Power Macintosh 6100 Capacitor Replacement Guide
Replacing electrolytic capacitors (recapping) in your Power Macintosh 6100 is an important maintenance task for long-term reliability. Capacitors from the early 1990s may leak, dry out, or fail, causing various system problems.
Capacitor Inspection
Before recapping, inspect the logic board and power supply for signs of capacitor failure:
  • Bulging Tops – The normally flat or slightly indented top of the capacitor is domed or bulging
  • Leaking Electrolyte – Brown or black residue around the base or top of capacitors
  • Corrosion or PCB Staining – Discoloration on the circuit board near capacitors
Symptoms of Capacitor Failure
Common symptoms that may indicate the need for recapping:
  • System won't power on or randomly shuts off
  • Audio distortion or no sound
  • System fails to boot reliably
  • Random crashes or freezes
  • Power supply makes buzzing or clicking noises
Power Macintosh 6100 Capacitor Overview
Power Supply Capacitors
The power supply contains high-voltage capacitors. Exercise extreme caution.
⚠️ WARNING: Power supply capacitors can retain dangerous voltage even when unplugged. Allow adequate discharge time (at least 24 hours) or use proper discharge procedures. The 6100 power supply is particularly known for capacitor failure.
Common power supply capacitors include:
  • Main filter capacitors (high voltage, large values)
  • Secondary filter capacitors (various values)
  • Ripple suppression capacitors
Logic Board Capacitors
The Power Macintosh 6100 logic board contains several electrolytic capacitors. Values vary by board revision.
Common logic board capacitors include:
  • Audio section capacitors
  • Power filtering capacitors
  • Various values from 10µF to 470µF
Note: The 6100 logic board generally has fewer capacitors than later models, but they still require attention due to age.
  1. Discharge and Prepare
    • Unplug the system and wait at least 24 hours for the power supply
    • Remove the top case and locate the logic board
    • Use a wrist strap to prevent ESD damage
  1. Document Capacitor Locations
    • Photograph the board before starting
    • Note polarity markings (negative stripe on capacitor, + or - on PCB)
  1. Remove Old Capacitors
    • Use a temperature-controlled soldering iron (recommended 350°C/660°F)
    • For through-hole: heat each lead and gently pull the capacitor free
    • Use desoldering braid or pump to remove excess solder
  1. Prepare Pads
    • Clean pads with isopropyl alcohol and a brush
    • Check for lifted traces or pad damage
    • Apply fresh solder to tin the pads
  1. Install New Capacitors
    • Verify correct polarity (negative stripe to negative marking)
    • Use quality replacement capacitors rated for the same or higher voltage
    • Solder securely with minimal heat application time
  1. Trim and Inspect
    • Trim leads flush on through-hole capacitors
    • Check for solder bridges or cold joints
    • Use a multimeter to verify no shorts exist
  1. Clean and Test
    • Clean the board with isopropyl alcohol
    • Allow to dry completely
    • Reassemble and test the system
  • Temperature-controlled soldering iron (chisel tip recommended)
  • Desoldering pump or wick/braid
  • Fine solder (0.5mm–0.8mm diameter)
  • Isopropyl alcohol (90%+) and ESD-safe brush
  • Multimeter for continuity testing
  • Magnifying glass or loupe
  • Anti-static wrist strap
  • Safety glasses
Voltage Adjustment After Recap
After replacing capacitors, verify power supply output:
  • +5V rail: 4.85V – 5.15V
  • +12V rail: 11.9V – 12.7V
  • -12V rail: -11.9V to -12.7V
Additional Tips
  • Use quality Japanese-brand capacitors (Nichicon, Panasonic, Rubycon)
  • Match or exceed original voltage ratings
  • Match capacitance values exactly
  • Consider replacing all electrolytic capacitors at once for thorough restoration
  • The power supply is the most common failure point—consider recapping it first
  • Take photos throughout the process for reference
