Apple Multiple Scan 15 Service Source
Revision as of 07:36, 25 September 2026 by Josh (talk | contribs) (P4: turn document holder into a real documentation page (verification drive))
The Apple Multiple Scan 15 Display volume of Apple's Service Source is a 32-page service manual. The PDF was distilled on 9 November 1995.
Specifications as printed
Item Value
Picture tube 15 in diagonal flat square shadow mask, 13.3 in viewable; 0.28 mm dot pitch
Screen resolution 640 x 480, 800 x 600, 832 x 624; 1024 x 768 only on PCs through a Mac/PC adapter
Scan rates vertical refresh 60-75 Hz; horizontal 31.77-56.5 kHz
Video input RGB analogue, RS-343A, 0.714 V peak-to-peak positive-going
Sync on green RS-343A level, 0.286 V ±10% negative-going during blanking
Separate or composite sync 1 to 5 V peak-to-peak, either polarity
Mains 90-134 and 198-260 VAC, self-configuring, 47-63 Hz
Power 90 W maximum
Size / weight 16.5 in (424 mm) H x 15.8 in (405 mm) W x 17.6 in (452.3 mm) D; 31 lb (14 kg)
The 0.714 V p-p video and 0.286 V sync-on-green levels are the most useful numbers in this manual: they are a direct go/no-go check on a suspect video cable or graphics card with an oscilloscope, and they apply to every Apple analogue RGB display of this era.
Apple also documents manual degauss: switch the monitor off and on again, noting that a full degauss is only possible after the monitor has been off for 20 minutes or more.
Contents
  • Basics - Overview (pdf pp. 3-4)
  • Specifications - Characteristics, Controls and Ports, Physical and Electrical, Environmental (pdf pp. 6-11)
  • Troubleshooting - General, symptom charts for No Raster, Geometry, Video and Miscellaneous (pdf pp. 13-17)
  • Adjustments - Brightness and Contrast, Geometry, Zooming, Factory Settings (pdf pp. 19-32)
No Take Apart chapter and no Exploded View. No parts list, no schematic, no component values, no fuse data. Everything in the Adjustments chapter is done from the front panel; there is no internal alignment procedure.
Pages that cite this document
A CRT display holds a lethal charge on the anode after the mains is removed. Follow CRT Discharge Procedure before working inside one.
Download: Multiple scan 15 display.pdf
