Macintosh LC Troubleshooting
This guide covers common issues and diagnostic procedures for the Macintosh LC.
Preliminary Checks
editBefore troubleshooting, verify:
- Power cable is securely connected.
- Monitor cable is properly attached.
- Keyboard and mouse are connected to ADB port.
- No external SCSI devices are causing conflicts.
No Power
edit| Symptom | Possible Cause | Action |
| Completely dead, no fan | Power supply failure | Check power supply capacitors; test with known-good PSU |
| Clicks or ticks repeatedly | Short circuit or capacitor failure | Inspect logic board for leaked capacitors; check for shorts |
| Fan spins briefly, then stops | Thermal protection or PSU fault | Check PSU output voltages; inspect for overheating |
| LED on but no startup | Logic board issue | Reset PRAM (Cmd+Opt+P+R); inspect for capacitor damage |
Power Supply Voltages
editMeasure at the logic board power connector:
- +5V rail: 4.85V – 5.15V
- +12V rail: 11.9V – 12.7V
Chimes but No Video
| Normal chime, black screen | VRAM failure or video circuit issue | Reseat VRAM SIMM; test with different monitor |
| Chime with garbage display | VRAM or logic board damage | Check VRAM; inspect for capacitor leakage near video circuit |
| Distorted or shifted image | Video timing issue | Check video output connector; try different monitor cable |
Startup Chime Errors
editThe Macintosh LC produces error chimes to indicate hardware failures:
| Chime Pattern | Meaning | Action |
| No chime | CPU or ROM failure | Check ROM SIMMs if applicable; inspect logic board |
| Single tone (not normal chime) | RAM failure | Reseat SIMMs; test each SIMM individually |
| Four tones (ascending) | RAM failure | Replace RAM SIMMs |
Sad Mac Errors
editA Sad Mac icon with error codes indicates hardware failure. Common codes for the LC:
| Code | Meaning | Action |
| 0000000F / 00000001 | ROM test failure | ROM or logic board problem |
| 0000000F / 00000002 | Memory test failure | Check RAM SIMMs |
| 0000000F / 00000003 | Memory addressing error | Reseat or replace RAM |
| 0000000E / 0000xxxx | Various hardware errors | Check expansion cards; reseat all socketed chips |
Intermittent Operation
| Random freezes | Capacitor failure or bad RAM | Recap logic board; test RAM |
| Works when cold, fails when warm | Thermal-related component failure | Inspect capacitors; check solder joints |
| Spontaneous restarts | Power supply instability | Check PSU capacitors and output voltages |
| Corrupted graphics after warmup | VRAM or video circuit failure | Reseat VRAM; check for capacitor damage |
SCSI Problems
| Hard drive not recognized | SCSI ID conflict or cable issue | Check SCSI ID (drive should be ID 0); reseat cables |
| Flashing question mark | No bootable system found | Boot from floppy; check hard drive with SCSI utilities |
| External devices not detected | Termination or ID issue | Verify termination; check all SCSI IDs are unique |
Floppy Drive Issues
| Disk not ejecting | Mechanical jam or failed eject motor | Manually eject with paperclip; check eject mechanism |
| Cannot read disks | Dirty heads or misalignment | Clean heads with IPA; try different disks |
| Disks not recognized | Drive failure or controller issue | Test with known-good drive; check ribbon cable |
Audio Issues
| No sound output | Capacitor failure in audio circuit | Recap logic board, especially near audio jacks |
| Distorted audio | Failing capacitors | Replace capacitors |
| Crackling or popping | Bad solder joints or capacitors | Reflow solder joints; replace capacitors |
The LC is particularly prone to audio issues due to its plastic audio jack sockets, which are near capacitors that commonly leak.
