Module:Sidebar
Revision as of 16:15, 15 March 2025 by Josh (talk | contribs) (1 revision imported)
Documentation for this module may be created at Module:Sidebar/doc
require('strict')
local cfg = mw.loadData('Module:Sidebar/configuration')
local p = {}
local getArgs = require('Module:Arguments').getArgs
Categorizes calling templates and modules with a 'style' parameter of any sort
for tracking to convert to TemplateStyles.
TODO after a long cleanup: Catch sidebars in other namespaces than Template and Module.
TODO would probably want to remove /log and /archive as CS1 does
local function categorizeTemplatesWithInlineStyles(args)
	local title = mw.title.getCurrentTitle()
	if title.namespace ~= 10 and title.namespace ~= 828 then return '' end
	for _, pattern in ipairs (cfg.i18n.pattern.uncategorized_conversion_titles) do
		if title.text:match(pattern) then return '' end
	end
	for key, _ in pairs(args) do
		if mw.ustring.find(key, cfg.i18n.pattern.style_conversion) or key == 'width' then
			return cfg.i18n.category.conversion
		end
	end
end
For compatibility with the original {{sidebar with collapsible lists}}
implementation, which passed some parameters through {{#if}} to trim their
whitespace. This also triggered the automatic newline behavior.
-- See ([[meta:Help:Newlines and spaces#Automatic newline]])
local function trimAndAddAutomaticNewline(s)
	s = mw.ustring.gsub(s, "^%s*(.-)%s*$", "%1")
	if mw.ustring.find(s, '^[#*:;]') or mw.ustring.find(s, '^{|') then
		return '\n' .. s
	else
		return s
	end
end
Finds whether a sidebar has a subgroup sidebar.
local function hasSubgroup(s)
	if mw.ustring.find(s, cfg.i18n.pattern.subgroup) then
		return true
	else
		return false
	end
end
local function has_navbar(navbar_mode, sidebar_name)
	return navbar_mode ~= cfg.i18n.navbar_none and
		navbar_mode ~= cfg.i18n.navbar_off and
			sidebar_name or
			mw.getCurrentFrame():getParent():getTitle():gsub(cfg.i18n.pattern.sandbox, '') ~=
			cfg.i18n.title_not_to_add_navbar
end
local function has_list_class(args, htmlclass)
	local patterns = {
		'^' .. htmlclass .. '$',
		'%s' .. htmlclass .. '$',
		'^' .. htmlclass .. '%s',
		'%s' .. htmlclass .. '%s'
	for arg, value in pairs(args) do
		if type(arg) == 'string' and mw.ustring.find(arg, 'class') then
			for _, pattern in ipairs(patterns) do
				if mw.ustring.find(args[arg] or '', pattern) then
					return true
				end
			end
		end
	end
	return false
end
-- there are a lot of list classes in the wild, so we add their TemplateStyles
local function add_list_styles(args)
	local function add_list_templatestyles(htmlclass, templatestyles)
		if has_list_class(args, htmlclass) then
			return frame:extensionTag{
				name = 'templatestyles', args = { src = templatestyles }
		else
			return ''
		end
	end
	local plainlist_styles = add_list_templatestyles('plainlist', cfg.i18n.plainlist_templatestyles)
	local hlist_styles = add_list_templatestyles('hlist', cfg.i18n.hlist_templatestyles)
	-- a second workaround for [[phab:T303378]]
	-- when that issue is fixed, we can actually use has_navbar not to emit the
	-- tag here if we want
	if has_navbar(args.navbar, args.name) and hlist_styles == '' then
		hlist_styles = frame:extensionTag{
			name = 'templatestyles', args = { src = cfg.i18n.hlist_templatestyles}
	end
	-- hlist -> plainlist is best-effort to preserve old Common.css ordering. [hlist_note]
	return hlist_styles .. plainlist_styles
end
-- work around [[phab:T303378]]
-- for each arg: find all the templatestyles strip markers, insert them into a
-- table. then remove all templatestyles markers from the arg
local function move_hiding_templatestyles(args)
	local gfind = string.gfind
	local gsub = string.gsub
	local templatestyles_markers = {}
	local strip_marker_pattern = '(\127[^\127]*UNIQ%-%-templatestyles%-%x+%-QINU[^\127]*\127)'
	for k, arg in pairs(args) do
		for marker in gfind(arg, strip_marker_pattern) do
			table.insert(templatestyles_markers, marker)
		end
		args[k] = gsub(arg, strip_marker_pattern, '')
	end
	return templatestyles_markers
end
Main sidebar function. Takes the frame, args, and an optional collapsibleClass.
