Module:Protection banner
| This Lua module is used on many pages and changes may be widely noticed. Test changes in the module's /sandbox or /testcases subpages, or in your own module sandbox. Consider discussing changes on the talk page before implementing them. |
| This module is rated as ready for general use. It has reached a mature form and is thought to be relatively bug-free and ready for use wherever appropriate. It is ready to mention on help pages and other Wikipedia resources as an option for new users to learn. To reduce server load and bad output, it should be improved by sandbox testing rather than repeated trial-and-error editing. |
| This module is subject to page protection. It is a highly visible module in use by a very large number of pages, or is substituted very frequently. Because vandalism or mistakes would affect many pages, and even trivial editing might cause substantial load on the servers, it is protected from editing. |
| This module depends on the following other modules: |
This module creates protection banners and padlock icons that are placed at the top of protected pages.
Usage
Most users will not need to use this module directly. For adding protection templates to pages you can use the {{pp}} template, or you may find it more convenient to use one of the more specific protection templates in the table below.
From wikitext
{{#invoke:Protection banner|main
| 1 = reason
| small = yes/no
| action = action
| date = protection date
| user = username
| section = talk page section name
| category = yes
The #invoke syntax can be used for creating protection templates more specific than {{pp}}. For example, it is possible to create a protection template which always shows a padlock icon by using the code {{#invoke:Protection banner|main|small=yes}}. Pages which call this template will still be able to use other arguments, like action. However, this only works one level deep; a page calling a template which calls another template containing the above code will not automatically be able to use parameters like action.
Note: You should no longer specify the expiry, as it is automatically retrieved in all cases.
From Lua
First, load the module.
local mProtectionBanner = require('Module:Protection banner')Then you can make protection banners by using the _main function.
mProtectionBanner._main(args, cfg, titleObj)args is a table of arguments to pass to the module. For possible keys and values for this table, see the parameters section. The cfg and titleObj variables are intended only for testing; cfg specifies a customised config table to use instead of Module:Protection banner/config, and titleObj specifies a mw.title object to use instead of the current title. args, cfg and titleObj are all optional.
Parameters
All parameters are optional.
- 1 – the reason that the page was protected. If set, this must be one of the values listed in the reasons table.
- small – if set to "yes", "y", "1", or "true", a padlock icon is generated instead of a full protection banner.
- action – the protection action. Must be one of "edit" (for normal protection), "move" (for move-protection) or "autoreview" (for pending changes). The default value is "edit".
- date – the protection date. This must be valid input to the second parameter of the #time parser function. This argument has an effect for reasons that use the PROTECTIONDATE parameter in their configuration. As of July 2014, those were the "office" and "reset" reasons.
- user – the username of the user to generate links for. As of July 2014, this only has an effect when the "usertalk" reason is specified.
- section – the section name of the protected page's talk page where discussion is taking place. This works for most, but not all, values of reason.
- category – categories are suppressed if this is set to "no", "n", "0", or "false".
- catonly – if set to "yes", "y", "1", or "true", will only return the protection categories, and not return the banner or padlock. This has no visible output.
Reasons
The following table contains the available reasons, plus the actions for which they are available.
| Reason | Action | Description |
| blp | edit | For pages protected to promote compliance with the biographies of living persons policy |
| dispute | edit | For pages protected due to editing disputes |
| dmca | edit | For pages protected by the RTC due to Digital Millennium Copyright Act takedown requests |
| ecp | edit | For articles in topic areas authorized by ArbCom or meets the criteria for community use |
| mainpage | edit | For pages protected for being displayed on the Main Page |
| office | edit | For pages protected by the Wikimedia Foundation |
| reset | edit | For pages protected by the Wikimedia Foundation and "reset" to a bare-bones version |
| sock | edit | For pages protected due to sock puppetry |
| template | edit | For high-risk templates and Lua modules |
| usertalk | edit | For pages protected against disruptive edits by a particular user |
| vandalism | edit | For pages protected against vandalism |
| dispute | move | For pages protected against page moves due to disputes over the page title |
| vandalism | move | For pages protected against page-move vandalism |
Errors
Below is a list of some of the common errors that this module can produce, and how to fix them.
Invalid protection date
Error: invalid protection date ("abc")
This error is produced if you supply a |date= parameter value that is not recognised as a valid date by the #time parser function. If in doubt, you can just use a date in the format "dd Month YYYY", e.g. "9 October 2026". To see a full range of valid inputs, see the #time documentation (only the first parameter, the format string, may be specified).
Invalid action
Error: invalid action ("abc")
This error is produced if you specify an invalid protection action. There are only three valid actions: edit (the default, for normal protection), move (for move-protection), and autoreview (for pending changes). This should only be possible if you are using a template that supports manually specifying the protection action, such as {{pp}}, or if you are using #invoke directly. If this is not the case, please leave a message on Module talk:Protection banner.
