Osborne Vixen Troubleshooting Guide
This guide provides systematic troubleshooting for the Osborne Vixen portable computer. As one of the last CP/M luggables, the Vixen’s reliability depends on healthy power, video, disk, and logic subsystems. This page details common failure symptoms, diagnostic steps, and component-level remedies.
🔌 Preliminary & Power-up Checks
Begin by confirming the Vixen’s power supply and startup sequence, as many issues stem from simple electrical faults.
Visual & Basic Checks
- Remove the case top and inspect for burnt components, corrosion, or leaking capacitors.
- Check for loose or oxidised connectors, especially at the power input and disk drives.
- Ensure all ribbon cables are firmly seated.
Power Supply & Voltage Checks
| Test Point | Expected Voltage | Notes |
| Mainboard +5V rail | +5.0 V DC (±5%) | Logic supply—measure at RAM/CPU Vcc pins |
| Mainboard +12V rail | +12 V DC (±10%) | Disk drives, CRT, some logic |
| CRT board | +12 V DC, +180 V DC | For video and CRT anode (observe safety) |
| Floppy drive connector | +5 V / +12 V DC | Both rails required for operation |
- If voltages are low or missing, check the internal fuses and PSU output.
- Inspect for cracked solder joints at the power jack and switch.
Power-up Symptoms Table
| No lights, no fan, no CRT glow | Blown fuse, dead PSU, broken switch | Test/replace fuse, check switch continuity, recap PSU |
| Fan runs, CRT dark, no beeps | CRT supply failure, video board fault | Check CRT voltages, inspect video board components |
| Power LED on, no disk activity | Logic board not running, CPU/RAM fault | Proceed to logic-level checks, test CPU reset/clock |
🖥️ Display & Chime Diagnostics
The Osborne Vixen has a built-in monochrome CRT. Video faults are common and often easy to localise.
CRT & Video Faults
| Symptom | Probable Cause | Remedy |
| CRT glows, but no text or border | Video signal missing, logic board not running | Check CPU, ROM, RAM, and video output ICs |
| Horizontal line only | Vertical deflection failure | Inspect/replace vertical output IC, check for cold joints |
| Vertical line only | Horizontal deflection failure | Check horizontal driver transistor, flyback transformer |
| Dim or flickering display | Ageing CRT, weak PSU, bad capacitors | Adjust brightness, recap video board, check PSU |
| Garbled or missing characters | Video RAM or character ROM fault | Test/replace video RAM/ROM, reseat socketed chips |
Diagnostic Steps
- Observe CRT at power-on: does it glow, display raster, or show garbage?
- Listen for relay click or faint high-voltage whine (indicates CRT HV present).
- Adjust brightness/contrast—if raster appears, logic board is likely at fault.
- If no glow, test CRT heater voltage and inspect video board for failed parts.
🥏 Floppy Disk & Storage Subsystem Failures
The Vixen uses standard 5.25" double-density drives. Disk faults are frequent due to drive age and connector issues.
Disk System Fault Table
| "BOOT ERROR" or no boot from disk | Bad disk, dirty heads, drive failure | Clean heads, try known-good disk, check drive power |
| Drive spins but no access | Ribbon cable loose, controller fault | Reseat cables, test controller ICs (e.g. WD1793) |
| "NO DISK" or "DISK ERROR" messages | Faulty drive select logic, bad ROM | Check drive select jumpers, test/replace ROM |
| Disk not ejected | Mechanical jam, failed eject solenoid | Inspect/repair drive mechanism |
Floppy Drive Diagnostic Steps
- Try booting from a known-good CP/M disk.
- Listen for drive spin-up and head movement.
- Swap drive ribbon cables; if problem moves, suspect drive.
- If both drives fail, check disk controller IC (WD1793 or equivalent) and associated logic.
💾 Memory & ROM Faults
RAM and ROM failures are a leading cause of "dead" or unstable Vixens.
Memory/ROM Fault Table
| Symptom | Probable Cause | Action |
| Blank screen, no beep | RAM or ROM failure, CPU not running | Test/replace RAM (4164/41256), check ROM sockets |
| Random characters, system crashes | Marginal RAM, bad address/data bus | Swap RAM chips, logic probe bus lines |
| Consistent boot errors | Corrupt ROM, socket corrosion | Reseat/replace ROMs, clean sockets |
RAM/ROM Diagnostic Steps
- Power off, remove and reseat all socketed RAM and ROM chips.
- If available, substitute with known-good chips.
- Use logic probe to check for activity on address/data lines.
- If possible, run a RAM test utility from disk.
⚠️ Connector & Socket Issues
Ageing sockets and connectors are a frequent source of intermittent faults.
- Inspect all IC sockets for corrosion or looseness—reseat or replace as needed.
- Clean edge connectors (keyboard, disk, CRT) with isopropyl alcohol.
- Check for cracked solder joints at the power, video, and disk connectors.
🔩 Component-level Tests
Clock & Reset Circuitry
- Confirm CPU clock (typically 4 MHz) with an oscilloscope or logic probe.
- Check RESET line: should pulse low on power-up, then go high.
- If CPU is not running, check reset capacitor and associated logic (e.g., 555 timer or discrete components).
Voltage Test Points
| Location | Expected Voltage | Notes |
| CPU Vcc pin | +5 V DC | Main logic supply |
| Floppy drive connector | +5 V, +12 V DC | Both required for operation |
| CRT board anode | +180 V DC | High voltage—use caution! |
Logic IC Substitution
- Swap socketed logic chips (74LS, 4000 series) one at a time with known-good parts.
- For soldered ICs, piggy-back a good chip to test for improvement (not for MOS/ROMs).
🔊 Audio & I/O Failures
The Vixen has a simple beeper for sound and serial/parallel ports for I/O.
Audio Faults
- No beep at power-on: check beeper, drive transistor, and CPU port output.
- Replace beeper or transistor if silent.
I/O Port Issues
- Serial/parallel ports dead: check for broken traces, failed driver ICs (e.g., 1488/1489).
- Inspect port solder joints and connector pins for damage.
