Apple Express Modem Documentation
Revision as of 13:41, 4 October 2026 by Josh (talk | contribs) (List the GeoPort page among pages citing these documents)
Two Apple user documents cover the Apple Express Modem.
Express Fax/Modem User's Guide (1994)
The Express Fax/Modem User's Guide is Apple's 1994 manual for the Express Modem and its Express Fax software, part number 030-5409-B, 172 printed pages plus front matter (185 PDF pages). It is written for both the PowerBook and the communications slot versions of the modem.
Contents
Contents (printed page numbers)
Part Pages Covers
Preface ix-xi How to use the book; FCC and DOC information
Chapter 1, Introducing the Express Modem 1-10 Package contents, analog line requirement, modem design, Express Modem and Express Fax software and features, connecting the Macintosh, installing the software
Chapter 2, Using Your Modem 11-20 Setting up a connection, speed, error control, data compression, reaching another modem
Chapter 3, Express Fax Quick Start 21-32 Fax Quick Send; receiving a first fax
Chapter 4, Getting the Most Out of Your Express Fax 33-68 Fax Sender, Fax Phone Book, Fax Terminal, Fax Log, receiving
Chapter 5, Fax Viewer 69-80 Viewing, editing, printing and forwarding faxes
Chapter 6, Fax Cover 81-95 Designing and installing cover pages
Appendix A, Technical Information 97-109 Express Modem control panel, Communications Toolbox, call management, software specifications
Appendix B, Modem Command Set 111-136 AT commands, S registers, result codes, MNP commands, ASCII table
Appendix C, Tips and Troubleshooting 137-152 Checking the installation and the line, common problems, messages and alerts, older modems, AppleTalk Remote Access and AppleLink set-up
Glossary and index 153-172
The guide is a user manual. It has no hardware description, take-apart or parts list, and its "Hardware specifications" section (p. 109) says only that the modem is compatible with the computer.
Download: Apple Express Fax-Modem User's Guide (1994).pdf
Apple Macintosh Express Fax/Modem Installation Guide (1994)
The Apple Macintosh Express Fax/Modem Installation Guide, part number 030-5806-A (1994), is an 8-page leaflet for the communications slot card. It covers the box contents, system requirements (System 7 or later, 4 MB of RAM recommended), fitting the card and connecting the telephone line, and a five-point hardware troubleshooting checklist. It has a drawing of the card but no electrical detail.
Download: Apple Macintosh Express Fax-Modem Installation Guide (1994).pdf
Pages that cite these documents
