Macintosh Plus Service Source
Revision as of 08:28, 25 September 2026 by Josh (talk | contribs) (P4 verification: turn document holder into a real documentation page (contents with PDF page numbers, Apple's own specifications, honest gaps, citing pages))
The Macintosh Plus volume of Apple's Service Source is a 69-page service manual covering the Macintosh Plus. The PDF was distilled on 21 October 1995.
The Plus volume is one of only three Macintosh Service Source manuals that contains an Adjustments → Voltage chapter; the SE, SE/30, Classic and everything later have yoke and video adjustments only.
Service Source volumes are module-level documents. They give Apple's own specifications, symptom charts, take-apart procedures and module part numbers, but they do not carry schematics, board-level parts lists or component values, so they cannot be used to source a capacitor table. Where a figure below is quoted, it is quoted as Apple printed it.
Specifications as Apple prints them
Item As printed
CPU Motorola 68000 at 7.83 MHz
Line voltage 105–125 VAC
Frequency 50–60 Hz
Maximum power 60 W
Contents
Reconstructed from the manual's own running headers; page numbers are positions in the PDF, so a citation can be checked directly.
  • Basics — Overview (pdf p. 3)
  • Specifications — Introduction (pdf p. 5), Processor (pdf p. 6), Memory (pdf p. 7), Disk Storage (pdf p. 8), I/O Interfaces (pdf p. 9), I/O Devices (pdf p. 10), Sound and Video (pdf p. 11), Electrical (pdf p. 12), Physical (pdf p. 13)
  • Troubleshooting — General (pdf p. 15), Symptom Charts (pdf p. 16)
  • Take Apart — Cover (pdf p. 27), Power/Sweep Board (pdf p. 29), Logic Board (pdf p. 33), CRT (pdf p. 39), Floppy Drive (pdf p. 42), Chassis (pdf p. 44)
  • Upgrades — Memory Upgrade (pdf p. 47)
  • Adjustments — Voltage (pdf p. 51), Yoke (pdf p. 58), Video (pdf p. 63)
Notable content
The voltage adjustment is made on the power/sweep board through the external drive port using Apple voltage test cable 077-0135: orange lead 11.90–12.75 V, red lead 4.85–5.15 V, and the board is replaced if both cannot be brought into tolerance together. The procedure is transcribed in full on Macintosh 128K/512K Service Source.
  • No parts list, no schematic, no component values — the power/sweep board is a module.
  • The Electrical specification gives the 105–125 V machine only; the 220–240 V board is not separately specified.
Pages that cite this document
This machine contains a high-vacuum picture tube and a live analogue board. Follow CRT Discharge Procedure before working inside one.
Download: Macintosh_Plus.pdf (538 KB)
