Sega CD (Model 2)
Revision as of 10:11, 12 May 2025 by Josh (talk | contribs)
Sega CD Model 2
(Mega-CD 2)
U.S. NTSC Sega CD (Model 2) side-mounted beneath a Genesis 2
ManufacturerSega Enterprises Ltd.
TypeCD-ROM add-on console
ReleasedApril 23, 1993 (JP Mega-CD 2)
November 1, 1993 (US Sega CD 2)
May 1, 1994 (EU Mega-CD 2)
Discontinued1996 (replaced by licensed JVC WonderMega 2 & CD X)
Intro priceJP ¥29 800 • US US$229 • EU £230
CPUMotorola MC68EC000 @ 12.500 MHz (main)
Sony CXD1802Q custom gate-array (CD-DSP) †
Memory512 KB Program RAM
768 KB dual-ported Word-RAM
128 KB PCM Sample RAM
64 KB Battery-backed Save RAM
Storage1× 1 ×-speed top-loading CD-ROM (150 kB s⁻¹)
cartridge passthrough up to 4 MB
Display256 / 320 × 224 px (NTSC) • 52-colour line-scroll • 80 sprites
SoundGenesis YM3438 FM & PSG plus Ricoh RF5C164 8-ch PCM @ 32 kHz 10-bit DAC
Dimensions252 mm W × 215 mm D × 63 mm H
Weight≈ 1.3 kg
OS / FirmwareMega-CD System BIOS v2.x (128 KB mask ROM)
PredecessorSega CD (Model 1)
SuccessorSega CDX / JVC Wondermega
CodenameMARS-CD-B (JP R&D) • “Top-loader”
Model no.HAA-2950 (JP) • MK-4102 (US) • MK-4102-50 (EU)
The Sega CD Model 2 – known in Japan and PAL regions as the Mega-CD 2 – is the second-generation optical add-on for the Sega Genesis/Mega Drive. Launched April 1993 in Japan and late-1993 overseas, it re-engineers the bulky front-loading Model 1 into a smaller, top-loading deck that bolts to the right-hand side of a Model-2 Genesis (or underneath a Model-1 via spacer plate). The redesign slashes build cost by integrating disc-logic, FM synth mix, and RF modulator into two new ASICs and by replacing the complex motorised tray with a spring-latched lid.
Historical Context & Sales
  • Sega’s first CD drive – the Model 1 “front-loader” (HAA-2910) – cost US$299 and carried a high RMA rate (optical alignment, belt stretch).
  • Cost-reduction taskforce (“MCD-R2”) produced a simplified mechanism using Sony’s ubiquitous KSS-210A pickup and a plastic clam-shell housing.
  • Debuted 23 April 1993 bundled with Sonic CD in Japan; U.S. release November 1993 bundled with Sewer Shark.
  • Combined Model-1/2 worldwide sales ≈ 2.24 million units – ~70 % are Model 2 according to 1995 Sega annual report.
Hardware Architecture
Major ICs (VA0 main-board)
Part Function(s)
MC68EC000 (64-pin) Primary 16-bit CPU @ 12.5 MHz
315-5880 “MCD ASIC 2” Sub-CPU bus arbiter • Word-RAM controller • rotation / scaling / 3×3 matrix
315-5788 OKI MSM6295-compatible DMA + CD-SUB code ROM
Ricoh RF5C164 8-channel PCM generator, 10-bit DAC
CXD2510Q CD-DSP / decoder – replaces discrete CN-303 & CXP controllers in Model 1
315-5684-B RGB DAC + stereo mixer (shares with Genesis 2)
Internally, software sees identical registers to Model 1; all games and dev tools remain compatible.
Clock Scheme (NTSC)
  • Master XTAL = 12.500 MHz × 4 = 50.000 MHz → ÷4 = 12.5 MHz (68k)
  • Z80 (in Genesis) still sourced from 53.693 MHz ÷15 ≈ 3.58 MHz
  • Word-RAM dual-ported clock = 25 MHz.
