- Network cards - Econet and Ethernet adapters
- Video digitizers - Required 1 MB for practical use
- MIDI interfaces - Worked acceptably with 512 KB
- ROM podules - Ideal for A305 due to no RAM requirement
The backplane operated at full 8 MHz speed with automatic speed detection for slower peripherals. Each slot provided standard power rails, though the linear PSU limited total expansion capacity.
Internal Upgrades
editBeyond memory expansion, A305 owners could install:
- ARM3 processor upgrade - 25 MHz ARM3 with 4 KB cache
- MEMC1a upgrade - Required for 4 MB RAM support
- RISC OS carrier board - Upgraded ROM capacity to 2 MB
- Econet module - Internal networking interface
- Battery backup - For CMOS settings retention
The ARM3 upgrade proved particularly popular with A305 owners, as the 4 KB cache partially compensated for limited main memory by reducing memory bandwidth requirements.
Manufacturing History
editAcorn produced the A305 from June 1987 to early 1989, with several PCB revisions addressing various issues:
| Revision | Production Period | Changes | Notes |
| Issue 1 | Jun-Oct 1987 | Original design | Arthur 0.30 ROM |
| Issue 2 | Nov 1987-Apr 1988 | Improved memory timing | Arthur 1.20 ROM |
| Issue 3 | May 1988-Dec 1988 | Podule timing fixes | Some with RISC OS upgrade |
| Issue 4 | Jan-Mar 1989 | Cost reduction | Final production |
Production volumes remained lower than the A310, with educational purchases accounting for approximately 60% of sales. The price differential of £76 between A305 and A310 models narrowed over time as memory costs declined, reducing the A305's market appeal.
Common Modifications
editA305 owners frequently performed various modifications to enhance their systems:
Memory Upgrade Procedure
editConverting an A305 to 1 MB required: 1. Two additional 256K×9 SIMMs (approximately £50 in 1988) 2. Opening the case and locating empty SIMM slots 3. Installing SIMMs in correct orientation 4. No configuration changes required - MEMC auto-detects
The upgrade took minutes and required no technical expertise, making it popular with schools and home users. Many dealers offered installation services for customers uncomfortable opening their computers.
Video Output Modifications
editThe standard analog RGB output could be modified for different monitor types:
- VGA conversion - Sync combiner circuit for PC monitors
- Composite video - Added for TV connection
- Genlock input - For video production (required 1 MB)
These modifications typically involved adding small daughterboards or replacing the video output socket with a multi-standard connector.
Reliability Issues
editThe A305 exhibited the same reliability patterns as other early Archimedes models. The linear power supply operated within specifications with 512 KB but approached limits when fully expanded. Thermal management became critical in expanded systems, particularly those with multiple podules installed.
Battery leakage remained the primary long-term reliability concern. The Varta 3.6V NiCd battery typically leaked after 8-10 years, damaging nearby PCB traces. The battery's location near the keyboard connector made damage particularly problematic, as keyboard interface traces were difficult to repair
Performance Analysis
editDespite memory limitations, the A305 delivered impressive performance for its era. Integer arithmetic operations completed at speeds comparable to 80386 systems, while the custom chips provided graphics acceleration unavailable on PC platforms.
Benchmark results (512 KB configuration):
- Dhrystone 1.1 - 3900 iterations/second
- Savage benchmark - 1.2 seconds
- BBC BASIC loop test - 0.8 seconds
- Screen clear (Mode 12) - 15 milliseconds
- Circle drawing - 120 circles/second
These figures remained competitive even against machines costing twice as much, validating Acorn's RISC architecture approach.
Educational Impact
editThe A305 found particular success in UK schools, where budget constraints made the price difference significant. Many Local Education Authorities negotiated bulk purchases, obtaining additional discounts that made A305 systems attractive alternatives to BBC Master installations.
Teachers appreciated the BBC BASIC compatibility, allowing existing educational software to run with minimal modification. The improved graphics and sound capabilities enabled new categories of educational software, particularly in music and art education.
editMaintenance requirements mirror those of other Archimedes models. Priority tasks include CMOS battery replacement before leakage occurs, cleaning ventilation paths to prevent thermal buildup, and inspection of power supply capacitors for signs of aging. The reduced component count of 512 KB configurations slightly simplifies maintenance, with fewer RAM chips to clean or reseat.
editCommon A305-specific issues include insufficient memory errors when running newer software, system crashes when switching to high-resolution modes, and performance degradation in memory-intensive applications. The limited memory also exacerbates problems with fragmentation, requiring periodic resets to reclaim memory. Standard Archimedes troubleshooting procedures apply to hardware faults.
editCapacitor replacement requirements are identical to the A310, as both models share the same motherboard and power supply designs. Critical capacitors include the main PSU filter (4700µF 25V), auxiliary smoothing capacitors (1000µF 16V ×3), and numerous smaller electrolytics throughout the motherboard. The power supply's linear design makes capacitor replacement straightforward but requires careful attention to polarity and voltage ratings.
Market Position
editThe A305 occupied an unusual market position, offering revolutionary technology at a price point between 8-bit systems and full 32-bit workstations. While successful in education, the model struggled in the home market where the memory limitations became apparent quickly. Most retail customers opted for the A310, viewing the additional memory as essential for future software compatibility.
By 1989, declining memory prices eliminated the A305's price advantage, leading Acorn to discontinue the model in favor of the unified A3000 design. The A305's brief production run makes it relatively rare today, particularly units still in original 512 KB configuration.