The collapsibleClass is and should be used only for sidebars with collapsible
lists, as in p.collapsible.
function p.sidebar(frame, args, collapsibleClass)
	if not args then
		args = getArgs(frame)
	end
	local hiding_templatestyles = table.concat(move_hiding_templatestyles(args))
	local root = mw.html.create()
	local child = args.child and mw.text.trim(args.child) == cfg.i18n.child_yes
	root = root:tag('table')
	if not child then
		root
			:addClass(cfg.i18n.class.sidebar)
			-- force collapsibleclass to be sidebar-collapse otherwise output nothing
			:addClass(collapsibleClass == cfg.i18n.class.collapse and cfg.i18n.class.collapse or nil)
			:addClass('nomobile')
			:addClass(args.float == cfg.i18n.float_none and cfg.i18n.class.float_none or nil)
			:addClass(args.float == cfg.i18n.float_left and cfg.i18n.class.float_left or nil)
			:addClass(args.wraplinks ~= cfg.i18n.wrap_true and cfg.i18n.class.wraplinks or nil)
			:addClass(args.bodyclass or args.class)
			:css('width', args.width or nil)
			:cssText(args.bodystyle or args.style)
		if args.outertitle then
			root
				:tag('caption')
					:addClass(cfg.i18n.class.outer_title)
					:addClass(args.outertitleclass)
					:cssText(args.outertitlestyle)
					:wikitext(args.outertitle)
		end
		if args.topimage then
			local imageCell = root:tag('tr'):tag('td')
			imageCell
				:addClass(cfg.i18n.class.top_image)
				:addClass(args.topimageclass)
				:cssText(args.topimagestyle)
				:wikitext(args.topimage)
			if args.topcaption then
				imageCell
					:tag('div')
						:addClass(cfg.i18n.class.top_caption)
						:cssText(args.topcaptionstyle)
						:wikitext(args.topcaption)
			end
		end
		if args.pretitle then
			root
				:tag('tr')
					:tag('td')
						:addClass(args.topimage and cfg.i18n.class.pretitle_with_top_image
							or cfg.i18n.class.pretitle)
						:addClass(args.pretitleclass)
						:cssText(args.basestyle)
						:cssText(args.pretitlestyle)
						:wikitext(args.pretitle)
		end
	else
		root
			:addClass(cfg.i18n.class.subgroup)
	end
	if args.title then
		if child then
			root
				:wikitext(args.title)
		else
			root
				:tag('tr')
					:tag('th')
						:addClass(args.pretitle and cfg.i18n.class.title_with_pretitle
							or cfg.i18n.class.title)
						:addClass(args.titleclass)
						:cssText(args.titlestyle)
		end
	end
	if args.image then
		imageCell
			:addClass(cfg.i18n.class.image)
			:addClass(args.imageclass)
			:cssText(args.imagestyle)
			:wikitext(args.image)
		if args.caption then
			imageCell
				:tag('div')
					:addClass(cfg.i18n.class.caption)
					:cssText(args.captionstyle)
					:wikitext(args.caption)
		end
	end
	if args.above then
		root
			:tag('tr')
				:tag('td')
					:addClass(cfg.i18n.class.above)
					:addClass(args.aboveclass)
					:cssText(args.abovestyle)
					:newline() -- newline required for bullet-points to work
					:wikitext(args.above)
	end
	local rowNums = {}
	for k, v in pairs(args) do
		k = '' .. k
		local num = k:match('^heading(%d+)$') or k:match('^content(%d+)$')
		if num then table.insert(rowNums, tonumber(num)) end
	end
	table.sort(rowNums)
	-- remove duplicates from the list (e.g. 3 will be duplicated if both heading3
	-- and content3 are specified)
	for i = #rowNums, 1, -1 do
		if rowNums[i] == rowNums[i - 1] then
			table.remove(rowNums, i)
		end
	end
	for i, num in ipairs(rowNums) do
		local heading = args['heading' .. num]
		if heading then
			root
				:tag('tr')
					:tag('th')
						:addClass(cfg.i18n.class.heading)
						:addClass(args.headingclass)
						:addClass(args['heading' .. num .. 'class'])
						:cssText(args.headingstyle)
						:cssText(args['heading' .. num .. 'style'])
						:newline()
						:wikitext(heading)
		end
		local content = args['content' .. num]
		if content then
			root
				:tag('tr')
					:tag('td')
						:addClass(hasSubgroup(content) and cfg.i18n.class.content_with_subgroup
							or cfg.i18n.class.content)
						:addClass(args.contentclass)
						:addClass(args['content' .. num .. 'class'])
						:cssText(args.contentstyle)
						:cssText(args['content' .. num .. 'style'])
						:newline()
						:wikitext(content)
						:done()
					 -- Without a linebreak after the </td>, a nested list like
					 -- "* {{hlist| ...}}" doesn't parse correctly.
