Macintosh LC 630 DOS Compatible Troubleshooting
The Macintosh LC 630 DOS Compatible is a Macintosh LC 630 fitted with a DOS-compatibility card (a 486 processor on a card, sharing the Mac's drives and display). The Macintosh side is electrically identical to the standard LC 630, so the Macintosh LC 630 Troubleshooting page applies in full for the Mac hardware.[1]
DOS-card specific notes
[edit | edit source]- If the Mac side works but DOS will not start, check the DOS card is seated in its slot, that its RAM SIMM is fitted, and that the shared IDE/drive resources are configured. A faulty or unseated DOS card should be removed to confirm the Mac boots normally on its own.
- Switching between the Mac and PC sides is done in software (or a keyboard hot-key); a machine that appears "stuck" may simply be showing the other side's output.
Common faults (shared with the LC 630)
[edit | edit source]As with the LC 630, check the PRAM battery for leakage and corrosion, recap where needed, and confirm the power-supply rails. Full detail is on Macintosh LC 630 Troubleshooting.
[edit | edit source]Surface-mount capacitor leakage
[edit | edit source]The Macintosh LC 630 DOS Compatible logic board uses surface-mount electrolytic capacitors whose electrolyte turns corrosive with age and creeps across the board, eating through traces, pads and IC pins. Typical signatures are a machine that will not chime, chimes but shows no video, plays distorted or missing audio, or shows a garbled or checkerboard screen. Wash the affected area and replace every electrolytic with a tantalum or polymer part, then repair any lifted traces. The switch-mode power supply (ASTEC or TDK on the LC-family machines) holds its own electrolytics and fails the same way, so recap it alongside the board.[2]
PRAM battery
[edit | edit source]The Macintosh LC 630 DOS Compatible backs up its clock and Parameter RAM from a 3.6 V ½AA lithium cell. These cells — red Maxell parts especially — leak or burst and corrode the board, so remove an aged one on sight. A flat cell can also stop a soft-power machine booting or disturb the video; left plugged in, trickle power preserves the settings, but a machine switched off at the wall with a dead cell loses them. Clean the area and fit a fresh 3.6 V cell.[3]
Boot chime and Sad Mac
[edit | edit source]Read the start-up sound first: a normal chime with a black screen points to the display path or the monitor, an absent chime or a "chord of death" points to RAM or a core fault, and a Sad Mac shows a numeric code — see Sad Mac Error Codes.
[edit | edit source]- โ Apple Service Source and Low End Mac, LC 630 / Quadra 630 family. Source for the LC 630 DOS Compatible configuration.
- โ Mac84, Macintosh LC series power-supply recapping guide; the MacCaps capacitor reference; and iFixit. Source for surface-mount electrolytic leakage eating traces, pads and pins, the ASTEC/TDK LC power-supply cap failures, and Apple's use of tantalum (non-leaking) capacitors on the Quadra 700/900 logic boards.
- โ Warning! Exploding Maxell PRAM batteries, 68kMLA; and Mac Battery Leaks, MacDat. Source for the 3.6 V ½AA lithium PRAM cell, the Maxell leak/explosion board damage, and soft- versus hard-power PRAM retention.
