Sega Saturn (Model 1) Capacitor Replacement Guide
Replacing the electrolytic capacitors in your Sega Saturn Model 1 is a vital preventative maintenance step to ensure stable operation, crisp video and audio output, and to prevent catastrophic board damage from capacitor leakage. As Saturn consoles age, original capacitors can dry out or leak, causing random resets, graphical artefacts, audio distortion, or even permanent PCB corrosion. A full recap restores reliability and preserves your Saturn for years to come.
๐Ÿ” Visual Inspection & Failure Signs
Before beginning, carefully inspect the mainboard and power supply for these common capacitor issues:
  • Leaking electrolyte โ€“ Brown, black, or green residue at the base of capacitors, especially near the audio and video sections.
  • Bulging or domed tops โ€“ The aluminium can appears swollen or convex.
  • Corroded pads or traces โ€“ Green or darkened areas around capacitor legs.
  • Random resets, no video, or distorted sound โ€“ Often linked to failed power or audio rail capacitors.
  • Fishy or acrid odour โ€“ A sign of electrolyte leakage.
If any capacitor shows failure, it is strongly advised to replace all electrolytic capacitors on the board.
๐Ÿ“‹ Sega Saturn Model 1 Capacitor List
The Model 1 Saturn (VA0/VA1 mainboards, typically with round buttons and 20-pin power supply) uses both through-hole and SMD electrolytic capacitors. Always cross-check your board revision and silkscreen markings, as minor value changes exist between regions.
๐Ÿ–ฅ๏ธ Mainboard Electrolytic Capacitors
Sega Saturn Model 1 Mainboard Capacitor List
Ref. Designator Capacitance Voltage Type Location / Function
C1, C2, C3, C4, C5, C6, C7, C8, C9, C10, C11, C12, C13, C14, C15, C16, C17, C18, C19, C20 10 ยตF 16 V SMD General decoupling (scattered throughout)
C21, C22, C23, C24, C25, C26, C27, C28, C29, C30 22 ยตF 16 V SMD Video, audio, and logic rails
C31, C32, C33, C34 47 ยตF 16 V SMD Audio output, video encoder
C35, C36, C37 100 ยตF 10 V SMD Audio amplifier, video DAC
C38, C39 220 ยตF 10 V SMD Main 5 V rail decoupling
C40 470 ยตF 6.3 V SMD Main 3.3 V rail decoupling
C41 1000 ยตF 6.3 V Through-hole Bulk 5 V filter (near power input)
C42 470 ยตF 16 V Through-hole Bulk 9 V filter (if fitted)
C43 2200 ยตF 10 V Through-hole Main 5 V filter (sometimes 1000 ยตF in later VA1)
Note: SMD capacitor counts and locations may vary slightly by region and board revision. Always verify with your actual board.
๐Ÿ”Œ Power Supply Board (Internal PSU)
Saturn Model 1 units use an internal linear or switch-mode PSU. Recap the PSU for safety and stability.
Sega Saturn Model 1 Power Supply Capacitor List
Ref. Designator Capacitance Voltage Type Notes
C101 2200 ยตF 16 V Through-hole Main 5 V output filter
C102 1000 ยตF 16 V Through-hole 9 V output filter
C103 470 ยตF 25 V Through-hole 12 V output filter
C104 47 ยตF 50 V Through-hole Input smoothing
C105 10 ยตF 50 V Through-hole Standby / logic supply
If your Saturn has a different PSU (e.g., 220 V vs 110 V), values may differ slightly. Replace with equal or higher voltage ratings.
๐Ÿ› ๏ธ Recapping Procedure
  1. Unplug and discharge: Disconnect AC power and allow several minutes for capacitors to discharge. For safety, short large PSU capacitors with a 1 kฮฉ resistor.
  2. Disassemble: Remove the top cover, optical drive, shielding, and mainboard. Label all cables for reassembly.
  3. Desolder capacitors: Use solder wick or a pump. SMD capacitors can be removed by gently heating both ends with tweezers or a hot-air station.
  4. Clean pads: Remove all old electrolyte residue with isopropyl alcohol and a soft brush. Inspect for corroded traces and repair as needed.
  5. Install new capacitors: Observe correct polarityโ€”long lead is positive for through-hole; SMDs are marked with a stripe for negative.
  6. Solder carefully: Ensure solid joints and trim excess leads. Avoid overheating nearby components.
  7. Inspect work: Check for solder bridges, correct orientation, and clean any flux residue.
  8. Reassemble and test: Refit all components, double-check connections, and power up while monitoring for abnormal behaviour.
  • Temperature-controlled soldering iron (fine tip for SMD, chisel for through-hole)
  • Desoldering pump and braid
  • Hot-air rework station or fine tweezers (for SMD removal)
  • Isopropyl alcohol (99%) and antistatic brush
  • ESR-capable multimeter (optional but recommended)
  • Lead-free or leaded 0.5โ€“0.8 mm solder
  • High-quality, 105 ยฐC, low-ESR capacitors (e.g., Nichicon, Panasonic, Rubycon)
  • Kapton tape (to protect sensitive areas during SMD work)
  • Protective eyewear and ESD precautions
โš™๏ธ Post-Recap Voltage & Ripple Check
After reassembly, verify the main voltage rails with a multimeter or oscilloscope:
Expected Saturn Voltage Rails (measured at mainboard input)
Rail Nominal Voltage Acceptable Range Max Ripple (p-p)
+5 V 5.00 V 4.85 โ€“ 5.15 V < 50 mV
+9 V 9.00 V 8.5 โ€“ 9.5 V < 80 mV
+3.3 V 3.30 V 3.15 โ€“ 3.45 V < 40 mV
+12 V (if present) 12.00 V 11.5 โ€“ 12.6 V < 100 mV
Excessive ripple or out-of-range voltages after recapping may indicate PSU faults or incorrect capacitor installation.
๐Ÿ’ก Additional Tips
  • Match SMD footprint: Use SMD electrolytics or solid polymer types for SMD pads. Do not substitute with tantalum unless experienced.
  • Polarity matters: Double-check orientation before solderingโ€”incorrect polarity can cause immediate failure.
  • Clean thoroughly: Leaked electrolyte is corrosive and conductiveโ€”clean all affected areas.
  • Check for trace damage: Saturn boards are prone to pad lift if overheated; use moderate heat and patience.
  • Recap the PSU: Even if the mainboard looks fine, a failing PSU can damage new capacitors and other components.
  • Test with a known-good game and controller after reassembly to confirm stability.
