Macintosh 128K/512K Capacitor Replacement Guide
Replacing electrolytic capacitors (recapping) in your Macintosh 128K and 512K is essential for long-term reliability. Over time, capacitors degrade, leading to voltage instability, display artifacts, and system failure. **Proactively replacing these components ensures continued functionality and prevents potential board damage.**
Capacitor Inspection
Before replacing capacitors, it is essential to **inspect them** for signs of deterioration. The most common failure symptoms include:
- "Bulging Tops" – A capacitor should have a flat top. If swollen or domed, it is failing.
- "Leaking Electrolyte" – A brownish or white crust around capacitor leads indicates electrolyte leakage.
- "Corrosion" – PCB discoloration or corrosion around capacitor bases suggests imminent failure.
If **any of these symptoms** are present, replacement is highly recommended.
Macintosh 128K/512K Capacitor List
The **Macintosh 128K and 512K analog board** contains numerous capacitors that should be replaced proactively. Below is the verified list of capacitor specifications:
| Label | Stock Capacitance | Stock Voltage | Quantity |
| C1 | 3.9µF | 35V | 1x |
| C2 | 4700µF | 16V | 1x |
| C3 | 220µF | 16V | 2x |
| C5 | 47µF | 10V | 1x |
| C6 | 22µF | 50V | 2x |
| C10 | 33µF | 16V | 2x |
| C11 | 10µF | 160V | 1x |
| C12 | 22µF | 50V | 2x |
| C18 | 33µF | 16V | 2x |
| C24 | 2200µF | 16V | 4x |
| C27 | 2200µF | 16V | 1x |
| C28 | 1000µF | 16V | 1x |
| C30 | 2200µF | 16V | 1x |
| C31 | 220µF | 16V | 1x |
| C32 | 2200µF | 16V | 1x |
| C33 | 4700pF | 250V | 2x |
| C34 | 100µF | 200V | 4x |
| C35 | 100µF | 200V | 1x |
| C36 | 4700pF | 250V | 1x |
| C37 | 0.47µF | 250V | 1x |
| C38 | 100µF | 200V | 1x |
| C39 | 100µF | 200V | 1x |
| C42 | 470µF | 10V | 2x |
| C45 | 470µF | 10V | 1x |
Proper capacitor replacement requires **careful handling and the right tools**. Follow these steps:
- "CRT Safety" – Fully discharge the CRT before servicing to avoid dangerous high-voltage shocks.
- "Disassembly" – Remove the analog board, noting all connector placements.
- "Desoldering" – Use a solder sucker or desoldering braid to **remove old capacitors** without damaging PCB traces.
- "Replacement" – Install new capacitors with correct polarity (**observe the + and - markings**).
- "Soldering" – Solder new capacitors securely and **trim excess lead length**.
- "Inspection" – Ensure all solder joints are **clean and well-adhered**.
- "Final Check" – Use a multimeter to verify **no shorts between power rails** before powering on.
Recommended Tools
To perform a **successful capacitor replacement**, the following tools are recommended:
- "Soldering iron" – Temperature-controlled, fine-tip soldering iron.
- "Desoldering pump or braid" – For safe removal of capacitors.
- "Multimeter" – For verifying voltage levels.
- "Anti-static brush and isopropyl alcohol" – To clean PCB areas before and after work.
- "Safety glasses and insulated gloves" – **CRT servicing involves high voltage**, always use protection.
Voltage Adjustment Post-Recap
After recapping, **voltages should be verified and adjusted** to ensure long-term stability. Measure the power rails using a **multimeter** at the floppy drive connector or logic board harness.
- "+5V Line" – Should measure **4.85V – 5.15V**
- "+12V Line" – Should measure **11.9V – 12.7V**
If voltages are **out of range**, adjust using the **trimmer potentiometer (R56)** on the analog board.
Additional Tips
- "Turn on the Macintosh 128K/512K periodically" to prevent capacitors from drying out.
- "Replace capacitors in batches" to ensure even aging if full recapping is not possible.
- "Dispose of old capacitors properly" at an **electronics recycling center**.
For **further maintenance and troubleshooting**, refer to the Macintosh 128K/512K Troubleshooting Guide.
