IBM ThinkPad T20 T21 T22 T23 Service Manual
The IBM Mobile Systems ThinkPad Computer Hardware Maintenance Manual of April 2002 is IBM's service manual for the ThinkPad T20, T21, T22 and T23, part number 62P9631, First Edition (April 2002), 182 pages. The title page lists the ThinkPad T20, T21, T22 and T23 (MT 2647/2648) and the ThinkPad Dock (MT 2631). All four models share the two machine types. The same file is also on IBM Mobile Systems ThinkPad Hardware Maintenance Manual (April 2002).
Contents
Page numbers are the manual's own.
- Introduction (pp. 1-18): strategy for replacing FRUs and how to use error messages, diskette compatibility matrix, safety notices in English, French, German, Italian and Spanish, safety information and the laser compliance statement.
- General descriptions (pp. 21-37): read this first, related service information including restoring the preloaded system, passwords (p. 26) and power management (p. 28); checkout guide (p. 32) with PC-Doctor (p. 34) and the power system checkout (p. 35).
- ThinkPad T20, T21, T22 and T23 series, from p. 39: product overview and specifications (p. 41), status indicators, FRU tests, Fn key combinations; symptom-to-FRU index (p. 49).
- FRU replacement notices (p. 56): screw notices and retaining serial numbers.
- Removing and replacing a FRU (pp. 59-139): numbered procedures from 1010 Battery pack (p. 60) to 3020 ThinkPad Dock top cover (p. 136).
- Locations (p. 140) and parts list (p. 143), with the model matrix (p. 146), LCD FRUs (p. 157), keyboards (p. 160) and recovery CDs (p. 161).
- Notices (p. 174).
The manual works at FRU level. It has no schematics and no component values, and a system board is a single part number. The only capacitor it mentions is the "bulging capacitor" hazard in the safety inspection guide.
What it settles
The power system checkout (pp. 35-37) gives these limits: AC adapter output +15.5 to +17.0 V dc at pin 1; battery pack +0 to +12.6 V dc between terminals 1 and 5, discharged if below +11.0 V dc, and 4 to 30 kΩ between terminals 4 and 5 if above it; backup battery +2.5 to +3.2 V dc on the red wire.
The password section (pp. 26-27) sets out what IBM would and would not reset: a forgotten power-on password can be removed; a forgotten supervisor password has no reset procedure and the system board must be replaced; a forgotten user hard-disk password can be bypassed only with the master hard-disk password.
The screw notices (p. 56) say the screws are nylon-coated, should be used only once, and are tightened by angle (90 degrees past contact for plastic to plastic, 180 degrees for logic card to plastic) or to the torque given in each procedure.
Download: IBM ThinkPad T20 T21 T22 T23 Service Manual.pdf
- IBM Mobile Systems ThinkPad Hardware Maintenance Manual (April 2002), the same file under the cover title
- IBM ThinkPad T30 Hardware Maintenance Manual, IBM ThinkPad A20m/p A21m/p A22m/p Hardware Maintenance Manual, IBM ThinkPad X20 X21 X22 X23 X24 Hardware Maintenance Manual
- IBM ThinkPad Notebooks - Personal Systems Reference (machines withdrawn by January 2001) and IBM ThinkPad Notebooks (A/G/R/T/X) - Personal Systems Reference (A, G, T and X series withdrawn by May 2005), for model specifications by type-model
