Osborne Executive Capacitor Replacement Guide
Recapping the Osborne Executive is essential for ensuring reliable operation, clean power delivery, and long-term preservation of this classic portable CP/M computer. The original electrolytic capacitors, now over forty years old, are prone to drying out, leaking, or failing, which can cause erratic behaviour, power issues, and even damage to rare custom ICs. Proactive replacement of all electrolytic capacitors is strongly recommended for any Executive in regular use or on display.
๐ Visual Inspection & Failure Signs
Before beginning, examine the Osborne Executiveโs boards for these common capacitor failure indicators:
- Bulging or domed cans โ especially on the power supply and mainboard filter capacitors.
- Leaking electrolyte โ brown, green, or white crust at the base of capacitors or on the PCB.
- Corrosion or PCB staining โ discolouration or green residue around capacitor leads.
- Unstable operation โ random resets, video distortion, or disk errors may be traced to failing capacitors.
If any single capacitor shows signs of failure, it is best practice to replace all electrolytic capacitors in the system.
๐ Osborne Executive Capacitor Lists
The Osborne Executive consists of three main assemblies requiring recapping: the power supply, the main logic board, and the CRT video board. Always cross-check values with your specific revision, as some parts may differ between early and late units.
๐ Power Supply Board
| Ref. Designator | Capacitance | Voltage | Notes |
| C1 | 220 ยตF | 250 V | Mains filter (high voltage, safety rated) |
| C2 | 10 ยตF | 50 V | Start-up (bootstrap) |
| C3 | 2200 ยตF | 25 V | +12 V output filter |
| C4 | 2200 ยตF | 16 V | +5 V output filter |
| C5 | 470 ยตF | 25 V | +12 V secondary filter |
| C6 | 470 ยตF | 16 V | +5 V secondary filter |
| C7 | 1 ยตF | 50 V | Control circuit decoupling |
| C8 | 1 ยตF | 50 V | Control circuit decoupling |
Note: Some power supply revisions may use 3300 ยตF for C3/C4. Always match the installed value or consult the silkscreen.
๐ฅ๏ธ Main Logic Board
| Ref. Designator | Capacitance | Voltage | Function |
| C101 | 10 ยตF | 16 V | Reset timing |
| C102, C103, C104, C105 | 1 ยตF | 50 V | Local decoupling (various ICs) |
| C106, C107 | 22 ยตF | 16 V | Audio and video path coupling |
| C108 | 100 ยตF | 16 V | Bulk decoupling |
| C109 | 47 ยตF | 16 V | Floppy interface filter |
| C110, C111, C112 | 10 ยตF | 16 V | Miscellaneous decoupling |
SMD electrolytics are not present on original Osborne Executive boards; all are through-hole types.
๐ต CRT Video Board
| VC1 | 10 ยตF | 160 V | Vertical deflection coupling |
| VC2, VC3 | 22 ยตF | 50 V | Video signal coupling |
| VC4 | 100 ยตF | 16 V | Video output filter |
| VC5 | 1 ยตF | 50 V | Sync decoupling |
Always verify capacitor polarity on the CRT boardโincorrect installation may cause display failure or damage.
๐ ๏ธ Recapping Procedure
- Unplug and discharge: Disconnect the Executive from mains power. Discharge the CRT (see CRT Discharge Procedure) and power supply filter capacitors before working.
- Disassemble: Remove the rear case screws, gently lift the top cover, and disconnect the keyboard and CRT cables.
- Remove boards: Unscrew and carefully extract the power supply, mainboard, and CRT board as needed.
- Desolder capacitors: Use solder wick or a pump. Take care not to lift padsโOsborne PCBs are robust but can be damaged by excessive heat.
- Install replacements: Fit new capacitors, matching polarity and lead spacing. Use 105 ยฐC, low-ESR types for all replacements.
- Clean up: Remove flux residue with IPA and inspect for solder bridges or cold joints.
- Reassemble and test: Refit all boards, reconnect cables, and power up. Monitor for any unusual sounds, smells, or behaviour.
๐งฐ Recommended Tools & Parts
- Temperature-controlled soldering iron (60โ80 W, 2 mm chisel tip)
- Desoldering pump and solder wick
- Multimeter (with continuity and ESR test if possible)
- Isopropyl alcohol (IPA) and antistatic brush
- High-quality 105 ยฐC, low-ESR radial electrolytic capacitors (e.g., Nichicon PW/PS, Panasonic FR/FC, Rubycon YXF/ZLH)
- Kapton tape for insulating capacitors near metal shields
- Protective eyewear and insulated gloves
โ๏ธ Post-Recap Voltage & Ripple Checks
After recapping, verify key voltage rails at the mainboard edge connector or test points:
| Rail | Expected Voltage | Max Ripple (p-p) |
| +5 V | 4.90 โ 5.10 V | < 50 mV |
| +12 V | 11.8 โ 12.5 V | < 100 mV |
| -12 V | -11.5 โ -12.5 V | < 100 mV |
Excessive ripple or out-of-range voltages after recapping may indicate a failing regulator or transformer. Shut down immediately if voltages are abnormal.
๐ก Extra Tips
- Replace all electrolytics at once โ partial recaps are not recommended due to similar ageing across all parts.
- Check for PCB damage โ clean up any leaked electrolyte thoroughly, as it can corrode traces.
- Use correct voltage ratings โ never install a capacitor rated for lower voltage than the original.
- Observe polarity carefully โ especially on the CRT and power supply boards.
- Store and operate in a dry environment โ moisture accelerates capacitor ageing.
- Power up gently โ use a variac or current-limited bench supply for the first power-on after recapping.
