Macintosh Quadra 605 Capacitor Replacement Guide
Replacing electrolytic capacitors (recapping) in your Macintosh Quadra 605 is essential for long-term reliability. This guide also applies to the LC 475, Performa 475, and Performa 476, which share the same logic board and power supply.
After 30+ years, the original surface-mount electrolytic capacitors in these machines are prone to failure and leakage. Electrolyte from failed capacitors is corrosive and can damage traces and components if not addressed.
Capacitor Inspection
Before recapping, inspect the logic board for signs of capacitor failure:
  • Bulging Tops – Capacitors with domed or swollen tops are failing
  • Leaking Electrolyte – Brown or orange residue around capacitor bases
  • Corrosion or PCB Staining – Discoloration on the PCB near capacitors
  • Lifted or Corroded Traces – Electrolyte has damaged the board
Even if capacitors appear healthy externally, electrolyte can leak from the bottom of the capacitor, hidden from view. Proactive replacement is recommended.
Macintosh Quadra 605 / LC 475 Logic Board Capacitor List
The logic board uses surface-mount tantalum or electrolytic capacitors. Recommended replacements are tantalum capacitors which do not leak like electrolytics.
Logic Board Capacitor Specifications
Capacitance Voltage Quantity Recommended Replacement
47µF 16V Multiple KEMET T491D476K016AT (tantalum)
100µF 6.3V Multiple KEMET T491D107K006AT (tantalum)
Tantalum capacitors are polarized. Observe correct polarity when installing – the stripe on a tantalum indicates the positive lead (opposite of electrolytics where the stripe marks negative).
Recapping Guide Image
LC 475 / Quadra 605 Logic Board Recapping Guide. Source: Recap-a-Mac
Power Supply Capacitor List
The Quadra 605 uses the same power supply as the LC, LC II, LC III, and LC 475. This power supply is also prone to capacitor failure.
LC Series Power Supply Recapping Guide. Source: Recap-a-Mac
The power supply should be recapped along with the logic board for complete restoration.
Warning: Power supplies contain high-voltage capacitors that can retain charge even when unplugged. Allow adequate time for discharge before working inside the power supply. Use appropriate safety precautions.
Required Tools
  • Temperature-controlled soldering iron (recommended 350-380°C for lead-free solder)
  • Solder wick or desoldering pump
  • Fine solder (0.5 mm diameter, leaded preferred)
  • Isopropyl alcohol (90% or higher)
  • ESD-safe brush or toothbrush
  • Multimeter
  • Safety glasses
  • Flux (no-clean recommended)
Removal Procedure
  1. Disconnect Power – Unplug the machine and remove the logic board from the case.
  2. Document Orientation – Photograph capacitor positions and polarities before removal.
  3. Apply Heat – Heat one side of the capacitor while gently pushing from the side. SMD capacitors will slide off when solder is molten.
  4. Remove Old Solder – Use solder wick to clean the pads thoroughly.
  5. Clean the Area – Remove any electrolyte residue with isopropyl alcohol and a brush.
  6. Inspect Traces – Check for trace damage or corrosion. Repair any lifted or broken traces before installing new capacitors.
Installation Procedure
  1. Apply Fresh Solder – Tin the pads with fresh solder.
  2. Position Capacitor – Place the new capacitor observing correct polarity. For tantalum capacitors, the stripe indicates positive.
  3. Solder Leads – Heat each pad and allow solder to flow around the lead.
  4. Inspect Joints – Joints should be shiny and smooth, not dull or balled.
  5. Clean Flux – Remove flux residue with isopropyl alcohol.
  6. Check for Shorts – Use a multimeter to verify no shorts exist between power rails.
Trace Repair
If capacitor electrolyte has damaged traces:
  1. Scrape away corrosion to reveal clean copper (if any remains).
  2. Use fine wire (30 AWG or similar) to bridge damaged sections.
  3. Solder wire to good portions of the trace on either side of the damage.
  4. Apply conformal coating or clear nail polish to protect the repair.
For severely damaged boards, trace repair may require significant skill. Consider professional repair if damage is extensive.
Testing After Recap
  1. Visually inspect all solder joints.
  2. Check for shorts between power rails with a multimeter.
  3. Reassemble and connect only power (no peripherals).
  4. Power on and verify startup chime.
  5. Connect monitor and verify video output.
  6. Test all functions including audio, floppy drive, and SCSI.
Voltage Verification
After recapping, verify power supply voltages under load:
Expected Voltages
Rail Expected Range
+5V 4.85V – 5.25V
+12V 11.4V – 12.6V
Parts Sourcing
Recommended replacement capacitors:
Tantalum capacitors are preferred over electrolytics because they do not contain liquid electrolyte and will not leak over time.
Additional Resources