Reasons cannot contain the pipe character
Error: reasons cannot contain the pipe character ("|")
This error is produced if you specify a reason using the |1= parameter that includes a pipe character ("|"). Please check that you are not entering the {{!}} template into this parameter by mistake. The pipe character is disallowed as the module uses it internally. A list of valid reasons can be seen in the reasons section.
Other errors
If you see an error other than the ones above, it is likely to either be a bug in the module or mistake in the configuration. Please post a message about it at Module talk:Protection banner.
Technical details
This module uses configuration data from Module:Protection banner/config. Most of the module's behaviour can be configured there, making it easily portable across different wikis and different languages.
General test cases for the module can be found at Module:Protection banner/testcases, and test cases specific to enwiki's config can be found at Module:Protection banner/config/testcases.
Bug reports and feature requests should be made on the module's talk page.
-- This module implements {{pp-meta}} and its daughter templates such as
-- {{pp-dispute}}, {{pp-vandalism}} and {{pp-sock}}.
-- Initialise necessary modules.
require('strict')
local makeFileLink = require('Module:File link')._main
local effectiveProtectionLevel = require('Module:Effective protection level')._main
local effectiveProtectionExpiry = require('Module:Effective protection expiry')._main
-- Lazily initialise modules and objects we don't always need.
local getArgs, makeMessageBox, lang
-- Set constants.
local CONFIG_MODULE = 'Module:Protection banner/config'
-- Helper functions
local function makeCategoryLink(cat, sort)
if cat then
return string.format(
'[[%s:%s|%s]]',
mw.site.namespaces[14].name,
cat,
sort
end
end
-- Validation function for the expiry and the protection date
local function validateDate(dateString, dateType)
if not lang then
lang = mw.language.getContentLanguage()
end
local success, result = pcall(lang.formatDate, lang, 'U', dateString)
if success then
result = tonumber(result)
if result then
return result
end
end
error(string.format(
'invalid %s: %s',
dateType,
tostring(dateString)
), 4)
end
local function makeFullUrl(page, query, display)
'[%s %s]',
tostring(mw.uri.fullUrl(page, query)),
display
end
-- Given a directed graph formatted as node -> table of direct successors,
-- get a table of all nodes reachable from a given node (though always
-- including the given node).
local function getReachableNodes(graph, start)
local toWalk, retval = {[start] = true}, {}
while true do
-- Can't use pairs() since we're adding and removing things as we're iterating
local k = next(toWalk) -- This always gets the "first" key
if k == nil then
return retval
end
toWalk[k] = nil
retval[k] = true
for _,v in ipairs(graph[k]) do
if not retval[v] then
toWalk[v] = true
end
end
end
end
-- Protection class
local Protection = {}
Protection.__index = Protection
Protection.supportedActions = {
edit = true,
move = true,
autoreview = true,
upload = true
Protection.bannerConfigFields = {
'text',
'explanation',
'tooltip',
'alt',
'link',
'image'
function Protection.new(args, cfg, title)
local obj = {}
obj._cfg = cfg
obj.title = title or mw.title.getCurrentTitle()
-- Set action
if not args.action then
obj.action = 'edit'
elseif Protection.supportedActions[args.action] then
obj.action = args.action
else
'invalid action: %s',
tostring(args.action)
), 3)
end
-- Set level
obj.level = args.demolevel or effectiveProtectionLevel(obj.action, obj.title)
if not obj.level or (obj.action == 'move' and obj.level == 'autoconfirmed') then
-- Users need to be autoconfirmed to move pages anyway, so treat
-- semi-move-protected pages as unprotected.
obj.level = '*'
end
-- Set expiry
local effectiveExpiry = effectiveProtectionExpiry(obj.action, obj.title)
if effectiveExpiry == 'infinity' then
obj.expiry = 'indef'
elseif effectiveExpiry ~= 'unknown' then
obj.expiry = validateDate(effectiveExpiry, 'expiry date')
end
-- Set reason
if args[1] then
obj.reason = mw.ustring.lower(args[1])
if obj.reason:find('|') then
error('reasons cannot contain the pipe character ("|")', 3)
end
end
-- Set protection date
if args.date then
obj.protectionDate = validateDate(args.date, 'protection date')
end
-- Set banner config
do
obj.bannerConfig = {}
local configTables = {}
if cfg.banners[obj.action] then
configTables[#configTables + 1] = cfg.banners[obj.action][obj.reason]
end
if cfg.defaultBanners[obj.action] then
configTables[#configTables + 1] = cfg.defaultBanners[obj.action][obj.level]
configTables[#configTables + 1] = cfg.defaultBanners[obj.action].default
end
configTables[#configTables + 1] = cfg.masterBanner
for i, field in ipairs(Protection.bannerConfigFields) do
for j, t in ipairs(configTables) do
if t[field] then
obj.bannerConfig[field] = t[field]
break
end
end
end
end
return setmetatable(obj, Protection)
end
function Protection:isUserScript()
-- Whether the page is a user JavaScript or CSS page.
local title = self.title
return title.namespace == 2 and (
title.contentModel == 'javascript' or title.contentModel == 'css'
end
function Protection:isProtected()
return self.level ~= '*'
end
function Protection:shouldShowLock()
-- Whether we should output a banner/padlock
return self:isProtected() and not self:isUserScript()
end
-- Whether this page needs a protection category.
