Macintosh SE/30 Reloaded Logic Board
Revision as of 10:22, 30 March 2025 by Josh (talk | contribs) (→Power Check)
Type Logic Board
First released 2023
Latest revision N/A
Operating voltage —
Layers / PCB 4-layer PCB
Compatibility Macintosh SE/30
Model No. SE30RL
Preparation and Inspection
Step Description
Required Components and Tools
Components Tools
  • EPROM (27C64 Video ROM)
  • Hot air rework station
  • Fine-gauge solder (0.5mm)
  • ESD tweezers and microscope
  • GAL and EPROM programmers
Assembly Techniques
Surface-Mount Soldering
Error creating thumbnail: Unable to save thumbnail to destination
SMD drag soldering demonstration
Component Technique
Through-Hole Soldering
  2. All SMD passives
  3. SMD ICs and transistors
Power Check
Subsystem Tests
Subsystem Verification
Subsystem Test
Simasimac error screen
Symptom Potential Cause
  • Optional 32-bit clean ROM SIMM support (no need for MODE32).
Community Resources
