Sega Mega Drive / Genesis (Model 2)
Revision as of 15:18, 27 April 2025 by Josh (talk | contribs) (Created page with "{{Infobox computer | name = Sega Genesis Model 2<br />(Mega Drive II) | image = 260px | caption = European PAL Mega Drive II (VA1) – bundled with ''Sonic 2'' | manufacturer = Sega Enterprises Ltd. | type = 16-bit home video-game console | release date = {{Start date|1993|04|23}} (JP)<br />{{Start date|1993|10}} (US)<br />{{Start date|1993|10}} (EU) | discontinued =...")
(Mega Drive II)
European PAL Mega Drive II (VA1) – bundled with Sonic 2'
ManufacturerSega Enterprises Ltd.
Type16-bit home video-game console
ReleasedApril 23, 1993 (JP)
October 1, 1993 (US)
October 1, 1993 (EU)
Discontinued1998 (superseded by Genesis 3 & licensed clones)
Intro priceJP ¥12 800 • US US$99 • EU £99
CPUMotorola MC68000 @ 7.67 MHz (NTSC) / 7.61 MHz (PAL)
Memory64 KB 68k WRAM • 64 KB VRAM • 8 KB Z80 RAM • 128 B colour/VSRAM
StorageROM cartridges ≤ 4 MB (40 Mbit†) • Sega CD & 32X add-ons†
Display
SoundASIC YM3438-core 6-ch FM + DAC
TI SN76489 PSG
Left/right line-mix to AV multi-out
Dimensions220 mm W × 210 mm D × 55 mm H
Weight≈ 700 g (VA1 board + shielding)
OS / FirmwareMinimal TMSS ROM v2.x (8 KB, inside ASIC)
PredecessorSega Genesis (Model 1)
SuccessorSega Genesis (Model 3)
CodenameTakatoku / “Mark VI” compact
Model no.HAA-N0 (JP) • MK-1631 (US) • MK-1631-50 (EU)
The Sega Genesis Model 2 – sold outside North America as the Mega Drive II – is the first major redesign of Sega’s 16-bit console. Introduced in 1993, it condenses the original two-board architecture into a single cost-reduced PCB that integrates more logic into the 315-5660 “M5” ASIC, deletes the headphone amplifier, and replaces the large 8-pin DIN with a mini-DIN-9 A/V port.
📜 Historical Context
  • Development began mid-1992 to cut manufacturing cost (fewer PCBs, chassis tooling shared with Model 2 Sega CD).
  • Launched 23 April 1993 in Japan bundled with *Sonic CD* coupons; reached U.S./EU retail in October 1993 at a launch price of US $99 (console + Sonic 2).
  • Model 2 rapidly replaced remaining Model 1 inventory and remained Sega’s primary 16-bit SKU until 1998.
  • Total Genesis/Mega Drive family sales surpassed 30 million units worldwide; ~40 % are estimated to be Model 2 boards (VA0-VA4, Majesco VA7/GOAC).
🧠 Hardware Architecture
Integrated ICs (VA1 reference)
ASIC Functions Combined
315-5660 “M5” VDP core • YM3438 FM synth • PSG • I/O (pads, TMSS) • Bus arbiter
315-5684 RGB DAC • stereo mixer • master clock PLL • TV encoder controls
External silicon 68000 CPU • Z80 CPU • 64 KB SRAM × 2 (VRAM) • 64 KB SRAM (WRAM) • ROM & IO glue
What Changed vs. Model 1?
  • Removal of discrete YM2612; FM engine now inside ASIC (= YM3438 core) → slightly cleaner FM but different DAC ladder, causing famous “tinny” Model 2 audio.
  • Mini-DIN-9 A/V with C-sync no longer routed; composite chroma/luma fed from the encoder inside 315-5684.
  • On-board RCA RF modulator omitted – external RF switch box used in NTSC territories.
  • TMSS boot ROM updated to v2.00 (“Produced by or under license…”) / “Sega v2.00 1993”.
  • 32X compatibility assured: side expansion edge identical to Model 1 (though PCB cut-out shifted 2 mm on VA0).
System Clocking (NTSC)
  • Master crystal: 53.693 MHz → /7 = 7.670 MHz (68k), /15 = 3.579 MHz (Z80).
  • Pixel clock: 53.693 MHz / 1 → VDP; colour sub-carrier generated internally by 315-5684.
