Sega Mega Drive / Genesis (Model 1) Capacitor Replacement Guide
Recapping a Sega Mega Drive / Genesis Model 1 is essential for preserving sound, video quality, and long-term reliability. Ageing electrolytic capacitors are a leading cause of audio distortion, video artefacts, power instability, and outright failure. Proactive replacement ensures your console performs as intended for years to come.
๐Ÿ” Visual Inspection & Failure Signs
Before beginning, carefully examine the board for:
  • Bulging or domed capacitor tops โ€“ Indicates internal pressure and imminent failure.
  • Leaking electrolyte โ€“ Brown or white residue around capacitor bases, especially near the audio and power sections.
  • Corrosion or PCB staining โ€“ Green or darkened areas signal leakage and possible trace damage.
  • Audio hum or distortion โ€“ Often tracks to failed audio-path capacitors.
  • Video interference or instability โ€“ Vertical lines, colour bleed, or sync loss may result from dried-out video supply capacitors.
  • Power issues โ€“ Random resets, failure to power on, or hot voltage regulators can be caused by high-ESR capacitors.
If any capacitor shows signs of failure, it is strongly recommended to replace all electrolytic capacitors on the board.
๐Ÿ“‹ Mega Drive / Genesis Model 1 Capacitor List
There are several Model 1 board revisions (VA0โ€“VA7), but capacitor values are largely consistent. Always cross-check your silkscreen and values before ordering replacements.
๐Ÿ–ฅ๏ธ Mainboard Electrolytic Capacitors
Sega Mega Drive / Genesis Model 1 Mainboard Capacitors
Ref Capacitance Voltage Quantity Circuit / Notes
C1 2200 ยตF 16 V 1x Main 5 V rail filter (power input)
C2 1000 ยตF 16 V 1x Secondary 5 V filter (regulator output)
C3, C4, C5, C6, C7, C8, C9, C10 10 ยตF 16 V 8x General decoupling (logic, video, audio)
C11, C12, C13, C14, C15 47 ยตF 16 V 5x Audio path, op-amp coupling, video amp
C16, C17 1 ยตF 50 V 2x Video output coupling (composite/chroma)
C18, C19 100 ยตF 16 V 2x Audio output filter, op-amp supply
C20 470 ยตF 16 V 1x 9 V rail filter (if fitted)
C21, C22 22 ยตF 16 V 2x Reset circuit, sub-audio
Some VA3โ€“VA7 revisions may have minor differences or additional small-value capacitors. Always verify against your board.
๐Ÿ’พ RF Modulator / Sub-Board Capacitors (if present)
RF Modulator Capacitors
Ref Capacitance Voltage Quantity Notes
C101 100 ยตF 16 V 1x 5 V filter
C102 10 ยตF 16 V 1x Video coupling
If you have removed or bypassed the RF modulator for composite/S-video mods, these may be omitted.
๐Ÿ› ๏ธ Recapping Procedure
  1. Disassemble the console: Remove all screws from the case bottom and carefully separate the halves. Unplug the power LED, controller ports, and any sub-boards.
  2. Remove the mainboard: Take out all mounting screws and gently lift the PCB from the shell.
  3. Document capacitor locations: Photograph or label each capacitor before removal, noting polarity and orientation.
  4. Desolder capacitors: Use a temperature-controlled iron (350โ€“375 ยฐC) and solder-wick or pump. Mega Drive boards are robust but avoid excessive heat to prevent pad lift.
  5. Clean the area: Remove old flux and any leaked electrolyte with isopropyl alcohol and a nylon brush.
  6. Install new capacitors: Match polarity (long lead = positive) and observe correct lead spacing (usually 5 mm). Use low-ESR, 105 ยฐC rated parts.
  7. Inspect your work: Check for solder bridges, correct orientation, and solid joints.
  8. Reassemble and test: Refit the board, reconnect all cables, and test the system before fully closing the case.
  • Temperature-controlled soldering iron (60โ€“70 W, 2 mm chisel tip)
  • Desoldering pump and solder-wick
  • Isopropyl alcohol (IPA) and nylon brush
  • 105 ยฐC, low-ESR radial electrolytic capacitors (Nichicon PW/PS, Panasonic FR/FC, Rubycon ZLH)
  • Multimeter (for continuity and voltage checks)
  • ESR meter (optional, for in-circuit capacitor testing)
  • Kapton tape (to insulate tall capacitors near shielding)
  • Protective eyewear
โš™๏ธ Post-Recap Voltage & Ripple Checks
After recapping, verify power rails at key points (with cartridge slot empty and no controller connected):
Expected Voltages โ€“ Sega Mega Drive / Genesis Model 1
Main 5 V rail (IC pin, e.g. 68000 pin 14) 4.95 โ€“ 5.10 V < 50 mV
Audio amp supply (op-amp Vcc) 4.8 โ€“ 5.1 V < 50 mV
9 V rail (if fitted, e.g. VA0/VA1) 8.5 โ€“ 9.5 V < 100 mV
Video output (composite pin, unloaded) 1.0 โ€“ 1.2 V (p-p) Clean, no hum
A persistent hum, buzz, or video artefacts after recapping may indicate a faulty voltage regulator or poor solder joint.
๐Ÿ’ก Additional Tips
  • Check the power supply first: An out-of-spec PSU can damage new capacitors and the console.
  • Use quality capacitors: Avoid generic brands; low-ESR, 105 ยฐC parts are essential for audio and power rails.
  • Observe polarity: Electrolytic capacitors are polarisedโ€”incorrect fitting can cause immediate failure.
  • Clean thoroughly: Remove all residue from leaked electrolyte, which is corrosive and conductive.
  • Retain original values: Do not increase capacitance significantly, especially in audio/video paths, as it may affect frequency response.
  • Re-seat connectors and chips: Disassembly may disturb edge connectors or socketed ICsโ€”reseat if issues persist.
  • Dispose of old capacitors properly: Take to an approved electronics recycling centre.
