Template:Infobox computer hardware
Usage
editInfobox template for hardware components (microprocessors, chipsets, controllers, expansion cards). Place the infobox as the very first line of the article with no blank lines above it; otherwise MediaWiki will create an empty paragraph that pushes content down.
Example skeleton — supply only the fields you need (blank ones are hidden automatically):
{{Infobox computer hardware
| name = Intel 8086
| logo = [[File:Intel logo.svg|90px]]
| image = [[File:Intel 8086.jpg|260px|frameless]]
| caption = Intel 8086 in DIP-40 package
| developer = Intel Corporation
| manufacturer = Intel
| type = 16-bit microprocessor
| introduced = June 8, 1978
| discontinued = September 1998
| arch = x86
| data_width = 16 bits
| address_width = 20 bits (1 MB)
| clock = 5–10 MHz
| process = 3 µm HMOS
| transistors = 29,000
| package = DIP-40, PLCC-44, CLCC-44
| voltage = +5 V
| instruction_set = x86 (8086 ISA)
| used_in = [[IBM PC (5150)]], NEC PC-9801, Olivetti M24
| successor = [[Intel 80186|80186]], [[Intel 80286|80286]]
| model = 8086
Field reference
edit| Field | Description |
| name | Component name shown as the infobox title |
| logo | Optional logo image |
| image | Main image of the component |
| caption | Caption shown below the main image |
| developer | Who designed the part |
| manufacturer | Who manufactures the part |
| type | Microprocessor, chipset, controller, etc. |
| introduced (or release_date) | Initial release date |
| discontinued | Discontinuation date |
| arch (or architecture) | Architecture family |
| data_width | Data path bit width |
| address_width | Address bus bit width |
| clock (or frequency) | Clock frequency |
| cache | L1/L2/L3 cache sizes |
| process | Semiconductor process node |
| transistors | Transistor count or gate count |
| package | IC package type |
| socket | CPU socket type |
| voltage (or vcc) | Operating voltage |
| power | Power consumption |
| instruction_set (or isa) | Instruction set architecture |
| used_in (or application) | Systems where this part is used |
| predecessor | Previous-generation part |
| successor | Next-generation part |
| codename | Internal development codename |
| model (or part) | Part number |
