IBM Model F (83-key)
The IBM Model F (83-key) is the original IBM Personal Computer keyboard, shipped from 1981 to 1985 with the IBM PC (5150) and IBM PC XT (5160). The 83-key XT layout has function keys F1-F10 in two columns on the left side, no separate cursor cluster (the numeric keypad doubles as cursor keys), and a steel-and-zinc internal construction.
IBM Model F (83-key XT layout)
IBM Model F (83-key, XT layout) keyboard, German variant pictured
Manufacturer IBM
Type Capacitive buckling-spring mechanical keyboard
Release date August 1981 (with the IBM PC)
Discontinued 1985 (replaced by Model M)
Interface 5-pin DIN (XT protocol — not AT-compatible without converter)
Compatible IBM PC (5150), IBM PC XT (5160), any XT-protocol clone
Dimensions 19" × 9" × 1.5" (485 × 228 × 38 mm)
Weight 7 lb 4 oz (3.3 kg)
Model 4584656, 4176191, 1801449 and others
The Model F uses a capacitive buckling-spring switch design — each key has its own barrel containing a spring that "buckles" sideways when pressed, snapping a flipper against the PCB through a foam-and-foil pad. The same buckling-spring mechanism appears in the later IBM Model M keyboard, but the Model M uses a membrane in place of the Model F's capacitive sense PCB.
  • Switch: capacitive buckling-spring.
  • Steel back plate and zinc-cast top frame.
  • 83 keys arranged in the XT layout: F1-F10 left column-pair, alphanumerics centre, numeric/cursor pad on the right.
  • Internal MCU: Intel 8048-family, generating XT-protocol scan codes.
  • Coiled DIN-5 cable to the host.
Foam Pad Repair
The foam-and-foil pads inside each barrel degrade with age — the foam crumbles and the foil oxidises, producing dead or stuck keys. A full restoration replaces all 83 pads with modern equivalents (Modern Model F's polypads or laser-cut 3M foil sheets are common choices) and removes any residue from the sense PCB with isopropyl alcohol.
The disassembly sequence is:
  1. Remove the case screws on the underside.
  2. Lift the top shell off; the barrel plate stays attached to the steel back plate.
  3. Unbend the C-clips around the barrel-plate perimeter.
  4. Lift the barrel plate clear of the PCB.
  5. Carefully turn the assembly over; the springs and flippers sit loose inside their barrels.
  6. Replace the foam-and-foil pads, re-bend the C-clips, and reassemble.
The C-clips fatigue with repeated bending — use a soldering iron to spot-weld replacement clips if any break during reassembly.
Compatibility
The 83-key Model F speaks the XT keyboard protocol — a simple unidirectional serial stream. It will not work with an AT, PS/2, or USB host directly. A small adapter (e.g. Soarer's Converter or a Pro Micro running tmk_keyboard) translates XT to PS/2 or USB.
The 84-key AT Model F (P/N 6450200, shipped with the 5170 AT) uses the bidirectional AT protocol and is not interchangeable with the 83-key XT version, although the physical case design is similar.
Common Faults
  • Dead or stuck keys — foam-and-foil pad degradation. Replace the pads.
  • Whole-keyboard 301 error — broken conductor in the curly DIN cable at the strain relief. Replace the cable.
  • Spurious key repeats — corroded sense pad PCB. Clean with isopropyl alcohol.
