Atari 1200XL Capacitor Replacement Guide
Replacing aged electrolytic capacitors (recapping) in the Atari 1200XL helps restore stable voltage regulation, clean audio output, and reliable operation. Unlike many vintage computers that use surface-mount electrolytics prone to leaking, the 1200XL uses through-hole axial electrolytic capacitors, which are less prone to catastrophic leakage but still degrade over time (40+ years).
This guide provides the complete capacitor list from the Atari 1200XL Field Service Manual parts list, along with post-recap voltage verification procedures.[1]
Capacitor Inspection
Before recapping, inspect the existing capacitors for signs of failure:
  • Bulging or split vents – the top or bottom of the capacitor is no longer flat, indicating internal gas build-up.
  • Electrolyte leakage – dried brown or dark residue around the capacitor leads or on the PCB.
  • Corrosion or PCB staining – discolouration of the PCB surface or copper traces near the capacitor.
  • Detached leads – leads that have corroded through or separated from the capacitor body.
  • ESR out of specification – use an ESR meter to check equivalent series resistance. High ESR indicates a degraded capacitor even if it appears physically intact.
Pay particular attention to C39 (10000 µF / 16V, main power filter) and the C7/C51/C52 group (47 µF / 10V) as these are the most critical electrolytics for power stability and audio quality.
Atari 1200XL Electrolytic Capacitor List
The following table lists all electrolytic capacitors on the 1200XL motherboard. These are the capacitors most likely to require replacement due to age-related degradation.
Atari 1200XL Electrolytic Capacitors
Ref Designator(s) Capacitance Voltage Type Quantity Purpose / Circuit Area
C39 10000 µF 16V Aluminium Electrolytic Axial 1 Main power supply filter capacitor (post-bridge rectifier)
C7, C51, C52 47 µF 10V Aluminium Electrolytic Axial 3 Power rail decoupling / audio circuit filtering
C40, C41, C54, C93, C99, C102, C155 22 µF 16V Aluminium Electrolytic Axial 7 Power rail decoupling, voltage regulation smoothing
C115, C162 10 µF 16V Aluminium Electrolytic Axial 2 Signal coupling / decoupling
Total electrolytic capacitors: 13
Full Capacitor Reference (All Types)
For completeness, the following table lists all capacitors on the 1200XL motherboard, including ceramics and film types. Ceramic and film capacitors rarely need replacement but are included for reference during board-level repair.
Atari 1200XL Complete Capacitor List
Ref Designator(s) Capacitance Voltage Type Qty Atari Part Number
C1 68 pF Ceramic Axial 1 C014179-12
C2–C5, C8, C10–C12, C14–C25, C30–C32, C34, C48, C55–C59, C68, C95, C100 0.1 µF 25V Ceramic Axial 35 C014181-03
C7, C51, C52 47 µF 10V Aluminium Electrolytic Axial 3 24-100476
C9, C98 270 pF 25V Ceramic 2 C061336-02
C13, C35, C64–C67, C72–C91, C103–C106, C109–C114, C120–C145, C147, C148, C151–C154 0.001 µF (1 nF) 25V Ceramic Axial 60 C014181-01
C26–C29 0.047 µF 25V Ceramic Axial 4 C014180-09
C36, C37, C149, C150 0.01 µF 100V Film 4 C061337-01
C39 10000 µF 16V Aluminium Electrolytic 1 C060603
C40, C41, C54, C93, C99, C102, C155 22 µF 16V Aluminium Electrolytic Axial 7 C014393
C42, C47 0.01 µF 25V Ceramic Axial 2 C014181-02
C60, C118 100 pF 25V Ceramic Axial 2 C014179-19
C61 150 pF 25V Ceramic Axial 1 C014179-09
C63 390 pF 25V Ceramic Axial 1 C014180-10
C96, C97 820 pF 25V Ceramic 2 C061336-03
C115, C162 10 µF 16V Aluminium Electrolytic Axial 2 C014371
C116 6800 pF (6.8 nF) 25V Ceramic Axial 1 C014180-12
C117 1500 pF (1.5 nF) 25V Ceramic Axial 1 C014180-15
C119 3.9 pF 25V Ceramic 1 C061336-01
Tools Required
  • Temperature-controlled soldering iron (adjustable, 300–370°C / 570–700°F)
  • Desoldering pump (solder sucker) or desoldering braid/wick
  • Fine leaded solder (0.5–0.8 mm, 63/37 or 60/40 tin-lead)
  • Isopropyl alcohol (99%) and ESD-safe brush
  • Flush cutters / side cutters
  • Multimeter with capacitance measurement (and ESR meter if available)
  • Anti-static wrist strap and ESD mat
  • Safety glasses
Procedure
  1. Disconnect power – unplug the external transformer and allow the unit to sit for several minutes.
  2. Disassemble the console – remove the six bottom screws, six PCB screws, and eleven RF shield push rivets as described in the Field Service Manual (Section 4).
