Revision as of 23:29, 13 January 2025 by Infobox computer>Jonesey95(Use block indent instead of misused definition list markup to resolve obscure Linter syntax error at a few pages including Template:Country data Congo. Ideally, this should not change the rendered output (it appears to make the h= text maybe one pixel closer to the text above it, which I hope is OK).)
This page is a redirect. The following categories are used to track and monitor this redirect:
Manifold sort: If help is needed to determine appropriate categories, then this redirect populates Category:Miscellaneous redirects. Monitors of that category will check this redirect and add or remove rcats as needed.
When appropriate, protection levels are automatically sensed, described and categorized.