					:newline()
		end
	end
	if args.below then
		root
			:tag('tr')
				:tag('td')
					:addClass(cfg.i18n.class.below)
					:addClass(args.belowclass)
					:cssText(args.belowstyle)
					:newline()
					:wikitext(args.below)
	end
	if not child and has_navbar(args.navbar, args.name) then
		root
			:tag('tr')
				:tag('td')
					:addClass(cfg.i18n.class.navbar)
					:cssText(args.navbarstyle)
					:wikitext(require('Module:Navbar')._navbar{
						args.name,
						mini = 1,
						fontstyle = args.navbarfontstyle
	end
	local base_templatestyles = frame:extensionTag{
		name = 'templatestyles', args = { src = cfg.i18n.templatestyles }
	local templatestyles = ''
	if args['templatestyles'] and args['templatestyles'] ~= '' then
			name = 'templatestyles', args = { src = args['templatestyles'] }
	end
	local child_templatestyles = ''
	if args['child templatestyles'] and args['child templatestyles'] ~= '' then
		child_templatestyles = frame:extensionTag{
			name = 'templatestyles', args = { src = args['child templatestyles'] }
	end
	local grandchild_templatestyles = ''
	if args['grandchild templatestyles'] and args['grandchild templatestyles'] ~= '' then
		grandchild_templatestyles = frame:extensionTag{
			name = 'templatestyles', args = { src = args['grandchild templatestyles'] }
	end
	return table.concat({
		add_list_styles(args), -- see [hlist_note] above about ordering
		base_templatestyles,
		templatestyles,
		child_templatestyles,
		grandchild_templatestyles,
		hiding_templatestyles,
		tostring(root),
		(child and cfg.i18n.category.child or ''),
end
local function list_title(args, is_centered_list_titles, num)
	local title_text = trimAndAddAutomaticNewline(args['list' .. num .. 'title']
		or cfg.i18n.default_list_title)
	local title
	if is_centered_list_titles then
		-- collapsible can be finicky, so provide some CSS/HTML to support
		title = mw.html.create('div')
			:addClass(cfg.i18n.class.list_title_centered)
			:wikitext(title_text)
	else
		title = mw.html.create()
	end
	local title_container = mw.html.create('div')
		:addClass(cfg.i18n.class.list_title)
		-- don't /need/ a listnumtitleclass because you can do
		-- .templateclass .listnumclass .sidebar-list-title
		:addClass(args.listtitleclass)
		:cssText(args.listtitlestyle)
		:cssText('color: var(--color-base)')
		:cssText(args['list' .. num .. 'titlestyle'])
		:node(title)
		:done()
	return title_container
end
Main entry point for sidebar with collapsible lists.
Does the work of creating the collapsible lists themselves and including them
into the args.
function p.collapsible(frame)
	local args = getArgs(frame)
	if not args.name and
		frame:getParent():getTitle():gsub(cfg.i18n.pattern.collapse_sandbox, '') ==
		cfg.i18n.collapse_title_not_to_add_navbar then
		args.navbar = cfg.i18n.navbar_none
	end
	local contentArgs = {}
	local is_centered_list_titles = false
	if args['centered list titles'] and args['centered list titles'] ~= '' then
		is_centered_list_titles = true
	end
		local num = string.match(k, '^list(%d+)$')
		if num then
			local expand = args.expanded and
				(args.expanded == 'all' or args.expanded == args['list' .. num .. 'name'])
			local row = mw.html.create('div')
			row
				:addClass(cfg.i18n.class.list)
				:addClass('mw-collapsible')
				:addClass((not expand) and 'mw-collapsed' or nil)
				:addClass(args['list' .. num .. 'class'])
				:cssText(args.listframestyle)
				:cssText(args['list' .. num .. 'framestyle'])
				:node(list_title(args, is_centered_list_titles, num))
				:tag('div')
					:addClass(cfg.i18n.class.list_content)
					:addClass('mw-collapsible-content')
					-- don't /need/ a listnumstyleclass because you can do
					-- .templatename .listnumclass .sidebar-list
					:addClass(args.listclass)
					:cssText(args.liststyle)
					:cssText(args['list' .. num .. 'style'])
					:wikitext(trimAndAddAutomaticNewline(args['list' .. num]))
			contentArgs['content' .. num] = tostring(row)
		end
	end
	for k, v in pairs(contentArgs) do
		args[k] = v
	end
	return p.sidebar(frame, args, cfg.i18n.class.collapse)
end
return p
