Atari 520STM
Revision as of 16:18, 29 March 2026 by Josh (talk | contribs) (Creating Atari 520STM article)
Atari 520STM
Atari 520STM (short-case design with external PSU, identical appearance to the 520ST)
ManufacturerAtari Corporation
TypeHome computer / personal computer
ReleasedJanuary 1, 1985
Discontinued1987 (superseded by the 520STFM)
Intro priceApproximately US$599 (varied by market and bundle)
CPUMotorola MC68000 @ 8 MHz
Memory512 KB RAM
StorageExternal 3.5-inch floppy drive (Atari SF354 or SF314); external ACSI hard disks
Display320ร—200 (16 colours), 640ร—200 (4 colours), 640ร—400 (mono); RF output for television display
SoundYamaha YM2149F (3 voices + noise)
Dimensions70 mm ร— 476 mm ร— 241 mm (2.75 ร— 18.75 ร— 9.5 in)
Weightโ‰ˆ4.3 kg (9.5 lb)
OS / FirmwareAtari TOS 1.00 (192 KB ROM)
PredecessorAtari 520ST
SuccessorAtari 520STFM
The Atari 520STM is a variant of the Atari 520ST home computer that added a built-in RF modulator for television output. The "M" in the model name stands for "Modulator". Released in late 1985, the 520STM was designed for the home market where many users did not own a dedicated computer monitor and needed to connect the machine to a standard television set.
Apart from the addition of the RF modulator circuitry, the 520STM was identical to the standard 520ST in all other respects. It retained the short-case form factor, external power supply, and external floppy drive requirement. The 520STM was primarily sold in the United Kingdom and other European markets where TV output was a key selling point for the home computing market.
History
When the Atari ST launched in mid-1985, the original 520ST required a dedicated monitor โ€” either the Atari SM124 monochrome monitor or the SC1224 colour monitor. This was an obstacle in markets like the UK, where home computers typically connected to the family television set.
By late 1985, Atari added an RF modulator to the 520ST design, creating the 520STM. This small change made the machine considerably more accessible to home users, as it could now produce a PAL (or NTSC) RF signal on a standard television aerial socket. The modulator was typically installed as a small shielded module on the motherboard, converting the composite video signal to a UHF/VHF RF carrier.
The 520STM was eventually superseded by the Atari 520STFM, which combined the RF modulator with an internal floppy disk drive in a redesigned "long case" with an internal power supply.
Architecture
The 520STM is architecturally identical to the Atari 520ST:
  • CPU: Motorola MC68000 @ 8 MHz
  • Architecture: 16/32-bit (32-bit internal registers, 16-bit external data bus, 24-bit address bus)
  • RAM: 512 KB (16ร— 256kร—1 DRAM)
  • ROM: 192 KB TOS 1.00 in 6ร— 32 KB mask ROMs
  • Custom ICs: Shifter (C025914), GLUE (C025915), MMU (C025912), DMA (C025913)
  • RF Modulator: Internal module converting composite video to RF for television aerial input
Major ICs
Function Part Number Notes
CPU MC68000P8 / MC68000FN8 8 MHz
Video Shifter C025914-38 Pixel serialiser
GLUE C025915-38A Bus timing and address decode
MMU C025912-38 DRAM controller
DMA Controller C025913-38 ACSI/floppy DMA
FDC WD1772-00-02 Floppy disk controller
MFP MC68901 Timers, interrupts, UART
ACIA (ร—2) MC6850 Keyboard/IKBD and MIDI
Sound/PIO YM2149F 3-voice PSG + I/O
RS-232 drivers MC1488 / MC1489 Serial port line drivers
RF Modulator Varies (shielded module) Converts composite video to UHF/VHF RF signal
Connectors
The 520STM has the same connector set as the 520ST, with the addition of an RF output:
  • Video/Monitor: 13-pin DIN (analog RGB, mono, sync, audio)
  • RF Output: Phono (RCA) jack or coaxial connector for television aerial input
  • Serial (Modem): DB-25 male, RS-232C
  • Parallel (Printer): DB-25 female
  • MIDI In/Out: Two 5-pin DIN connectors
  • External Floppy: 14-pin DIN
  • ACSI (Hard Disk): DB-19 female
  • Cartridge: 40-pin edge connector
  • Joystick/Mouse: Two DE-9 male ports
  • Power: 7-pin DIN (external PSU)
Display
The 520STM provides the standard ST display modes:
  • Low resolution: 320ร—200, 16 colours from 512, ~50/60 Hz
  • Medium resolution: 640ร—200, 4 colours from 512, ~50/60 Hz
  • High resolution (mono): 640ร—400, monochrome, ~71.2 Hz (SM124/SM125 monitor only โ€” not available via RF)
Note: The RF modulator only outputs the colour (low and medium resolution) display modes. The monochrome high-resolution mode requires a dedicated SM124/SM125 monitor and cannot be displayed on a television.
Sound
  • PSG: Yamaha YM2149F โ€” 3 square-wave channels + noise
  • MIDI: Built-in MIDI In/Out at 31.25 kbaud
  • Audio output: Mono line-level on monitor connector; also mixed into RF signal for television speakers
Known Issues
In addition to the common ST issues, the 520STM has modulator-specific concerns:
  • RF modulator failure: The internal RF modulator can fail or produce a poor-quality signal due to aged components. Symptoms include a snowy, unstable, or absent TV picture. The modulator module can sometimes be repaired by replacing its internal capacitors, or bypassed entirely for composite video output.
  • RF interference: Poor shielding on some board revisions can cause RF interference in the video output.
  • All standard ST issues apply: Keyboard membrane degradation, clock battery leakage, external PSU capacitor failure.
Motherboard Revisions
The 520STM used the C070243 board family (shared with later 520ST models):
Board Number Revisions Notes
C070243 Rev. C, H, I Short-case board with provision for RF modulator; also used in 520ST
Service and Repair
The 520STM shares all service procedures with the standard ST family:
