Sinclair ZX Spectrum 128 Capacitor Replacement Guide
The Sinclair ZX Spectrum 128 has a full component-level parts list in Sinclair's Service Manual, so every capacitor's designator, value, rating and type is documented. The tables below are transcribed from Table 5.4 (main PCB) and Table 5.5 (keypad PCB).[1]
Safety and board handling
[edit | edit source]There is no mains voltage inside the computer: it runs from an external power pack, and the highest rail on the board is +12 V.[1]
The Service Manual asks for recognised desoldering and heatsinking techniques and a suitably earthed, low-power iron, and for the board to be checked for solder splatter after any component is renewed.[1] Add fresh flux and solder to old joints before removing parts, and keep the time on each joint short.
When to replace capacitors
[edit | edit source]There are 13 electrolytics on the main board, so a targeted recap is quick when there is a reason for it:[1]
- Visible failure: bulging, leakage, residue or a split sleeve.
- An unstable supply, or rails out of tolerance or showing ripple. In the power circuit described in section 1.10, D15 and C44 rectify and smooth the inverter output to +12 V, and C111 and C112 with D28 and D29 form the charge pump that makes −12 V.[1]
- A dead RS232 port or keypad: the RS232 driver IC33 runs from +12 V and −12 V, and the keypad from +12 V, so check C44, C111 and C112.[1]
- Wavy lines across the display. Sinclair's 48K service manual gives the test: press down on each electrolytic in turn, and if the lines disappear, change that capacitor.[2]
Vertical banding ("jailbars") on the RGB output is not cured by a routine recap; it has its own modification, described below.[3]
Main board capacitors
[edit | edit source]From Table 5.4 of the Service Manual. Unless otherwise stated, all the capacitors are axial. Designators not listed here are marked "not used"; the 128 board has many unpopulated positions.[1]
Electrolytic capacitors
[edit | edit source]| Ref | Value | Rating / tolerance | Notes |
| C25 | 100 µF | 10 V, −10% +80% | |
| C27 | 1 µF | 50 V, 10% | |
| C28 | 22 µF | 10 V, −10% +80% | Changed to 47 µF in the jailbars modification |
| C34 | 22 µF | 10 V, −10% +80% | |
| C44, C45 | 100 µF | 10 V, −10% +80% (as printed; see below) | C44 smooths the +12 V rail with D15 |
| C50 | 22 µF | 10 V, −10% +80% | |
| C74 | 4.7 µF | 5 V minimum | |
| C80 | 22 µF | 10 V, −10% +80% | |
| C111, C112 | 47 µF | 16 V, −10% +80% | The −12 V charge pump, with D28 and D29 |
| C123 | 1 µF | 10 V, −10% +80% | |
| C127 | 1 µF | 10 V, −10% +80% |
The parts list gives C44 and C45 a 10 V rating, but section 1.10 places C44 on the +12 V rail, above that rating. Sinclair's 48K service manual lists C44 and C45, in the same inverter arrangement, as 100 µF 16 V.[1][2] Fit parts rated at 16 V or more at C44 and C45.
Ceramic capacitors
| C1–C8 | 22 nF | 25 V, 10% |
| C26 | 22 nF | 25 V, 10% |
| C29, C30 | 22 nF | 25 V, 10% (see note) |
| C31, C32 | 100 nF | 25 V, 10% |
| C35 | 10 nF | 25 V, 10% |
| C41 | 22 nF | 25 V, 10% |
| C43 | 100 nF | 25 V, 10% |
| C49 | 560 pF | 25 V, 10% |
| C55–C62 | 22 nF | 25 V, 10% |
| C66 | 22 nF | 25 V, 10% |
| C67 | 100 pF | 25 V, 10% |
| C75 | 100 nF | 25 V, 10% |
| C100 | 10 nF | 25 V, 10% |
| C101 | 22 nF | 25 V, 10% |
| C104 | 100 nF | 25 V, 10% |
| C105 | 180 pF | 25 V, 10% |
| C106–C110 | 22 nF | 25 V, 10% |
| C113, C114 | 47 nF | 25 V, 10% |
| C115 | 330 pF | 25 V, 2% |
| C116 | 10 nF | 25 V, 10% |
| C118, C119 | 1 nF | 25 V, 10% |
| C120 | 100 pF | 25 V, 10% |
| C121 | 47 pF | 25 V, 10% |
| C122 | 1 nF | 25 V, 10% |
| C124 | 20 pF | 25 V, 2% |
| C125 | 100 nF | 25 V, 10% |
| C126 | 22 pF | 25 V, 10% |
| C128 | 47 nF | 25 V, 10% |
| C129 | 100 pF | 25 V, 10% |
| C130 | See note | 25 V, 2% |
Sinclair's printed table lists "C29, C31" as 22 nF and then lists C31 again as 100 nF, while C30 does not appear at all, so the first entry is probably C29 and C30. Check the board.[1]
Note 6 to Table 5.4 says the 20 pF capacitor at C124 may be split into two 10 pF ±2% capacitors in parallel at C124 and C130, so whether C130 is fitted depends on how the board was built. Note 3 records that the PCB has provision for a 2–22 pF film-dielectric trimmer should it be needed.[1] C115, C124 and C130 are 2% parts; match the tolerance as well as the value.
