Amstrad PC1640 Service Manual
Revision as of 23:17, 24 September 2026 by Josh (talk | contribs) (Real documentation page: full printed title (PC1640 / PC-MD / PC-CD / PC-ECD), contents, the technical specification incl. the 0.31 mm ECD shadow mask and three slots retained with the hard disc, and the two sections worth knowing about (bad sectors on a period MFM drive, and the display-mode switch settings). Pointed at the separate VDU Tests manual for EGA/Hercules testing)
The PC1640 Personal Computer / PC-MD Monochrome Display / PC-CD Colour Display / PC-ECD Enhanced Colour Display Service Manual is Amstrad's own service manual for the PC1640 and its three displays. 76 pages, with a text layer and searchable.
Contents
Amstrad's own contents list:
  • Technical specification; safety tests
  • FD-3 maintenance โ€” pages 3–14
  • Flow charts โ€” 15–18
  • Hard disc installation instructions
  • Switch settings
  • Understanding bad sectors on a hard disc
  • Notes
  • Keyboard exploded diagram; keyboard control PCB layout; keyboard schematic diagram
  • PC1640 electrical parts list
  • PC1640/SD/DD/HD20 cabinet drawing and parts list
  • PC1640/SD/DD/HD20 CPU PC board, top and bottom views
  • PC1640/SD/DD/HD20 chassis schematic diagrams
  • Sections for the PC-MD, PC-CD and PC-ECD displays
What it settles
Technical specification: 640K system unit with all circuitry on a single motherboard; 8 MHz 8086; fully compatible internal graphics adaptor; three full-size expansion slots โ€” retained even with the hard disc option; one or two 360K 5.25-inch floppies or one floppy with a 20 MB hard disc; RS232 and parallel interfaces; loudspeaker with volume control; battery-backed real-time clock and configuration RAM; socket for an 8087; light pen and/or joystick connector; keyboard joystick port; two-button mouse with a dedicated port on the system unit; a choice of three displays โ€” paper-white monochrome, colour, or enhanced colour โ€” on a standard video connector. The ECD monitor has a 0.31 mm pitch shadow mask.
Two sections are worth knowing about beyond the usual:
  • "Understanding bad sectors on a hard disc" โ€” Amstrad's own explanation of what the defect list on a period MFM drive means and when a bad sector is expected rather than a fault. Useful before condemning a drive.
  • Switch settings โ€” the configuration switches, which on a PC1640 determine which display adaptor mode the machine boots in. A PC1640 with a blank screen is frequently set for the wrong display.
The FD-3 maintenance section at pages 3–14 is the same detailed drive procedure as in Amstrad PC1512 Service Manual.
  • No VDU diagnostic test documentation. Amstrad published that separately; see Amstrad PC1640 VDU Tests Manual, which covers the EGA and Hercules modes this manual does not exercise.
  • No hard disc repair data โ€” installation and bad-sector explanation only.
  • No coverage of the PC1512 or the PC2000 series.
Download here: Amstrad PC1640 Service Manual.pdf
