Macintosh Programming Primer 1989
The file this page embeds is not on the wiki.
The page was created to hold a document named Macintosh_Programming_Primer_1989.pdf. That file has never been uploaded: it does not appear in the wiki's image list under that name, under any case or punctuation variant, or under any close variant found by fuzzy matching across all 1,481 files held here. The embed and the download link on this page are therefore both dead, and the page is kept only so that the gap is visible rather than silent.
Nothing about the missing document is asserted here. No author, publisher, edition, page count or content is claimed, because none of it can be checked. If you have the file, upload it as File:Macintosh_Programming_Primer_1989.pdf and this page will work as intended.
This is not a repair source
editThis is a programming book. It contains no schematics, no parts lists, no component values, no voltages, no connector pinouts and no service procedures, and nothing in it should be cited for a hardware figure. Apple's software documentation and its compiler manuals describe the machine as the programmer sees it, which is not the machine the technician sees.
For hardware data use:
- Apple Service Source — Apple's own service manuals, module
level: specifications, symptom charts, take-apart and module part numbers
- Apple's Developer Notes — the one class of Apple developer document that does carry
rail currents, expansion-slot power budgets and connector pinouts. Several are held here, for example Macintosh IIci Developer Note, Macintosh IIsi Developer Note and Macintosh LC 475 and Quadra 605 Developer Note.
- Macintosh Repair & Upgrade Secrets and The Dead Mac Scrolls — component-level, for
the compact Macs
Related documents held here
edit- Macintosh C Programming Primer 1989 — the C Primer of the same year, which is held
- Macintosh C Programming Primer 1990
- Macintosh C Programming Primer 1992