Keypad PCB capacitors
[edit | edit source]The numeric keypad has its own small board with a General Instrument PIC1652 microcontroller:[1]
| Ref | Value | Rating / tolerance | Type |
| C1 | 1 µF | 10 V, −10% +80% | Electrolytic |
| C2, C3 | 47 pF | 25 V, 10% | Ceramic |
The jailbars modification
[edit | edit source]Some Toastracks show faint vertical banding on plain, light colours on the RGB output that does not appear over RF or composite video. Spectrum for Everyone suspects the PCB ground plane and gives this fix:[3]
- Replace C28 (22 µF, to the right of the 5-way keyboard connector) with a 47 µF axial electrolytic.
- Replace C7 and C8 (next to the IC12 and IC13 RAM chips, bottom left of the board) with 1 µF ceramic capacitors.
This reduces the banding significantly without removing it entirely. The equivalent change on the 48K is C5 to C8 to 150–220 nF, and on a grey +2 (Z70500 Issue 3) it is C52.[3]
Choosing replacements
[edit | edit source]- Use aluminium electrolytics of the same capacitance and the same or a higher voltage rating, rated for 105 °C, and at least 16 V at C44 and C45.
- Most of the originals are axial. If you fit radial parts, form the leads neatly and sleeve any long lead.
- Match the tolerance of the 2% parts (C115, C124, C130).
- Leave the ceramics alone except as part of the jailbars modification.
Replacement procedure
[edit | edit source]- Unplug the power, open the case and disconnect both keyboard ribbon cables.
- Lift the board out so it can be supported flat.
- Record the value, voltage and polarity of each electrolytic before removing it, and check it against the table above.
- Add fresh flux and solder to both joints.
- Lift one lead at a time with the joint fully molten, then clear the hole with wick.
- Fit the replacement the correct way round, solder it and trim the leads.
- Check for bridges and solder splatter before reassembly.[1]
Post-recap checks
[edit | edit source]- Power up, preferably on a current-limited bench supply, and check that the 128 menu appears.
- Check the supplies against the basic-checks table: +5 V ± 0.25 V at the regulator output, +12 V ± 0.5 V at IC33 pin 14, −12 V at IC34 pin 1, and −5 V at the anode of D19.[1]
- Check the clocks: 17.73447 MHz at IC37 pin 6, 3.54689 MHz at IC2 pin 6 and 8.8 MHz at IC1 pins 46 and 47, all with no jitter.[1]
- Check the display for wavy lines or new artefacts.
- Test the AY sound and the beeper, a tape load and the whole keyboard.
If a function that worked before the recap now fails, check the polarity of every replaced electrolytic first.
[edit | edit source]- Sinclair ZX Spectrum 128
- Sinclair ZX Spectrum 128 General Maintenance
- Sinclair ZX Spectrum 128 Troubleshooting Guide
- Sinclair ZX Spectrum+ Capacitor Replacement Guide
- Sinclair ZX Spectrum +2 Capacitor Replacement Guide
- Capacitor Failure Symptoms
[edit | edit source]- ↑ 1.00 1.01 1.02 1.03 1.04 1.05 1.06 1.07 1.08 1.09 1.10 1.11 1.12 1.13 Sinclair ZX Spectrum 128 Service Manual (File:ZX Spectrum 128 Service Manual.pdf), Sinclair Research Ltd; re-typeset Revision 1.1 by Brendan Alford. Table 5.4 (main PCB components), Table 5.5 (keypad PCB components), section 5.2 (notes to Table 5.4), section 1.10 (power supplies), section 4.2.3 (basic checks) and section 4.3 (repair notes).
- ↑ 2.0 2.1 Sinclair ZX Spectrum Service Manual (File:Sinclair ZX Spectrum Service Manual.pdf), Sinclair Research Ltd, section 6.4.3 "Wavy lines across screen"; parts list section 8.5 (C44/C45 100 µF 16 V).
- ↑ 3.0 3.1 3.2 "Fixing Vertical 'Jailbars' on your 48K, 128K and Grey Spectrum +2", Spectrum for Everyone.
