Macintosh Quadra 840AV Troubleshooting
Troubleshooting the Macintosh Quadra 840AV requires understanding its unique architecture, including the AV-specific features like the DSP chip and video I/O circuitry. This guide covers common problems and their solutions.
Preliminary Checks
  • Verify the power cable is securely connected
  • Check that the power outlet is working
  • Ensure all internal cables are properly seated
  • Remove any recently added hardware (NuBus cards, RAM, etc.)
  • Disconnect external SCSI devices
Power Supply Voltage Check
Macintosh Quadra 840AV. Source: Wikimedia Commons.
Expected Voltages
Rail Target Acceptable Range
+5V 5.0V 4.85V – 5.15V
+12V 12.0V 11.9V – 12.7V
-12V -12.0V -11.5V – -12.7V
No Power
No Power Diagnostics
Completely dead, no fan Power supply failure Test PSU voltages; recap or replace PSU
Completely dead, no fan Blown fuse in PSU Check and replace internal PSU fuse
Completely dead, no fan Failed power switch Test continuity of front panel power switch
Clicking/ticking sound PSU overload protection Disconnect drives; check for shorts on logic board
Fan spins briefly then stops PSU failure or short Check for shorts; test PSU under load
Intermittent power Loose power connector Reseat power supply connector to logic board
Startup Chime But No Video
No Video Diagnostics
Chime, no video Bad VRAM Remove optional VRAM SIMMs; test with onboard VRAM only
Chime, no video Failed monitor Test with known-good monitor
Chime, no video Bad video cable Inspect and replace video cable
Chime, no video Logic board failure Check for capacitor leakage; inspect video circuitry
Chime, garbled video VRAM failure Reseat or replace VRAM SIMMs
Chime, rolling picture Monitor sync issue Try different resolution in PRAM or with different monitor
Video Artifacts
Common causes of display artifacts:
  • Failing VRAM (soldered or in SIMMs)
  • Cold solder joints on video circuitry
  • Capacitor leakage affecting video section
  • Overheating
No Startup Chime
No Chime Diagnostics
No chime, fan runs Bad RAM Test RAM SIMMs individually; try known-good RAM
No chime, fan runs Bad ROM Rare; logic board replacement likely needed
No chime, fan runs Logic board failure Check for capacitor leakage; inspect for damage
No chime, fan runs CPU failure Very rare; requires logic board repair
Death chimes (pattern) RAM failure Replace RAM; try different SIMM slots
Sad Mac Error Codes
The Quadra 840AV displays a Sad Mac icon with a hexadecimal error code when hardware failures are detected during startup.
See the Sad Mac Error Codes page for a comprehensive list.
Common Quadra 840AV Sad Mac Codes
Code Meaning Action
0000000F ROM checksum error Logic board issue; check for damage
0000000E RAM test failed Replace or reseat RAM SIMMs
00000001 Bus error Check NuBus cards; reseat connectors
0000000D Bad RAM address Test SIMMs individually
Audio Problems
Audio Troubleshooting
No audio output DSP failure Test with audio INIT disabled; DSP may need replacement
No audio output Capacitor failure Check and replace audio section capacitors
No audio output Software issue Reset PRAM; reinstall Sound Manager
Distorted audio Leaking capacitors Recap audio section of logic board
No audio input DSP failure Test GeoPort; DSP failure likely
No PlainTalk DSP or software Reinstall PlainTalk extensions; check DSP
The AT&T DSP 3210 handles audio processing. If audio problems persist after recapping, the DSP may have failed.
Video Capture Problems
Video I/O Troubleshooting
No video input Cable issue Check S-Video/composite cables
No video input DSP failure The DSP handles video processing
No video input Software issue Reinstall AV software; check extensions
Video input distorted Bad capacitors Recap video input section
No video output Port failure Test both S-Video and composite out
RAM Problems
RAM Troubleshooting
Wrong RAM amount detected Bad SIMM Test SIMMs individually
Wrong RAM amount detected Dirty contacts Clean SIMM contacts with isopropyl alcohol
Startup failure Incompatible SIMM Verify 60 ns, 72-pin; avoid 1MB, 2MB, 64MB SIMMs
Random crashes Marginal RAM Test with RAM diagnostic software
Random crashes Mixed RAM speeds Use matched SIMMs when possible
Remember: The Quadra 840AV does not support 1 MB, 2 MB, or 64 MB SIMMs.
SCSI Problems
SCSI Troubleshooting
Drive not detected Termination issue Ensure proper SCSI termination
Drive not detected ID conflict Check for duplicate SCSI IDs
Drive not detected Bad cable Inspect and replace SCSI cables
Slow performance Termination/cabling Check cable length; verify termination
Data corruption Bad drive Run disk diagnostics; replace drive
Floppy Drive Issues
Floppy Drive Troubleshooting
Disks not recognized Dirty heads Clean drive heads with cleaning disk
Disks not recognized Bad ribbon cable Inspect and reseat floppy cable
Read errors Worn heads Replace floppy drive mechanism
Won't eject Mechanical failure Manual eject with paperclip; repair mechanism
See Macintosh Floppy Drive Maintenance for detailed floppy drive care.
GeoPort Problems
GeoPort Troubleshooting
GeoPort adapter not working DSP failure Test other DSP functions (audio)
GeoPort adapter not working Software issue Reinstall GeoPort software
No dial tone Adapter not connected Check GeoPort adapter connections
Poor call quality DSP overload Close other applications using DSP
Many Quadra 840AV problems stem from capacitor failure. Symptoms include:
  • Audio distortion or failure
  • Video problems
  • System instability
  • Failure to start
  • Corrosion damage to traces
See the Macintosh Quadra 840AV Capacitor Replacement Guide for recapping information.
The Quadra 840AV carries a 3.6 V 1/2AA lithium PRAM battery. These leak and can burst, spraying corrosive electrolyte across the logic board and destroying nearby components — often while the machine simply sits in storage. Remove the PRAM battery from any un-serviced unit. If one has leaked, neutralise and clean the residue and repair corroded traces and vias before troubleshooting.[1]
Unlike the LC and Mac II surface-mount-electrolytic boards, the 68040-family Quadra 840AV logic board uses tantalum capacitors, which do not leak with age — the logic board does not normally need recapping. If the board misbehaves, look to leaked-PRAM-battery corrosion, socket/connector contacts and the power supply rather than to board capacitors.[2]
AV features
The Quadra 840AV adds the AT&T DSP3210 digital signal processor and video in/out. If the machine boots but AV functions (video capture/out, enhanced sound) fail, confirm the AV software/extensions are installed and check the DSP and the AV connector before suspecting the main logic.
  1. "Warning! Exploding Maxell PRAM Batteries", 68kMLA; and MacDat — Macintosh II family. Source for the leaking/exploding lithium PRAM battery that destroys nearby components.
  2. "Apple Macintosh Quadra 650", Retro Viator; and the Apple Macintosh Quadra/Centris 650 Service Source. Source for the 68040-family logic boards using tantalum capacitors (no logic-board recap needed) while the power supply uses electrolytics that do need replacing.
  3. "Compact/Desktop Power Supply Capacitor Lists (by make and model)", 68kMLA; and "Capacitor Replacement in a Vintage Power Supply", Big Mess o' Wires. Source for the shared desktop PSU form factor (IIci/IIcx/IIvi/IIvx/Performa 600/Quadra 650/Quadra 700), the electrolytic failure symptoms and the PSU capacitor lists.
Surface-mount capacitor leakage
The Macintosh Quadra 840AV logic board uses surface-mount electrolytic capacitors whose electrolyte turns corrosive with age and creeps across the board, eating through traces, pads and IC pins. Typical signatures are a machine that will not chime, chimes but shows no video, plays distorted or missing audio, or shows a garbled or checkerboard screen. Wash the affected area and replace every electrolytic with a tantalum or polymer part, then repair any lifted traces. The switch-mode power supply (ASTEC or TDK on the LC-family machines) holds its own electrolytics and fails the same way, so recap it alongside the board.[1]
PRAM battery
The Macintosh Quadra 840AV backs up its clock and Parameter RAM from a 3.6 V ½AA lithium cell. These cells — red Maxell parts especially — leak or burst and corrode the board, so remove an aged one on sight. A flat cell can also stop a soft-power machine booting or disturb the video; left plugged in, trickle power preserves the settings, but a machine switched off at the wall with a dead cell loses them. Clean the area and fit a fresh 3.6 V cell.[2]
Boot chime and Sad Mac
  1. Mac84, Macintosh LC series power-supply recapping guide; the MacCaps capacitor reference; and iFixit. Source for surface-mount electrolytic leakage eating traces, pads and pins, the ASTEC/TDK LC power-supply cap failures, and Apple's use of tantalum (non-leaking) capacitors on the Quadra 700/900 logic boards.
  2. Warning! Exploding Maxell PRAM batteries, 68kMLA; and Mac Battery Leaks, MacDat. Source for the 3.6 V ½AA lithium PRAM cell, the Maxell leak/explosion board damage, and soft- versus hard-power PRAM retention.
