Schneider DMP4000 Service Manual
Revision as of 14:41, 1 October 2026 by Josh (talk | contribs) (Checked against the PDF: page map corrected (pp. 5, 8-9, 11), invented references F1-F3, X1, BZ1, CN9 removed, column is Teile-Nr.; capacitor values are on the circuit diagram; remove uncited fault claims, bold and em dashes)
The Kundendienst-Handbuch / Service Manual DMP 4000 is Schneider's service manual for the DMP 4000 wide-carriage dot-matrix printer, Ident-Nr. 33984, footer code HDS 60964/2500/16/87. It has 14 pages, with the parts lists in German and English side by side, and the scan has a text layer. Amstrad's combined manual covers the DMP4000 in an eight-page appendix; this manual is for the DMP 4000 alone and has its own electrical parts list.
Contents
  • p. 1: cover
  • p. 2: cabinet parts list
  • p. 3: cabinet drawing
  • p. 4: mechanism parts list (print head 37 665 00-501, motors, gears, springs, tractors, carriage, platen)
  • p. 5: printer mechanism drawing
  • pp. 6–7: circuit diagram
  • pp. 8–9: main PCB
  • p. 10: wiring diagram
  • p. 11: AC PCB, with the mains-side warning label, and control PCB
  • p. 12: electrical parts list: ICs, transistors, diodes and resistors
  • p. 13: capacitors, switches and miscellaneous parts, including the fuses
  • p. 14: technical data (in German), DIP-switch table and Centronics interface pinout
Selected parts, as printed
The list does not give circuit references for the fuses, the resonator, the bleeper, the sensor assemblies or the Centronics socket.
Ref Part Teile-Nr. (part no.)
fuse T5A / 250 V 124A0001-5000
fuse T3.15 / 250 V 124A0001-3150
fuse T1A / 250 V 124A0001-1000
C101, C104 0.047 µF / 250 V metallised film 102A0008-4725
LF1 mains filter coil, 1.3 mH 108A1000-0001
11 MHz ceramic resonator 111A0002-1160
DSW1 8-way DIP switch 107A0010-0801
DSW2 10-way DIP switch 107A0010-1001
SW1–SW4 tact switches 107A0011-0112
piezo bleeper 114A0091-0001
36-way Centronics socket 109A0006-3603
PT1 photo-interrupter SPI 216 P88010
HP (home position) sensor assembly SP1300A56
PE (paper end) sensor assembly SP1300A67
IC1 7805 voltage regulator 106A0003-7805
IC12 µPD7811 106A0000-7811
IC9 256K EPROM, 250 ns 106A0001-2756
IC11 6264-15 SRAM 106A0001-6264
BR1, BR2 bridge rectifiers RS403L 104A1003-0410
D1, D5 1N6275 15 V transient suppressor 104A2012-6275
D8 RD15 1 W zener 104A2001-1150
D35, D36 RD47 1.5 W zener 104A2001-2470
TR3 2SD1196 105A0204-1196
TR10 2SA1423 105A0101-1423
R77, R78 7.5 Ω 3 W 101A0006-0751
The three fuses are all time-lag (T) types rated 250 V: T5 A, T3.15 A and T1 A. The DMP 3000 has two, T3.15 A and T315 mA.
The parts list itemises only two capacitors, C101 and C104, both 0.047 µF 250 V metallised film. The electrolytics are not listed; capacitor values are marked on the circuit diagram (pp. 6–7).
Technical data, as printed
Item Value
Print system Impact dot-matrix (needle) printer
Speed 200 characters/s normal
Character matrix ASCII table 1: 9 × 9; table 2: 18 × 9; special characters tables 3.1/3.2: 12 × 11 and 4.1/4.2: 24 × 11
Character sets 96 ASCII, 96 italic, 96 NLQ, 96 NLQ italic, 9 international sets, 132 special characters including IBM graphics
Columns 136 standard (10 characters/inch), 163 elite (12 characters/inch), 233 condensed (17 characters/inch)
Line feed 1/6, 1/8 or 7/72 inch, n/72 and n/216 inch programmable; 1/6 inch in 0.1 s
Paper Continuous 7.5–42 cm wide; single sheet 8–39.5 cm wide
Interface Parallel, Centronics-compatible
Mains 220–240 V, 50 Hz
Size and weight 60 × 35 × 14 cm; 9.5 kg
The interface table gives a +5 V supply output rated at 50 mA maximum.
What it does not contain
There is no fault-finding table, adjustment procedure or list of the electrolytic capacitors.
Download: Schneider DMP4000 Service Manual.pdf (2.8 MB)
