Atari 400 Capacitor Replacement Guide
Recapping your Atari 400 is a crucial preventative step to ensure reliable operation, stable power delivery, and crisp video output. The original aluminium electrolytic capacitors in the Atari 400 are now over four decades old—well past their intended service life. Ageing capacitors can cause power instability, random crashes, distorted audio, and display artefacts. Proactive replacement restores system health and helps prevent catastrophic failures.
editBefore beginning, examine each capacitor for classic signs of failure:
- Bulging or domed tops – Indicates internal gas pressure and imminent failure.
- Leaking electrolyte – Brown, black, or green residue at the base or leads.
- Corrosion or PCB staining – Green/white deposits or darkened board areas.
- Intermittent resets, video glitches, or audio hum – Often traceable to dried-out or high-ESR capacitors.
If any single capacitor shows symptoms, it is best practice to replace all electrolytic capacitors on the mainboard.
Atari 400 Capacitor List
editThe Atari 400 uses a modest number of electrolytic capacitors, all of which are through-hole types on the mainboard and power supply board. SMD electrolytics are not present in this model.
Mainboard Electrolytic Capacitors
edit| Ref. Designator | Capacitance | Voltage | Function / Notes |
| C44 | 2200 µF | 16 V | Main +5 V rail smoothing (bulk filter) |
| C43 | 470 µF | 16 V | +12 V rail smoothing (video/audio circuits) |
| C42 | 47 µF | 16 V | +5 V local decoupling (logic) |
| C41 | 10 µF | 16 V | +5 V local decoupling (logic) |
| C40 | 10 µF | 16 V | +5 V local decoupling (logic) |
| C39 | 1 µF | 50 V | Video output coupling |
| C38 | 1 µF | 50 V | Audio output coupling |
Note: Some board revisions may use slightly different reference numbers—always cross-check with your silkscreen before ordering.
Internal Power Supply Board
editIf your Atari 400 has the original internal linear power supply (NTSC models), it contains additional electrolytic capacitors:
| Ref. Designator | Capacitance | Voltage | Function |
| C1 | 4700 µF | 16 V | Main input filter (rectified DC) |
| C2 | 1000 µF | 16 V | +12 V rail filter |
PAL models (with external power bricks) may not have these internal capacitors. Always inspect your specific unit.
Recapping Procedure
edit- Power off and unplug the Atari 400. Wait several minutes for capacitors to discharge.
- Disassemble the case: remove screws from the underside, gently separate the top shell, and disconnect the keyboard membrane.
- Remove the mainboard and, if present, the internal power supply board.
- Label all connectors for easy reassembly.
- Desolder each capacitor using a soldering iron (350–375 °C) and wick or pump. Take care not to lift PCB pads.
- Clean the pads with isopropyl alcohol and inspect for damage.
- Install new capacitors, matching polarity (long lead = positive) and ensuring correct lead spacing.
- Trim excess leads, solder cleanly, and inspect for bridges or cold joints.
- Reassemble the unit, reconnecting all cables and the keyboard membrane.
Recommended Tools & Parts
edit- Temperature-controlled soldering iron (2 mm chisel tip recommended)
- Desoldering braid and/or spring pump
- Leaded 63/37 or quality lead-free solder (0.5–0.7 mm)
- Isopropyl alcohol (99%) and antistatic brush
- Side-cutters for trimming leads
- Multimeter (for continuity and voltage checks)
- 105 °C, low-ESR radial electrolytic capacitors (brands: Nichicon, Panasonic, Rubycon)
- Kapton tape (optional, for insulating capacitors near shielding)
Voltage & Ripple Check
editAfter recapping and reassembly, verify the power rails at the mainboard edge connector or test points:
| Test Point | Expected Voltage | Max Ripple (p-p) |
| +5 V (logic) | 4.90 – 5.10 V | < 50 mV |
| +12 V (video/audio) | 11.5 – 12.5 V | < 100 mV |
- Use an oscilloscope (20 MHz bandwidth) to check ripple if available.
- Excessive ripple or unstable voltages may indicate a faulty power supply or incorrect capacitor installation.
Additional Tips
edit- Double-check polarity before soldering—reverse installation can damage the board.
- Use capacitors with equal or higher voltage ratings; never substitute lower-voltage parts.
- Clean any electrolyte residue thoroughly to prevent corrosion.
- If the video output remains noisy after recapping, check the RF modulator and its internal capacitors (if fitted).
- Store the Atari 400 in a dry environment and power it up periodically to keep capacitors healthy.
- Dispose of old capacitors at an approved electronics recycling centre.