Memory Map (abridged)
Address Size Device
$000000-$3FFFFF ≤ 4 MB Cartridge ROM
$A00000-$A0FFFF 64 KB Z80 bus window
$A10000-$A10FFF 4 KB I/O, TMSS, version register
$C00000-$C0003F 64 B VDP data & control
$FF0000-$FFFFFF 64 KB 68k Work-RAM (batteryless)
🔌 External Connectors
Mini-DIN 9 A/V (console female, front-view)
Pin Signal Notes
1 +5 V (75 mA) RGB SCART auto-switch
2 Audio right 1 Vpp line-level
3 Composite video 1 Vpp, 75 Ω
4 Audio left
5 Ground signal ground
6 Y (luma) For S-Video on rare VA3-S boards (unused)
7 C (chroma) – ″ –
8 Blue (0.7 Vpp) RGB direct from DAC
9 Red (0.7 Vpp)
  • Green shares composite video on model-2 harness.
  • CSYNC no longer present—mods tap VDP pin 11.
🖥️ Motherboard Revisions
Model 2 VA Boards
Rev GPU/Audio Core Notes Audio Quality
VA0 YM3438 + discrete pre-amp Early JP only; poor S-video traces Mild hiss
VA1 YM3438 inside 315-5660 Global; “M5” silkscreen Noticeable PWM noise
VA2 Same ASIC; cheaper DAC Wide RF shield removed Slightly darker
VA3-S Adds 315-5684-A encoder Provides true S-Video in Asia PAL Best stock audio
VA4 Majesco/AtGames GOAC “315-6123” (everything on one chip) Muddy, hissy
Errata: VA1 consoles can exhibit “rainbow jail-bars” due to shared RGB line impedance; mitigated by installing 470 Ω series resistors or full Triple-Bypass mod.
🔊 Audio Path
File:Genesis2 Audio Block.svg
Simplified audio chain
1. YM3438 DAC (inside ASIC) → 2. passive RC low-pass → 3. 315-5684 mixer → 4. Sony CXA1645 (NTSC) or MB3514 (PAL) video encoder → 5. mini-DIN audio pins. No headphone amp, therefore no PWM scaling knob; DC bias ~1.3 V, so improper cable coupling causes “mono bleed” on some TVs.
🪛 Servicing & Maintenance
  • Capacitors – fewer electrolytics; critical audio rails: C68 (47 µF/16 V), C41 (22 µF), C9 (10 µF 315-5684).
  • DC jack – fragile centre pin; desolder & replace with Kycon KLDX-2.5A for loose-power issues.
  • Fuse – surface-mount 1 A polyfuse PF1; easy to open-circuit after PSU spikes.
  • AV port strain – mini-DIN anchors only by solder; re-flow cracked pads on units with heavy SCART cables.
Comprehensive procedures: see Sega Genesis (Model 2) General Maintenance Guide and Sega Genesis (Model 2) Capacitor Replacement Guide.
🐞 Troubleshooting Cheatsheet
Fault Likely Cause Remedy
No video / green LED PSU MK-1631 failing (9 V sag) Use 9 V DC 1 A centre-barrel replacement
Video ok, silence 315-5684 audio caps dried Replace C68, C69; check mini-DIN pin 2/4 continuity
Jail-bar vertical stripes Poor VDP RGB drive Install Triple-Bypass or series resistors R30-R32 = 470 Ω
32X “error 04” EXT port dirty Alcohol scrub edge; check /RESET from CN-E
  • Rapid-fire switch (JP2) – solder toggle to TH input via 74HC04.
  • Region + 50/60 Hz – wire JP3/JP4 to 3-way slide; TMSS bios auto-selects RGB palette accordingly.
  • RGB Bypass / Triple-Bypass – PCBs by RetroRGB, Voultar: taps raw VDP RGB & YM3438, yields crystal-clear output.
  • Mega Amp v2 – dedicated discrete op-amp board recreates Model 1 headphone mix.
  • MiSTer Analogue IO – Model 2 shell often re-purposed as FPGA console.
📚 Technical Resources
  • *Mega Drive II Service Manual* (Sega, 1993) – schematics VA1 & VA2.
PDF links available at Sega Technical Documentation.
🗞️ Trivia
  • Early Model 2 NTSC boards left “GAMES = TOYS?” text in ROM v2.00; never displayed.
  • Bundles: Sonic 2 (“Not For Resale”) cart in U.S.; The Lion King in PAL territories (1994).
  • Brazilian licensee Tec Toy produced a turquoise “Mega Drive 3” reuse of Model 2 VA3 until 2007.
🔗 See Also
