Macintosh Quadra 800 Troubleshooting
Troubleshooting is essential for diagnosing and resolving issues with your Macintosh Quadra 800. This guide covers the most common problems encountered with this system.
Preliminary Checks
Before detailed troubleshooting, verify:
  • Power cable is securely connected
  • Power outlet is functional (test with another device)
  • All internal cables are properly seated
  • PRAM battery is installed and has charge
  • No foreign objects are inside the case
Power Supply Specifications:
  • Input: 100V-240V AC, 47-63 Hz
  • Maximum: 200 watts
No Power (System Dead)
No response when power button pressed Dead PRAM battery Replace 3.6V lithium battery
No response Failed power supply Test PSU voltages; replace if out of spec
No response Faulty power switch Test continuity of power switch; replace if faulty
Power light on, no startup Logic board failure Check for corrosion, reseat chips, test components
Ticking or clicking sound Short circuit or PSU issue Disconnect all peripherals and internal drives; test bare system
Power Supply Testing
Measure voltages at the logic board power connector:
  • +5V: Should read 4.85V – 5.15V
  • +12V: Should read 11.9V – 12.7V
  • -12V: Should read approximately -12.0V
If voltages are out of specification, the power supply may need capacitor replacement or full replacement.
Startup Chime but No Video
Video Issues After Startup Chime
Chime, no video on any monitor Failed VRAM Reseat or replace VRAM SIMMs
Chime, no video Faulty video output circuit Test with NuBus video card if available
Chime, no video Incompatible monitor Try a different monitor or adapter
Distorted or garbled video VRAM failure Replace VRAM SIMMs
Distorted video Incorrect VRAM configuration Ensure matching VRAM SIMMs are installed
Video works on NuBus card only On-board video failure Use NuBus video card as workaround; logic board repair needed for on-board video
Intermittent Operation
Random freezes Bad RAM Test RAM modules individually; replace faulty SIMMs
Random freezes Overheating Clean dust from interior; verify fan operation
Boots sometimes, not others Weak PRAM battery Replace PRAM battery
Boots sometimes Marginal power supply Test voltages under load; recap or replace PSU
Freezes during disk access SCSI issues Check termination, cables, and device IDs
Freezes during disk access Failing hard drive Run diagnostic software; backup and replace drive
Sad Mac Error Codes
A Sad Mac icon indicates a hardware failure detected during POST. The codes displayed below the icon help identify the failing component.
See the Sad Mac Error Codes page for a comprehensive list.
Common Quadra 800 Sad Mac Codes:
Sad Mac Codes
Code Meaning Action
0000000F 00000001 ROM test failed Logic board fault; may need repair
0000000F 00000002 Memory test failed Test/replace RAM SIMMs
0000000F 00000003 Memory addressing error Check SIMM seating; test individual SIMMs
0000000F 00000004 Memory test — byte error Replace faulty SIMM
0000000F 0000000E Data bus test error Logic board issue
0000000F 0000000F Address line test error Logic board issue or RAM problem
SCSI Issues
SCSI Problems
Flashing question mark No bootable drive found Check SCSI cables and termination; verify drive is spinning
Flashing question mark Corrupt system folder Boot from CD or floppy; reinstall system
Drive not recognized Incorrect SCSI ID Ensure unique IDs (0-6) for each device
Drive not recognized Missing termination Add terminator to last device in chain
Intermittent SCSI errors Bad cables Replace SCSI ribbon cable
External device not seen Termination power issue Some devices need termination power; check settings
Memory Issues
RAM Problems
Sad Mac on startup Faulty SIMM Remove SIMMs one at a time to identify bad module
Less RAM recognized than installed Incompatible SIMM Use 60 ns or faster 72-pin SIMMs
Less RAM recognized SIMM not fully seated Reseat all SIMMs
Intermittent errors Dirty contacts Clean SIMM contacts with isopropyl alcohol
Memory errors in specific applications Marginal SIMM Replace SIMM even if it passes basic tests
Floppy Drive Issues
Floppy Drive Problems
Disk not recognized Dirty heads Clean heads with cleaning disk
Disk not recognized Misaligned heads Professional realignment or drive replacement
Disk ejects immediately Bad disk Try different disk
Disk ejects immediately Drive failure Replace floppy drive mechanism
Read/write errors Worn heads Replace floppy drive
CD-ROM Issues
If equipped with the AppleCD 300i:
CD-ROM Problems
Disc not recognized Dirty laser lens Clean lens with appropriate cleaner
Disc not recognized Incorrect SCSI ID Verify CD-ROM has unique SCSI ID (typically 3)
Audio CDs don't play Software issue Check CD player software settings
Slow reading Dirty lens Clean laser lens
Tray won't open Mechanical failure Use emergency eject hole; may need drive replacement
NuBus Card Issues
Expansion Card Problems
Card not recognized Poor contact Reseat card firmly
Card not recognized Dirty contacts Clean card edge connector with isopropyl alcohol
System unstable with card Incompatible card Check compatibility; update drivers
System unstable with card Power supply overloaded Remove other cards; test individually
Conflicts between cards Resource conflicts Try different slot configurations
Startup Sequence
Normal Quadra 800 startup sequence:
  1. Power supply activates
  2. Startup chime sounds
  3. POST (Power-On Self-Test) runs
  4. RAM test completes
  5. SCSI bus scans for devices
  6. Boot device selected
  7. System software loads
  8. Desktop appears
If the sequence fails at any point, the failure location indicates which component to troubleshoot.
