Atari PC4 Manuel d'Utilisation
Revision as of 18:07, 1 October 2026 by Josh (talk | contribs) (Documentation page for the hosted PDF: title, contents, gaps and citing pages)
The Atari PC4 Manuel d'Utilisation is Atari Corporation's French owner's manual for the Atari PC4, copyright 1988. The scan has 154 pages with a text layer of poor OCR quality in places.
Contents
Sections useful for repair, with printed page numbers:
  • Chapter 1, the machine and setting it up, including fitting memory modules in pairs and the 80287-12 coprocessor (section 1.6.2, pp. 8 to 9)
  • Section 1.7, specifications (pp. 22 to 24): Intel 80286 at 8 or 12 MHz, selected from the keyboard or by software (12 MHz by default); 1 MB RAM, expandable to 8 MB; 96 KB ROM; 145 W internal supply; two serial ports (one through an adapter), one parallel port, analogue and digital video ports; four AT/XT slots and one XT slot; 15 × 38 × 41 cm; 360 KB and 1.2 MB 5.25-inch drives
  • Appendix A, system configuration and the SETUP program, including the extended setup (wait states, memory, page/interleave mode, cache RAM, EMS) (pp. 85 to 107)
  • Appendix B, system maintenance (p. 109 onwards): replacing the clock battery, which sits in a holder screwed to the chassis and connected by a cable (pp. 110 to 111); start-up error messages, beep codes and the DIAGS diagnostic program
  • Appendix C, connector pinouts, including the internal power connector (pp. 123 to 130)
No schematic or parts list.
Pages that cite this document
  • Atari PC4: cites Section 1.6.2, pp. 8–9, pp. 109–122, pp. 110–111, Section 1.7
Download: Atari PC4 Manuel d'Utilisation (1988).pdf
