IBM Quietwriter III 5202 Printer Hardware Maintenance and Service
Revision as of 21:37, 30 September 2026 by Josh (talk | contribs) (Correct 'lubrication points and intervals': chapter 8 lists points and lubricants but no interval; add PSU connector voltages, lubricant P/Ns, tools, adjustments; drop unsourced 'very few manuals do this' and 'resistive-ribbon' wording)
The IBM Quietwriter III Printer 5202 Hardware Maintenance and Service manual, Third Edition (November 1987), is IBM's field service manual for the Quietwriter III, a letter-quality printer for the IBM Personal Computer that prints at 100 to 160 characters per second (burst) by what IBM calls "nonimpact thermal printing technology" (p. 1-1). The PDF has 264 pages.
Associated documentation named in the preface: the Quietwriter III Printer 5202 Guide to Operations (S544-4082, P/N 1319571), the Technical Reference (S544-4083, P/N 1319601), the Sheetfeed Option Guide to Operations (S544-4122, P/N 1318499) and the Sheetfeed Hardware Maintenance and Service (SY20-8580, P/N 6373116).
Contents
Page numbers are the manual's own.
Chapter Subjects Page
1. General Information printer description, maintenance approach, setup switches, special tools and test equipment, safety 1-1
2. Diagnostic Tests tests used to find or repeat a symptom 2-1
3. Diagnostic Information the MAPs, starting with MAP 0100 (p. 3-2) 3-1
4. Repair Information removal and replacement of each FRU, including the power supply (4-25) and the Level 1 and Level 2 printer boards (4-27, 4-29) 4-1
5. Adjustments cardholder, carrier transport belt, deflector, printhead height, printhead solenoid, ribbon take-up motor collar, transport motor belt 5-1
6. Locations printer assembly, carrier board and printer board connectors, printer wiring diagram 6-1
7. Print and Ribbon Samples samples of good and defective print, ribbon samples 7-1
8. Preventive Maintenance safety inspection guide, lubrication specifications 8-1
9. Parts Catalog 9-1
Index X-1
Figures a repairer can use
  • Power supply output connector (MAP step 032, p. 3-26): pin 1 ground, pin 2 -12 V, pin 3 ground, pins 4 and 5 +38 V motor supply, pins 6 to 9 ground, pins 10 to 13 +5 V logic supply. The same MAP also checks 30 V and -5 V.
  • Lubrication (p. 8-2): IBM No. 10 oil on the carrier pivots, pinch roller shaft, capstan/clutch pulley bearing and idler pulley; IBM No. 23 grease on the load lever cam and link and the paper bail and release lever points. Oil and grease must be kept off the platen, feed rolls, paper bail rolls, rubber mounts and drive belts. IBM part numbers: No. 23 grease 1280441 (1/2 oz) and 1280442 (1 lb); No. 10 oil 1280443 (4 oz) and 1280444 (1 pint). The chapter lists lubrication points and lubricants but gives no service interval.
  • Special tools (p. 1-8): IBM part numbers for the scales, feeler gauge, splined wrenches, spring hook, T-bender, an analog VOM (Triplett 310C or equivalent, P/N 9900167), wrap plug 1341046 and ESD kit.
It works to FRU level: the printer board, carrier board and power supply are replaced as units, and there is no circuit schematic or component value. The Chapter 6 wiring diagram shows the interconnections between assemblies only. The sheet feeder has its own maintenance manual.
Download: IBM Quietwriter III 5202 Printer Hardware Maintenance and Service.pdf
