Osborne Vixen Troubleshooting Guide
Revision as of 18:51, 11 May 2025 by Josh (talk | contribs) (Automated update by bot)
This guide provides systematic troubleshooting for the Osborne Vixen portable computer. As one of the last CP/M luggables, the Vixenโ€™s reliability depends on healthy power, video, disk, and logic subsystems. This page details common failure symptoms, diagnostic steps, and component-level remedies.
๐Ÿ”Œ Preliminary & Power-up Checks
Begin by confirming the Vixenโ€™s power supply and startup sequence, as many issues stem from simple electrical faults.
Visual & Basic Checks
  • Remove the case top and inspect for burnt components, corrosion, or leaking capacitors.
  • Check for loose or oxidised connectors, especially at the power input and disk drives.
  • Ensure all ribbon cables are firmly seated.
Power Supply & Voltage Checks
Mainboard +5V rail +5.0 V DC (ยฑ5%) Logic supplyโ€”measure at RAM/CPU Vcc pins
Mainboard +12V rail +12 V DC (ยฑ10%) Disk drives, CRT, some logic
CRT board +12 V DC, +180 V DC For video and CRT anode (observe safety)
Floppy drive connector +5 V / +12 V DC Both rails required for operation
  • If voltages are low or missing, check the internal fuses and PSU output.
  • Inspect for cracked solder joints at the power jack and switch.
Power-up Symptoms Table
Symptom Likely Cause Action
No lights, no fan, no CRT glow Blown fuse, dead PSU, broken switch Test/replace fuse, check switch continuity, recap PSU
Fan runs, CRT dark, no beeps CRT supply failure, video board fault Check CRT voltages, inspect video board components
Power LED on, no disk activity Logic board not running, CPU/RAM fault Proceed to logic-level checks, test CPU reset/clock
๐Ÿ–ฅ๏ธ Display & Chime Diagnostics
The Osborne Vixen has a built-in monochrome CRT. Video faults are common and often easy to localise.
CRT & Video Faults
Symptom Probable Cause Remedy
CRT glows, but no text or border Video signal missing, logic board not running Check CPU, ROM, RAM, and video output ICs
Horizontal line only Vertical deflection failure Inspect/replace vertical output IC, check for cold joints
Vertical line only Horizontal deflection failure Check horizontal driver transistor, flyback transformer
Dim or flickering display Ageing CRT, weak PSU, bad capacitors Adjust brightness, recap video board, check PSU
Garbled or missing characters Video RAM or character ROM fault Test/replace video RAM/ROM, reseat socketed chips
Diagnostic Steps
  1. Observe CRT at power-on: does it glow, display raster, or show garbage?
  2. Listen for relay click or faint high-voltage whine (indicates CRT HV present).
  3. Adjust brightness/contrastโ€”if raster appears, logic board is likely at fault.
  4. If no glow, test CRT heater voltage and inspect video board for failed parts.
๐Ÿฅ Floppy Disk & Storage Subsystem Failures
The Vixen uses standard 5.25" double-density drives. Disk faults are frequent due to drive age and connector issues.
Disk System Fault Table
"BOOT ERROR" or no boot from disk Bad disk, dirty heads, drive failure Clean heads, try known-good disk, check drive power
Drive spins but no access Ribbon cable loose, controller fault Reseat cables, test controller ICs (e.g. WD1793)
"NO DISK" or "DISK ERROR" messages Faulty drive select logic, bad ROM Check drive select jumpers, test/replace ROM
Disk not ejected Mechanical jam, failed eject solenoid Inspect/repair drive mechanism
Floppy Drive Diagnostic Steps
  1. Try booting from a known-good CP/M disk.
  2. Listen for drive spin-up and head movement.
  3. Swap drive ribbon cables; if problem moves, suspect drive.
  4. If both drives fail, check disk controller IC (WD1793 or equivalent) and associated logic.
๐Ÿ’พ Memory & ROM Faults
RAM and ROM failures are a leading cause of "dead" or unstable Vixens.
Memory/ROM Fault Table
Symptom Probable Cause Action
Blank screen, no beep RAM or ROM failure, CPU not running Test/replace RAM (4164/41256), check ROM sockets
Random characters, system crashes Marginal RAM, bad address/data bus Swap RAM chips, logic probe bus lines
Consistent boot errors Corrupt ROM, socket corrosion Reseat/replace ROMs, clean sockets
RAM/ROM Diagnostic Steps
  1. Power off, remove and reseat all socketed RAM and ROM chips.
  2. If available, substitute with known-good chips.
  3. Use logic probe to check for activity on address/data lines.
  4. If possible, run a RAM test utility from disk.
โš ๏ธ Connector & Socket Issues
Ageing sockets and connectors are a frequent source of intermittent faults.
  • Inspect all IC sockets for corrosion or loosenessโ€”reseat or replace as needed.
  • Clean edge connectors (keyboard, disk, CRT) with isopropyl alcohol.
  • Check for cracked solder joints at the power, video, and disk connectors.
๐Ÿ”ฉ Component-level Tests
Clock & Reset Circuitry
  • Confirm CPU clock (typically 4 MHz) with an oscilloscope or logic probe.
  • Check RESET line: should pulse low on power-up, then go high.
  • If CPU is not running, check reset capacitor and associated logic (e.g., 555 timer or discrete components).
Voltage Test Points
Location Expected Voltage Notes
CPU Vcc pin +5 V DC Main logic supply
Floppy drive connector +5 V, +12 V DC Both required for operation
CRT board anode +180 V DC High voltageโ€”use caution!
Logic IC Substitution
  • Swap socketed logic chips (74LS, 4000 series) one at a time with known-good parts.
  • For soldered ICs, piggy-back a good chip to test for improvement (not for MOS/ROMs).
๐Ÿ”Š Audio & I/O Failures
The Vixen has a simple beeper for sound and serial/parallel ports for I/O.
Audio Faults
  • No beep at power-on: check beeper, drive transistor, and CPU port output.
  • Replace beeper or transistor if silent.
I/O Port Issues
  • Serial/parallel ports dead: check for broken traces, failed driver ICs (e.g., 1488/1489).
  • Inspect port solder joints and connector pins for damage.
