Macintosh SE Troubleshooting
Revision as of 17:50, 4 April 2025 by Josh (talk | contribs)
๐Ÿ”Œ Preliminary Checks and Power Supply Basics
Begin troubleshooting by confirming the analog board provides correct voltages: ideally, +5V DC (within 4.90โ€“5.10V) and +12V DC at the floppy or SCSI drive connectors.
If the SE appears completely dead (no fan, CRT glow, or startup chime):
  • Check analog board fuses, rectifiers (CR2, CR3), Q2 transistor, and R22 resistor
  • Test voltages with a multimeter
  • Disconnect any peripherals or internal cards
  • Inspect logic board for corrosion or capacitor leakage
  • Ensure reset and interrupt switches are not jammed
  • Perform full capacitor replacement (recap) on the logic board
๐Ÿ–ฅ๏ธ "Simasimac" โ€“ Horizontal Stripe Pattern
Macintosh Simasimac
The infamous Simasimac pattern (horizontal B&W stripes, no chime) usually means failed reset circuitry or RAM issues caused by leaky capacitors.
Steps to resolve:
  • Clean and reseat ROM and RAM chips
  • Replace PRAM battery if below 3.0V
  • Verify CPU reset and 16 MHz clock with an oscilloscope
  • Check continuity around capacitors for damaged traces
  • Inspect the Apple Sound Chip (ASC) and RP2 filter network
๐Ÿง  Chimes of Death and Sad Mac Codes
The Chimes of Death suggest serious logic board issues:
  • Reseat and clean ROM SIMM and RAM modules
  • Ensure memory banks are filled with identical SIMMs (4 per bank)
  • Test RAM slots and address/data lines for continuity
  • Replace faulty ICs like 74F258 multiplexers
  • Severe cases may involve the VIA or ASC chips
See Sad Mac Error Codes for full interpretation of error patterns.
๐Ÿ“บ Video Display Issues
No Video but Chime Present
  • Confirm CRT glow and brightness control
  • Check for missing sync/video signals at P1 connector
  • Suspect ICs like UE8 (video multiplexer)
Vertical "Jailbar" Stripes
  • Caused by RAM misconfiguration
  • Ensure matching SIMMs in each bank, larger ones in Bank A
Checkerboard Pattern
Checkerboard screen from logic board fault
  • Indicates ROM or early memory failure
  • Clean and reseat ROM SIMM
  • Use compatible ROM for SE (not SE/30 or IIsi)
๐Ÿ’พ Disk Drive and SCSI Issues
Frozen Mouse on Gray Screen
  • Suggests SCSI controller (NCR 53C80) failure
  • Disconnect internal SCSI devices to test
  • Replace SCSI chip if necessary
Floppy Drive Issues
  • Clean mechanical components
  • Check or replace the SWIM floppy controller
  • Resolder or replace nearby ICs
More on this can be found at:
๐Ÿ”Š Audio and ADB Issues
Audio Issues
  • No chime could mean bad ASC or analog amplifier
  • Check headphone jack โ€“ if it works, analog board is likely at fault
  • Replace ASC if digital audio fails
ADB Issues
  • No keyboard/mouse? Check and replace:
 * Fuse F1
 * ADB microcontroller (Egret)
  • Inspect solder joints on VIA chips and ADB port
๐Ÿ•ฐ๏ธ Recurring Reset or Clock Failures
  • Random resets = failing capacitors or shorted traces
  • Clock loss = bad 32.768 kHz crystal or dead PRAM battery
  • Clean up any electrolyte residue near ASC, VIA, or Egret chips
๐Ÿ”ง Analog Board Troubleshooting
  • Vertical line only = horizontal deflection issue โ†’ reflow P1 pins, replace C15
  • Horizontal line only = vertical collapse โ†’ check TDA1170A vertical IC
  • Wavy display = failing flyback transformer
  • Clicking power supply = logic board short or bad startup circuit (CR2/CR3, Q2, R22)
