IBM Options and Adapters - IBM Fixed Disk Adapter
Revision as of 03:16, 23 September 2026 by Josh (talk | contribs) (Documentation page for newly hosted IBM Options and Adapters technical reference section)
The IBM Fixed Disk Adapter section of IBM's Options and Adapters technical reference is the manufacturer's own reference for the MFM hard-disk controller shipped in the IBM PC XT.
What it contains
  • Description — attachment of one or two drives through an internal daisy-chained data/control cable, a maximum of one adapter and two drives per system, buffering on the I/O bus, use of the system board's DMA and of an interrupt level, and automatic 11-bit burst error detection and correction by way of 32-bit ECC. IBM also warns that the last cylinder is reserved for diagnostics and that the diagnostic write test destroys any data on it.
  • Programming — the status register, the sense bytes, the data register, the control byte and the full command summary.
  • Interface — the I/O address range hex 320 to hex 323, the controller-select pulse written to hex 322, and the adapter ROM decoded between hex C8000 and hex C9FFF.
  • BIOS listing — the complete commented assembler source of the adapter's own device-level control ROM, including the power-on diagnostic that displays 1701 when it fails.
  • Logic diagrams — the full schematic.
Download it here: IBM Options and Adapters - IBM Fixed Disk Adapter.pdf
