Sega Mega Drive / Genesis (Model 1)
Revision as of 15:32, 27 April 2025 by Josh (talk | contribs) (Josh moved page Sega Mega Drive (Model 1) to Sega Mega Drive / Genesis (Model 1): Misspelled title)
The Sega Mega Drive—released as the Sega Genesis in North America—is a 16-bit fourth-generation console that propelled Sega into direct competition with Nintendo’s Super Famicom/SNES. Its Motorola 68000 CPU and sophisticated Yamaha FM audio gave arcade-like performance at home, while aggressive “Genesis does what Nintendon’t” marketing helped drive ≈ 30 million units sold worldwide.
Sega Mega Drive – Model 1
First-generation (“High Definition Graphics – Stereo Sound”) Mega Drive released in Japan & Europe
Type16-bit home video-game console
Released29 October 1988 (JP)
14 August 1989 (NA – as Genesis)
30 November 1990 (EU)
DiscontinuedApril 1997 (worldwide)
Intro priceJP ¥21 000 • US US$189 (1989) • UK £189.99 (1990)
CPUMotorola 68000 @ 7.67 MHz[1]
Zilog Z80 @ 3.58 MHz (audio & Master-System compatibility)
Memory64 KB 16-bit Work RAM • 64 KB VRAM • 8 KB Z80 RAM
StorageROM cartridges (up to 4 MB officially; larger with bank-switch)
CD-ROM via Sega CD (Model 1) add-on
Display320 × 224 px (256 × 224, 320 × 240 & 256 × 240 modes) • 64 colours onscreen from 512-colour palette • 80 sprites
SoundYamaha YM2612 6-ch FM + SN76489 PSG 4-ch + 8-bit PCM (via 68000 DMA)
Dimensions280 mm W × 210 mm D × 70 mm H
Weight1.2 kg
OS / FirmwareNone (game cartridge provides code)
PredecessorMaster System II
SuccessorSega Saturn
CodenameMK-1601 (HAA-2510 PCB)
Model no.“VA0–VA6” motherboard revisions
🧠 Architecture & Dual-CPU Design
Sub-system Specification (Model 1 VA4, NTSC)
Main CPU Motorola 68000 @ 7.67 MHz (16/24-bit CISC, 68010-class core)
Sound CPU / 8-bit legacy Zilog Z80 @ 3.579 MHz – controls PSG & streams PCM to YM2612 DAC
Also hosts complete Master-System I/O for backward compatibility (cartridge mode pin M3)
VDP Sega Custom YM7101 (315-5313) – derive from Yamaha V9938: 2 scrolling BG planes + window + 80 sprites, 64 colours onscreen
Audio Yamaha YM2612 (OPN2) 6-ch FM + integrated 8-bit DAC (channel 6)
Texas Instruments SN76489 PSG (3 tone + noise) clocked from 3.58 MHz ÷ 16
RAM 2 × 32 KB 16-bit DRAM (Work RAM)
2 × 32 KB VRAM (dual-ported) 8 KB static RAM for Z80
ROM space Up to 4 MB linear; larger games (Virtua Racing, 6 MB) use mapper ASIC
DMA 68000→VDP HSYNC DMA (13.4 MB/s burst) and VRAM copy modes
💾 Memory Map (NTSC, no add-ons)
Mega Drive Model 1 Address Space (68000)
Range Size Purpose
000000–3FFFFF 4 MB Cartridge ROM / SRAM
400000–7FFFFF Mirrors / future mapper
A00000–A0FFFF 64 KB Z80 address space (via bus request)
A10000–A1001F 32 B I/O ports: controller, version, TMSS
A11100 1 B Bus-grant register (68k⇄Z80)
A11200 1 B Z80 reset
C00000–C0001F 32 B VDP registers
C00000–C0FFFF 64 KB VRAM (through VDP)
C00020–C0003F 32 B PSG, YM2612, CRTC HV counter
FF0000–FFFFFF 64 KB System RAM (work RAM)
Key ROM vectors: 000004 initial SSP, 000006 initial PC (game entry), TMSS “SEGA” string check at 000100 on later VA6(+).
