Template:View
| This template uses Lua: |
{{Navbar}} provides a small "view · talk · edit" navigation bar. It is primarily used for content-heavy templates and other transcluded content blocks, so that the content inside the template or block is more easily editable in situ where it was found, without having track it down through examining transclusion code. Template:Tnull's extremely high use rate and consequent protection level are because it is integrated as a feature into numerous navigation box and infobox templates used in millions of articles. It is also a regular feature of many internal-use templates and tables of the RTC Wiki, Help, and Template namespaces.
Usage
[edit source]General
[edit source]When one of the following examples is placed inside a given template (or block of content used for selective transclusion), it adds basic navbar navigational functionality:
{{navbar|Navbar/doc|mini=y}}{{navbar|Navbar/doc|plain=y}}{{navbar|Navbar/doc|fontstyle=color: green; font-style: italic;}}
Navbar/doc will be substituted with the page name of the real location of the content when parsed by the servers. For example, {{navbar|Navbar/doc}} gives:If the page is moved or renamed the substituted text will need to be updated accordingly. Alternatively, you can use Template:Mfl instead of Navbar/doc to keep track of the current location of the transcluded page:
{{navbar|{{#invoke:params|self}}|mini=...|plain=...|...}}
When used in content that is selectively transcluded but which is also used as-is in its original location, this template should be wrapped in Template:Xtag markup, so that it only appears when transcluded.
Font size and weight
[edit source]The font-size is 88% when used in a topical navbar template or in plain text, and 100% when nested in a navbox or infobox (because those templates' text size is already reduced; the "100%" is relative to the surrounding template's own content, not that of the entire page). The |fontstyle= parameter can be used to adjust the font size as needed (e.g. to reduce font size even more when the template is used inside a block element with a large font size). Do not abuse this to make excessively small text (i.e. less than 85% of the normal page text), since that causes accessibility problems for many readers.
In a topical navbar, the weight is "normal"; when nested in a navbox or infobox, it inherits the style of the surrounding content. The middot bullets are bold for better visibility.
Block level element
[edit source]The template generates block-level markup with <div>...</div> tags, and therefore, any surrounding markup cannot include <span>...</span> tags, which would cause a div-span-flip lint error.
Examples
[edit source]Required parameters
[edit source]{{navbar|Template Name}}– the template name is required.
Optional parameters
[edit source]| Options | Parameters | Produces... | "Shortcut" template |
| Basic | {{navbar|Template Name}} |
| Different text | {{navbar|Template Name|text=This template:}} |
| Without "This box:" text | {{navbar|Template Name|plain=y}} |
{{view}} | |
| Short version | {{navbar|Template Name|mini=y}} |
{{v}} | |
| With brackets | {{navbar|Template Name|brackets=y}} |
| With font styling examples (span) | {{navbar|Template Name|fontstyle=color: green; font-style: italic;}} |
| With whole-template styling examples (div) | {{navbar|Template Name|style=float:right; background: Beige; padding: 5px; border: 1px solid;}} |
| History, move, and watchlist links | {{navbar|template=Template Name|e|t|h|m|w}} |
Note that to show the history, move, and watchlist links, |template= needs to be set to the template value specifically. Individual values can be left out of this list, e.g. {{navbar|template=Template Name|h|m|w}} will only show the view, history, move, and watchlist links.
Shortcut templates
[edit source]The mini=y and plain=y parameters can be avoided by using the {{v}} or {{view}} templates, respectively, instead. They also support changing the shown links, for example only view and edit, or only view and talk:
These are some quick examples which can be copied and pasted directly inside a template with no adjustments:
| Syntax | Which produces |
{{v|Navbar/doc}}
{{v|t|template=Navbar/doc}}
{{v|t|e|template=Navbar/doc}}
{{v|t|e|h|template=Navbar/doc}}
{{v|t|e|h|m|template=Navbar/doc}}
{{v|t|e|h|m|w|template=Navbar/doc}} |
Template:VTemplate:Pb
Template:VTemplate:Pb Template:VTemplate:Pb Template:VTemplate:Pb Template:VTemplate:Pb Template:VTemplate:Pb |
The same type of template only for the full text "view" style:
{{view|Navbar/doc}}
{{view|talk|template=Navbar/doc}}
{{view|talk|edit|template=Navbar/doc}}
{{view|talk|edit|hist|template=Navbar/doc}}
{{view|talk|edit|hist|move|template=Navbar/doc}}
{{view|talk|edit|hist|move|watch|template=Navbar/doc}} |
Template:Pb Template:Pb Template:Pb Template:Pb Template:Pb Template:Pb |
Adding option |d (for "discuss") equals adding |t, adding a t link (for "talk").
Notes
[edit source]Navbar is contained within a <div>...</div> in order to accommodate a horizontal unnumbered list. This means it cannot be placed inside a <span>...</span> or other inline element, because the HTML Tidy extension will 'fix' situations where it finds block elements inside inline elements.
Prepackaged
[edit source]- {{Navbar-header}}
- Positions on the right edge of the line, often used in non-collapsible navbox heading.
- {{Navbar-collapsible}}
- For use in conjunction with collapsible tables, floats opposite of the [hide]/[show] feature.
[edit source]Other internal link templates, including:
- {{Talk}} – plain talk link
- {{Watch}} – plain link that adds the page to your watchlist
- {{Subscribe}} – plain link that adds the page to your subscriptions
- Category:Internal template-link templates
TemplateData
[edit source]TemplateData for View
When placed inside a given template, it adds navbar navigational functionality
| Parameter | Description | Type | Status | |
| Template Name | 1 | The name of the template, so links work correctly
| String | required |
| Different text | text | Allows custom text to replace the default 'this box'
| String | optional |
| Without 'This box:' text | plain | Removes 'This box'
| Number | optional |
| Short Version | mini | Shortens text to V T E
| Number | optional |
| with brackets | brackets | adds brackets before and after the links
| Number | optional |
| Font color | fontstyle | Allows you to change the color of the font (in the format color:green)
| String | optional |
| To float to the side | style | Allows the template to float to the side (format=float:right)
| String | optional |
