Amstrad DMP2000 / DMP3000 / DMP4000 Service Manual
The DMP2000 / DMP3000 / DMP4000 Printer Service Manual is Amstrad plc's combined service manual for three dot-matrix printers. It has 22 pages and a text layer. A note under the first contents list reads "DMP2000/3000 section only. For DMP4000 see pages 13 onwards", and the DMP4000 section has its own contents list on page 13.
Contents
Amstrad's contents lists, with printed page numbers:
- DMP2000/3000: safety note 2, technical specifications 2, interface 3, dipswitch settings 3, control PCBs 4, cabinet drawing 5, printer mechanism 6, printer mechanism parts list 7, block diagram 7, wiring diagram 8 and 9, circuit diagram 10 and 11, electrical parts list 12
- DMP4000: technical specification 13, safety note 13, exploded view and parts list 14, cabinet drawing and parts list 15, component layouts 16, layouts/masks 17, electrical parts list 18, wiring diagram 19, circuit diagram 20
Page 2 prints the DMP2000 and DMP3000 side by side. Both are impact dot-matrix printers with 9 × 9 characters, Centronics-compatible parallel interfaces and 220–240 V AC 50 Hz supplies. The DMP2000 is rated at 105 cps maximum; the DMP3000 at 105 cps for normal characters and 52 cps double width, and it adds italics. Both list pica (10 cpi, 80 columns), elite (12 cpi, 96 columns) and the double-width and double-width condensed sizes; the condensed size (17 cpi, 137 characters per line) is listed for the DMP2000 only. The DMP2000 measures 380 × 100 × 260 mm; the DMP3000 400 × 250 × 100 mm and 4.2 kg.
The DMP4000 (p. 13) is a wide-carriage wire dot-matrix printer: 200 cps standard and 50 cps near letter quality, 136 columns standard and 233 condensed, tractor paper 3 to 16½ inches wide, 600 × 350 × 120 mm and 9.5 kg.
What it covers
The DMP2000/3000 electrical parts list (p. 12) gives part numbers for the ICs, including the µPD7811G-071 controller (IC6) and the L7805CY regulator (IC18), the transistors, diodes, S4VB10 and S2VB10 bridge rectifiers, the mains transformer and filter coil, and the resistors and capacitors by value. The DMP4000 list (p. 18) is laid out the same way and includes the 7805 regulator, a 4700 µF / 16 V capacitor at C2 and three fuses: T1A, T5A and T3.15A, all 250 V. The printer mechanism parts list (p. 7) and the DMP4000 mechanism list (p. 14) give mechanical part numbers, including the DMP4000 print head (190972).
- Troubleshooting or fault-symptom tables of the kind in the DMP1 manual.
- Adjustment procedures.
- The DMP1 or the LQ3500.
The standalone DMP2000 manual is a separate 12-page edition for the DMP2000 alone, with its drawings in a different order.
Download: Amstrad DMP2000 DMP3000 DMP4000 Service Manual.pdf