📺 Video Timing
Mode Pixel clock Pixels/line Lines/frame Refresh
NTSC 320-wide 10.738 MHz 342 active / 427 total 262 59.922 Hz
PAL 320-wide 10.054 MHz 342 / 427 312 49.701 Hz
  • The VDP fetches one 16-bit VRAM word every 4 cycles; HSYNC width ≈ 84 master clocks.*
🔌 Edge Connector (64-pin Cartridge Slot)
A1 GND Ground B1 +5 V
A2 A23 Address bus 23 B2 A22
A3 A21 B3 A20
A30 M3 Low = Master-System mode B30 /CART_INH Pull low to disable ROM (CD/32X)
A32 /OE 16-bit ROM output enable B32 /WE (SRAM)
🛠️ Model 1 Motherboard Revisions
Key Mega Drive VA-board Changes
Rev (JP) ASIC Notable characteristics
VA0 (launch, 1988) 315-5211 VDP Rare; discrete RGB amp, noisier audio
VA2–VA4 (1989) 315-5313 VDP Adds low-pass in audio, fixes VDP register 1 bug
VA5 (1991) 315-5476 combined I/O ˜1 dB louder YM2612 DAC, TMSS “LOCK-ON”
VA6 (1992) same TMSS mandatory; “Licensed by Sega” BIOS check
VA4 & later drop the “EXT PORT” text on the front but keep the 9-pin SUB-D connector. Revision affects RGB quality and capacitor layout—see the dedicated maintenance guide for board-specific recap lists.
🔉 Audio Path
68000 DMA → YM2612 FM → mixed with PSG → pre-emphasis RC filter → Sony CXA1034 op-amp → headphone amp & rear AV-out.
  • Early VA0/VA1 units suffer the well-known “Mega-Drive whistle.”* Installing 470 µF / 100 µF low-ESR caps and moving the audio return after the regulators mitigates it (documented in the Mega Drive AV Output Guide).
🕰️ Historical Context & Sales
  • Conceived under codename “Mark V” to supersede the 8-bit Master System using Sega’s System-16 arcade silicon.
  • Japanese uptake was modest (≈ 400 k units by 1990) until Sonic the Hedgehog (1991) exploded sales.
  • North America (Genesis): > 18 million; Europe/Middle East: > 8 million; Brazil (Tectoy): 3 million+.
  • Sixth-year production cost with VA6 board < US$50, leading to sub-£100 “Mega Drive II” bundles in 1995.
⚠️ Common Faults & Preventive Maintenance
  • Electrolytic capacitor leakage around CXA1034 (audio) and power rails (5 V, -12 V op-amp). See Mega Drive Capacitor Replacement Guide.
  • No video / jailbars – cracked solder on AV DIN, VDP or RAM ICs.
  • RESET line stuck low – faulty MC14069 (Hex Schmitt inverter) on VA0-VA3.
  • Z80 bus contention causes garbled FM – reseat / clean edge cartridge & check 315-5410 ASIC.
  • Full troubleshooting flow-chart on Mega Drive Troubleshooting Guide.
🎮 Expansion & I/O
  • Cartridge slot 64-pin edge (mapped @ 0–4 MB)
  • EXT PORT 9-pin mini-DIN (unused by most games; utilised by Sega CD side-bus)
  • AV Out 8-pin mini-DIN (RGB 0.7 Vpp, composite, mono audio)
  • Controller ports 2× DE-9 (compatible with Atari/VCS & MS pads)
  • Add-ons: Sega Mega-CD (CD-ROM storage, additional 12.5 MHz 68000 & PCM) and Sega 32X (2× Hitachi SH-2 @ 23 MHz, 32-colour cell-based renderer)
🎬 Trivia & Pop-culture
  • Early Japanese units proudly display “High Definition Graphics • Stereo Sound” silk-screen; later cost-reduced versions removed the legend though hardware remained identical.
  • The console appears (model-accurate) in the 2020 film Sonic the Hedgehog—complete with a VA3 style headphone volume wheel.
  • An undocumented VDP test pattern can be triggered by holding A+B+C+START on power-up with no cartridge inserted (development boards only).
Further reading / guides
  1. NTSC master clock 53.693175 MHz ÷7.