  3. Document existing capacitors – photograph the board before removal. Note polarity markings (stripe on negative lead for axial electrolytics).
  4. Remove old capacitors – heat each lead from the solder side of the board while applying gentle pressure or using a desoldering pump. Axial capacitors have leads that pass through the board; work each lead alternately to avoid pad damage.
  5. Clean the pads – remove residual solder with desoldering braid. Clean the pad area with IPA and an ESD-safe brush. Inspect pads and traces for damage.
  6. Install replacement capacitors – observe correct polarity. Axial electrolytics have a stripe or band marking the negative (−) lead. Insert into the correct holes, ensuring the polarity matches the PCB silkscreen markings.
  7. Solder securely – use a temperature-controlled iron. Apply solder to create a smooth, concave fillet around each lead. Avoid cold joints (grainy, dull appearance) and solder bridges.
  8. Trim leads – cut excess lead length flush with the solder joint using flush cutters.
  9. Clean and inspect – clean all solder joints with IPA. Inspect under magnification for solder bridges, cold joints, or damaged traces.
  10. Check for shorts – use a multimeter in continuity mode to verify no shorts exist between the +5V rail and ground before powering on.
Critical Notes
  • C39 (10000 µF / 16V) is physically large. Ensure the replacement fits within the RF shield clearance. Use a capacitor rated at 16V or higher (25V is acceptable and provides additional margin).
  • All electrolytic replacements should be rated at the same or higher voltage than the original.
  • The 1200XL uses axial electrolytic capacitors throughout. Radial replacements can be used if the leads are formed appropriately, but axial types provide a cleaner installation.
Voltage Verification After Recap
After replacing capacitors, verify the power supply output before installing the RF shield and reassembling:
Post-Recap Voltage Verification
Test Point Expected Value Tolerance Notes
AC input at J10 9.0 VAC ±10% From external transformer
DC at C39 positive terminal ~12.7 VDC Rectified, unregulated
+5V at A1 output (pin 3) +5.00 VDC ±5% (4.75–5.25V) Primary regulated output
+5V at A2 output (pin 3) +5.00 VDC ±5% (4.75–5.25V) Secondary regulated output
+5V at U22 pin 8 (CPU Vcc) +5.00 VDC ±5% Verify power reaches CPU
Ripple on +5V rail < 50 mV p-p Measure with oscilloscope AC-coupled. High ripple indicates C39 or regulator issue.
Functional Testing After Recap
  1. Power on and verify all three LEDs function (Power, L1, L2).
  2. Press HELP at the power-on logo to enter self-test.
  3. Run the Memory Test – all RAM and ROM bars should turn green.
  4. Run the Audio Visual Test – verify all four POKEY channels produce sound.
  5. Run the Keyboard Test – verify all keys register correctly.
  6. If available, insert the SALT 2.05 cartridge and run the Color Bar Test and Gray Bar Test to verify GTIA output.
  7. Connect a joystick and verify both controller ports respond.
When sourcing replacements, use quality brands such as Nichicon, Panasonic, Rubycon, or United Chemi-Con. Suggested specifications:
Recommended Replacement Specifications
Original Value Recommended Replacement Voltage Rating Type Notes
10000 µF / 16V 10000 µF / 25V 25V (upgraded) Axial or radial electrolytic Main filter cap – use highest quality available
47 µF / 10V 47 µF / 16V 16V (upgraded) Axial electrolytic Audio/power decoupling
22 µF / 16V 22 µF / 25V 25V (upgraded) Axial electrolytic Power rail smoothing
10 µF / 16V 10 µF / 25V 25V (upgraded) Axial electrolytic Signal coupling/decoupling
Upgrading voltage ratings provides additional headroom and longer service life without affecting circuit operation.
  1. Atari 1200XL Home Computer Field Service Manual Rev 01 – Parts List, Atari, Inc., February 1983—link(accessed 2026-03-29)