Memory Map (MC68EC000)
Sega CD Model 2 Physical Address Space
Range Size Device
$0000 00–$0FFF FF 1 MB Program RAM
$0200 00–$03FF FF 2 MB Word-RAM (dual-bank 0/1)
$0400 00–$05FF FF 2 MB PRG-RAM mirror / save RAM (battery)
$0600 00–$07FF FF 2 MB PCM sample RAM mirror
$0800 00–$0BFF FF 4 MB BIOS ROM (128 KB mirrored)
$0C00 00–$0DFF FF 2 MB CD-DSP & sub-CPU registers
$0E00 00–$0E00 FF 256 B Gate array I/O (gate, LEDs, reset)
Differences vs. Model 1
Area Model 1 (1991) Model 2 (1993) Result
Drive mech Sony KSS-240A sled + worm gear front-tray Sony KSS-210A fixed sled, top-lid 40 % cheaper, quieter
Optical control CXP921P + CXD1095Q (DSP) CXD2510Q SoC Fewer PCB layers
Audio mixing External op-amps, RCA output Mixed inside 315-5684-B, no RCA Shares Genesis 2 mini-DIN
Power rails 9 V in → 5 V, –5 V, +12 V regulators –5 V rail deleted (unused) One less 7905 IC
Word-RAM width 2 × 16-bit SRAM (dual bus) Same, but SRAMs integrated in ASIC later VA1 Slightly lower latency
External Connectors
  • Expansion edge – identical 64-pin BUS as Model 1; ships with 10 cm ribbon “mixing” cable to the Genesis 2 A/V port (carries left/right audio).
  • AC Adaptor – same barrel 2.1 mm as Genesis 2 (centre positive).
  • EXT Link – 9-pin mini-DIN to daisy-chain two Mega-CDs for dev use (never utilised by retail titles).
Motherboard Revisions
Mega-CD 2 Main-Boards
Rev Key ICs Notes
VA0 315-5880, CXD2510Q, discrete SDRAM Japan launch – green soldermask
VA1 315-5933 “ASIC 3” (RAM+gate array in one) Most common US/EU; no Word-RAM wait glitches
VA2 (Majesco) GOAC single-chip + Mitsubishi drive board Pack-in with late Genesis 3; cost-reduced
All revisions are cross-compatible; BIOS ROM changes (v2.00→v2.11) fix Lunar Eternal Blue save bug and 32X pass-through timing.
Audio Path
1. RF5C164 PCM → 315-5880 bus → 2. ASIC mixer combines FM+PSG from Genesis via ribbon audio BUS → 3. 315-5684-B internal op-amp → mini-DIN 9 (pins 2/4) / RCA L+R (PAL only). Because mixing is line-level only, Model 2 inherits Genesis 2’s famous “quiet” output (~300 mVpp). Mods: VMU Audio Amp or “Sega CD Audio Boost” board (TL072).
Maintenance
  • Pickup lens – KSS-210A rarely fails; clean with 91 % IPA swab.
  • Spindle hub – plastic hub cracks; 3-D-print “clamp hub saver” or cannibalise PC CD-ROM.
  • Lid switch – dual leaf SW1; adjust if unit reports “Please Close Cover” error.
  • Belt – Model 2 has *no belt*, only a direct-drive spindle.
  • Capacitors – far fewer SMD cans: primarily C224 220 µF (5 V rail) and audio coupling 47 µF (C138, C139). See Sega CD (Model 2) Capacitor Replacement Guide.
Common Faults & Fixes
Symptom Diagnosis Remedy
“Checking disc” endless Spindle hub height / dirty lens Clean lens; shim hub 0.2 mm
No PCM channels RF5C164 pin-rot on VA0 Re-flow QFP; recap C139/C140
BIOS boots, drive dead 5 V present, 9 V missing at CN3 Replace poly-fuse PF1 or AC adaptor
32X hangs on Sega CD ASIC revision < v2.11 Burn patch cart with “32X-SCD fix”
  • RGB Bypass via Triple-Bypass board (VDP → THS7374 → DIN 9).
  • Region Free BIOS – swap 27C1001 EPROM with patched Mega CD Multi-BIOS v2.8.
  • Non-destructive Switchless – PIC16F630 toggles JP1/JP2 for 50/60 Hz & J/U/E.
  • S-Video + Stereo Jack – tap Y/C from CXD2510Q and RF5C164 out.
Technical Documentation
  • Sega CD 2 / Mega CD 2 - Service Manual – full schematics & test points.
  • Yasushi Yamaguchi, “Sega CD ASIC Architecture” – Nikkei 1994 conference slides.
  • US Patent 5 471 206 – “Home-use CDROM system with rotation & scale processing”.
Trivia & Pop-Culture
  • Sega’s marketing touted Model 2 as “2 ½ times faster” to load due to firmware tweaks, though the drive itself is identical 1 × speed.
  • Film prop in Hackers (1995) – Acid Burn’s bedroom shows a Mega-CD 2 + Genesis 2 stack.
  • The JP manual warns: “Do not place cup noodles on top lid while operating.”
