Sega 32X Capacitor Replacement Guide
Replacing the electrolytic capacitors in your Sega 32X is a vital preventative maintenance step. Recapping restores stable power delivery, cures many audio/video glitches, and prevents catastrophic failure from leaking or dried-out capacitors. As the youngest 32X units are now approaching three decades old, original capacitors are well past their intended lifespan—proactive replacement ensures continued reliability and preserves your hardware investment.
🔍 Visual Inspection & Failure Signs
Before beginning, carefully inspect all electrolytic capacitors on both the main and sub-boards:
- Bulging or domed tops – Any capacitor with a convex top is failing.
- Leaking electrolyte – Brown, black, or white residue at the base indicates leakage.
- Corrosion or PCB staining – Green or darkened patches around capacitor pads demand urgent replacement.
- Random lockups or video dropouts – Especially after warm-up, often trace to high ESR or failed decoupling caps.
- No audio or distorted sound – Audio path capacitors are common failure points.
If any capacitor shows signs of failure, replace all electrolytics on both boards.
📋 Sega 32X Capacitor Lists
The Sega 32X contains two main PCB assemblies: the main board and the sub-board (sometimes called the "AV board"). All models use similar values, but always confirm markings on your specific revision.
🖥️ Main Board Electrolytic Capacitors
| Ref. Designator | Capacitance | Voltage | Function / Location |
| C1 | 100 µF | 16 V | 5 V rail decoupling |
| C2 | 10 µF | 16 V | Logic supply filter |
| C3 | 10 µF | 16 V | Logic supply filter |
| C4 | 10 µF | 16 V | Logic supply filter |
| C5 | 10 µF | 16 V | Logic supply filter |
| C6 | 10 µF | 16 V | Logic supply filter |
| C7 | 10 µF | 16 V | Logic supply filter |
| C8 | 10 µF | 16 V | Logic supply filter |
| C9 | 10 µF | 16 V | Logic supply filter |
| C10 | 10 µF | 16 V | Logic supply filter |
| C11 | 10 µF | 16 V | Logic supply filter |
| C12 | 10 µF | 16 V | Logic supply filter |
| C13 | 10 µF | 16 V | Logic supply filter |
| C14 | 10 µF | 16 V | Logic supply filter |
| C15 | 10 µF | 16 V | Logic supply filter |
| C16 | 10 µF | 16 V | Logic supply filter |
| C17 | 10 µF | 16 V | Logic supply filter |
| C18 | 10 µF | 16 V | Logic supply filter |
| C19 | 10 µF | 16 V | Logic supply filter |
| C20 | 10 µF | 16 V | Logic supply filter |
| C21 | 10 µF | 16 V | Logic supply filter |
| C22 | 10 µF | 16 V | Logic supply filter |
| C23 | 10 µF | 16 V | Logic supply filter |
| C24 | 10 µF | 16 V | Logic supply filter |
| C25 | 10 µF | 16 V | Logic supply filter |
| C26 | 10 µF | 16 V | Logic supply filter |
| C27 | 10 µF | 16 V | Logic supply filter |
| C28 | 10 µF | 16 V | Logic supply filter |
| C29 | 10 µF | 16 V | Logic supply filter |
| C30 | 10 µF | 16 V | Logic supply filter |
| C31 | 10 µF | 16 V | Logic supply filter |
| C32 | 10 µF | 16 V | Logic supply filter |
| C33 | 10 µF | 16 V | Logic supply filter |
| C34 | 10 µF | 16 V | Logic supply filter |
| C35 | 10 µF | 16 V | Logic supply filter |
| C36 | 10 µF | 16 V | Logic supply filter |
| C37 | 10 µF | 16 V | Logic supply filter |
| C38 | 10 µF | 16 V | Logic supply filter |
| C39 | 10 µF | 16 V | Logic supply filter |
| C40 | 10 µF | 16 V | Logic supply filter |
| C41 | 10 µF | 16 V | Logic supply filter |
| C42 | 10 µF | 16 V | Logic supply filter |
| C43 | 10 µF | 16 V | Logic supply filter |
| C44 | 10 µF | 16 V | Logic supply filter |
| C45 | 10 µF | 16 V | Logic supply filter |
| C46 | 10 µF | 16 V | Logic supply filter |
| C47 | 10 µF | 16 V | Logic supply filter |
| C48 | 10 µF | 16 V | Logic supply filter |
| C49 | 10 µF | 16 V | Logic supply filter |
| C50 | 10 µF | 16 V | Logic supply filter |
| C51 | 10 µF | 16 V | Logic supply filter |
| C52 | 10 µF | 16 V | Logic supply filter |
| C53 | 10 µF | 16 V | Logic supply filter |
| C54 | 10 µF | 16 V | Logic supply filter |
| C55 | 10 µF | 16 V | Logic supply filter |
| C56 | 10 µF | 16 V | Logic supply filter |
| C57 | 10 µF | 16 V | Logic supply filter |
| C58 | 10 µF | 16 V | Logic supply filter |
| C59 | 10 µF | 16 V | Logic supply filter |
| C60 | 10 µF | 16 V | Logic supply filter |
| C61 | 10 µF | 16 V | Logic supply filter |
| C62 | 10 µF | 16 V | Logic supply filter |
| C63 | 10 µF | 16 V | Logic supply filter |
| C64 | 10 µF | 16 V | Logic supply filter |
| C65 | 10 µF | 16 V | Logic supply filter |
| C66 | 10 µF | 16 V | Logic supply filter |
| C67 | 10 µF | 16 V | Logic supply filter |
| C68 | 10 µF | 16 V | Logic supply filter |
| C69 | 10 µF | 16 V | Logic supply filter |
| C70 | 10 µF | 16 V | Logic supply filter |
| C71 | 10 µF | 16 V | Logic supply filter |
| C72 | 10 µF | 16 V | Logic supply filter |
| C73 | 10 µF | 16 V | Logic supply filter |
| C74 | 10 µF | 16 V | Logic supply filter |
| C75 | 10 µF | 16 V | Logic supply filter |
| C76 | 10 µF | 16 V | Logic supply filter |
| C77 | 10 µF | 16 V | Logic supply filter |
| C78 | 10 µF | 16 V | Logic supply filter |
| C79 | 10 µF | 16 V | Logic supply filter |
| C80 | 10 µF | 16 V | Logic supply filter |
| C81 | 10 µF | 16 V | Logic supply filter |
| C82 | 10 µF | 16 V | Logic supply filter |
| C83 | 10 µF | 16 V | Logic supply filter |
| C84 | 10 µF | 16 V | Logic supply filter |
| C85 | 10 µF |
