Macintosh Quadra 605 Troubleshooting
Troubleshooting is essential for diagnosing and resolving issues with your Macintosh Quadra 605. This guide also applies to the LC 475, Performa 475, and Performa 476, which share the same logic board.
Preliminary Checks
- Verify the power cable is securely connected and the outlet works.
- Check that the keyboard and mouse are connected to the ADB port.
- Disconnect all external SCSI devices to rule out SCSI chain issues.
- Remove any third-party RAM or expansion cards to test with stock configuration.
No Power
| Completely dead, no LED | Faulty power cable | Test with known-good cable |
| Completely dead | Failed power supply | Test PSU output voltages; recap if capacitors have failed |
| Completely dead | Shorted logic board | Inspect for visible damage, burnt components, or electrolyte from leaked capacitors |
| Clicking or ticking sound | Power supply capacitor failure | Recap the power supply |
| Intermittent power | Loose power connector | Reseat logic board power connector; check for corrosion |
Power Supply Testing
The Quadra 605 uses the LC-series power supply. Test voltage outputs:
- +5V rail: Should read 4.85V โ 5.25V
- +12V rail: Should read 11.4V โ 12.6V
If voltages are out of spec or absent, the power supply requires recapping or replacement.
Chime but No Video
| Chime, no video, drive activity | Failed VRAM | Reseat or replace VRAM SIMMs |
| Chime, no video | Bad video cable | Test with different monitor and cable |
| Chime, no video | Failed logic board capacitors | Recap logic board |
| Chime, garbled video | VRAM failure | Replace VRAM SIMMs |
| Chime, garbled video | Failing capacitors | Recap logic board; check for electrolyte damage |
| No chime, no video | Dead CPU | Inspect CPU socket; try reseating processor |
| No chime, no video | ROM failure | ROM chips rarely fail; usually indicates capacitor damage |
VRAM Testing
The Quadra 605 requires matched pairs of VRAM SIMMs. Test by:
- Removing all VRAM โ the system should still boot to a low-resolution display
- Swapping VRAM positions
- Testing with known-good VRAM
Startup Issues
| Flashing question mark | No bootable system found | Check hard drive connections; boot from floppy or external SCSI |
| Flashing question mark | Failed hard drive | Replace or test drive externally; consider SCSI2SD/BlueSCSI |
| Sad Mac icon | Hardware failure | Note the error code; see Sad Mac Error Codes |
| Freezes during startup | Failing capacitors | Recap logic board |
| Freezes during startup | RAM problem | Test with only onboard RAM |
| Freezes during startup | SCSI conflict | Check SCSI ID assignments and termination |
Sad Mac Error Codes
See Sad Mac Error Codes for a complete list. Common codes for the Quadra 605:
| Code | Meaning |
| 0000000F | ROM checksum failure or severe hardware problem |
| 0000000E | RAM test failure |
| 00000002 | ROM checksum error |
| 0000000D | RAM addressing error |
Intermittent Operation
| Random crashes | Failing capacitors | Recap logic board and power supply |
| Random crashes | Bad RAM | Test with different SIMM; try onboard RAM only |
| Random crashes | Thermal issues | Check ventilation; verify CPU is properly seated |
| Crashes under load | Power supply weakness | Test voltages under load; recap power supply |
| Crashes when accessing SCSI | SCSI termination issue | Verify proper termination at end of chain |
| Crashes when accessing SCSI | Failing hard drive | Test drive; replace with modern SCSI emulator |
SCSI Issues
| Internal drive not recognized | Loose cable | Reseat SCSI and power cables to drive |
| Internal drive not recognized | Drive failure | Test drive in another system; listen for spin-up |
| External device not seen | ID conflict | Ensure unique SCSI IDs (0-6, internal drive typically 0) |
| SCSI errors | Improper termination | Internal drive should be terminated; terminate last external device |
| Slow SCSI performance | Cable quality | Use proper SCSI cables; avoid excessive cable length |
Floppy Drive Issues
| Disk not ejecting | Worn eject gear | Replace eject gear assembly |
| Disk not ejecting | Manual eject blocked | Straighten paperclip, insert into emergency eject hole |
| Read errors | Dirty heads | Clean heads with isopropyl alcohol on cotton swab |
| Disks not recognized | Failed drive | Test with known-good drive |
| Constant disk access | Drive capacitor failure | Some drives have internal capacitors requiring replacement |
Audio Issues
| No startup chime | Speaker disconnected | Check internal speaker connection |
| No startup chime | Volume set to zero | Reset PRAM (Cmd-Option-P-R at startup) |
| Distorted audio | Failing capacitors | Recap logic board |
| No audio output | Bad capacitors in audio circuit | Recap logic board, paying attention to audio section |
PRAM and Settings Issues
If the machine loses settings or shows incorrect date/time:
- Replace the 3.6V PRAM battery
- Reset PRAM by holding Cmd-Option-P-R during startup until you hear the chime twice
- Inspect for battery leakage around the battery holder
Capacitor Failure Symptoms Summary
Many Quadra 605 issues trace back to failed electrolytic capacitors. Suspect capacitors if you see:
- Failure to start
- Intermittent operation
- Audio distortion or no audio
- Video problems
- Brown or crusty residue on the logic board
- Lifted traces or corrosion
See Macintosh Quadra 605 Capacitor Replacement Guide for replacement procedures.
โ ๏ธ PRAM battery โ remove it now
The Macintosh Quadra 605 uses a 3.6 V 1/2AA lithium PRAM battery (often a red Maxell). These are notorious for leaking and even exploding, spraying corrosive electrolyte across the logic board — a battery can burst while the machine sits in storage and destroy the board. Remove the PRAM battery from any un-serviced unit immediately. If one has leaked, neutralise and clean the residue and check the traces and vias around the battery and the nearby chips for corrosion, repairing any that are damaged.[1]
โ ๏ธ Surface-mount capacitor leakage
The Macintosh Quadra 605 logic board uses surface-mount electrolytic capacitors that leak electrolyte from the bottom with age. The leakage corrodes traces and vias and is a leading cause of faults, so recap and clean the board as a first step. A common pattern is a board that chimes but shows no video after servicing — usually corrosion damage (broken traces or vias) around the leaked capacitors (for example near C136/C137), which must be traced and repaired.[2]
The compact LC "pizza-box" power supply also uses electrolytics that leak with age. A dead LC PSU can usually be revived by replacing all its electrolytic capacitors and cleaning the leakage; any working LC PSU should be recapped pre-emptively, as it will otherwise fail. Confirm the +5 V and +12 V rails after servicing.[2]
Processor and expansion
The LC 475 uses a 25 MHz Motorola 68LC040 (no FPU); a full 68040 can be fitted to add hardware floating-point. The 114-pin PDS expansion slot accepts LC-compatible I/O, display, network and video-capture cards. The Macintosh Quadra 605 is the same logic board sold under the Quadra name.[2]
- โ 1.0 1.1 "Warning! Exploding Maxell PRAM Batteries", 68kMLA; and "Mac Battery Leaks", MacDat. Source for the exploding/leaking Maxell PRAM battery and the resulting board damage, and the LC not booting without a battery.
- โ 2.0 2.1 2.2 "Quadra 605 / LC 475", Quagmire Repair; the Apple Macintosh LC/LC II/LC III/LC 475/Quadra 605 Service Source; and "Macintosh LC Recap", PAPPP's Rambling. Source for the SMD-capacitor leakage, the PSU recap, and the trace/via damage causing chime-but-no-video.
