Macintosh Server G3 Documentation
Revision as of 07:12, 2 October 2026 by Josh (talk | contribs) (New page from Apple's Power Mac G4 Service Sources, spec pages and setup guides)
Apple documentation for the Macintosh Server G3.
Setting Up Your Macintosh Server G3 (1999)
Setting Up Your Macintosh Server G3 is Apple's 78-page owner's guide, "Includes setup and expansion information for the Macintosh Server G3 with Mac OS X Server", © 1999 Apple Computer. It covers the blue and white Server G3, with USB, FireWire and ADB ports, a Wide Ultra2 SCSI card with two drives and a four-port 10/100 Ethernet card. Page numbers below are the guide's printed numbers, which match the PDF pages.
Contents
  • Preface, Introducing the Macintosh Server G3 (p. 9): hardware and software features (10), hardware and software limitations in Mac OS X Server (11)
  • Chapter 1, Setting Up (p. 13): ports and connectors (16), plugging in and the voltage switch (18), monitor, keyboard and mouse, Ethernet (25)
  • Chapter 2, Working Inside the Server (p. 31): memory (32–33), internal storage and Wide Ultra2 SCSI drives (33–35), PCI cards and their power (35–36), the battery (36), opening the server (37), installing DRAM (40), installing drives (42), installing a PCI card (52), replacing the battery (55), closing the server (56)
  • Chapter 3, Starting Up Your Server (p. 59): turning it on and off, problems turning it on (61), using it without a monitor, restoring software
  • Chapter 4, Health, Safety and Maintenance (p. 67)
What it settles
  • The server's 3.6 V lithium backup battery is on the main logic board (p. 36).
  • Memory: PC-100 SDRAM, 3.3 V, unbuffered, 64-bit, 168-pin, no taller than 2.0 in, in four slots to 1024 MB; 256 MB DIMMs must use 128 Mbit chips; DIMMs need not be paired (p. 33).
  • PCI: slot 1 is a 66 MHz, 3.3 V slot holding the graphics card; with the SCSI and Ethernet cards fitted there is room for one more 33 MHz card drawing up to 25 W (p. 36).
  • SCSI IDs: factory drives use 0, 1 and 2, the SCSI card 7 (p. 46).
  • The voltage switch must be set correctly: "115" for 100–120 V, "230" for 200–240 V (p. 18).
  • Mac OS X Server of the time did not support FireWire, USB devices other than the keyboard and mouse, DVD-ROM discs, modem connections or most add-on PCI cards (p. 11).
What it does not contain
A user's guide: no service procedures beyond the customer-installable parts, no symptom charts, no part numbers or component data. It does not cover the 1998 beige Server G3.
Pages that cite this document
Download: Setting Up Your Macintosh Server G3 (1999).pdf
