Apple External Hard Drive SC Service Source
Revision as of 07:31, 25 September 2026 by Josh (talk | contribs) (P4: turn document holder into a real documentation page (verification drive))
The External Hard Drive SC volume of Apple's Service Source is a 52-page service document for Apple's external SCSI hard drive enclosures. The PDF was distilled on 14 December 1995.
Unusually, the Exploded View comes first: it is on pdf pp. 2-3, before the Take Apart chapter.
Contents
  • Exploded View (pdf pp. 2-3)
  • Take Apart (pdf pp. 5-28) - Cover, Power Supply, Hard Drive Mechanism, SCSI Select Switch Cable, LED Cable Assembly, Fan Frame, HDA-to-Case Cable, Fan, SCSI Select Switch
  • Additional Procedures (pdf pp. 29-52) - Carrier Removal; Torque Sequence; Modifying 5.25 Drives; Modifying 3.5 Drives; General Return Information; Setting SCSI ID
The Additional Procedures chapter is the same material Apple prints in its general Hard Drives volume, which is hosted on this wiki as Macintosh Disk Drive and UniDisk 3.5 Service Source (the file there is mis-titled; the document inside it is Hard Drives).
No Specifications chapter and no symptom chart. Nothing on capacity, transfer rate, supply rails or current draw; no parts list, no schematic, no component values. The manual does not name which mechanisms Apple shipped in these enclosures, so it cannot be used to identify a drive.
Pages that cite this document
Download: External hard drive sc.pdf