Protection.shouldHaveProtectionCategory = Protection.shouldShowLock
function Protection:isTemporary()
return type(self.expiry) == 'number'
end
function Protection:makeProtectionCategory()
if not self:shouldHaveProtectionCategory() then
return ''
end
local cfg = self._cfg
-- Get the expiry key fragment.
local expiryFragment
if self.expiry == 'indef' then
expiryFragment = self.expiry
elseif type(self.expiry) == 'number' then
expiryFragment = 'temp'
end
-- Get the namespace key fragment.
local namespaceFragment = cfg.categoryNamespaceKeys[title.namespace]
if not namespaceFragment and title.namespace % 2 == 1 then
namespaceFragment = 'talk'
end
-- Define the order that key fragments are tested in. This is done with an
-- array of tables containing the value to be tested, along with its
-- position in the cfg.protectionCategories table.
local order = {
{val = expiryFragment, keypos = 1},
{val = namespaceFragment, keypos = 2},
{val = self.reason, keypos = 3},
{val = self.level, keypos = 4},
{val = self.action, keypos = 5}
-- The old protection templates used an ad-hoc protection category system,
-- with some templates prioritising namespaces in their categories, and
-- others prioritising the protection reason. To emulate this in this module
-- we use the config table cfg.reasonsWithNamespacePriority to set the
-- reasons for which namespaces have priority over protection reason.
-- If we are dealing with one of those reasons, move the namespace table to
-- the end of the order table, i.e. give it highest priority. If not, the
-- reason should have highest priority, so move that to the end of the table
-- instead.
table.insert(order, table.remove(order, self.reason and cfg.reasonsWithNamespacePriority[self.reason] and 2 or 3))
-- Define the attempt order. Inactive subtables (subtables with nil "value"
-- fields) are moved to the end, where they will later be given the key
-- "all". This is to cut down on the number of table lookups in
-- cfg.protectionCategories, which grows exponentially with the number of
-- non-nil keys. We keep track of the number of active subtables with the
-- noActive parameter.
local noActive, attemptOrder
do
local active, inactive = {}, {}
for i, t in ipairs(order) do
if t.val then
active[#active + 1] = t
else
inactive[#inactive + 1] = t
end
end
noActive = #active
attemptOrder = active
for i, t in ipairs(inactive) do
attemptOrder[#attemptOrder + 1] = t
end
end
-- Check increasingly generic key combinations until we find a match. If a
-- specific category exists for the combination of key fragments we are
-- given, that match will be found first. If not, we keep trying different
-- key fragment combinations until we match using the key
-- "all-all-all-all-all".
-- To generate the keys, we index the key subtables using a binary matrix
-- with indexes i and j. j is only calculated up to the number of active
-- subtables. For example, if there were three active subtables, the matrix
-- would look like this, with 0 corresponding to the key fragment "all", and
-- 1 corresponding to other key fragments.
-- j 1 2 3
-- i
-- 1 1 1 1
-- 2 0 1 1
-- 3 1 0 1
-- 4 0 0 1
-- 5 1 1 0
-- 6 0 1 0
-- 7 1 0 0
-- 8 0 0 0
-- Values of j higher than the number of active subtables are set
-- to the string "all".
-- A key for cfg.protectionCategories is constructed for each value of i.
-- The position of the value in the key is determined by the keypos field in
-- each subtable.
local cats = cfg.protectionCategories
for i = 1, 2^noActive do
local key = {}
for j, t in ipairs(attemptOrder) do
if j > noActive then
key[t.keypos] = 'all'
else
local quotient = i / 2 ^ (j - 1)
quotient = math.ceil(quotient)
if quotient % 2 == 1 then
key[t.keypos] = t.val
else
end
end
end
key = table.concat(key, '|')
local attempt = cats[key]
if attempt then
return makeCategoryLink(attempt, title.text)
end
end
return ''
end
function Protection:isIncorrect()
local expiry = self.expiry
return not self:shouldHaveProtectionCategory()
or type(expiry) == 'number' and expiry < os.time()
end
function Protection:isTemplateProtectedNonTemplate()
local action, namespace = self.action, self.title.namespace
return self.level == 'templateeditor'
and (
(action ~= 'edit' and action ~= 'move')
or (namespace ~= 10 and namespace ~= 828)
end
function Protection:makeCategoryLinks()
local msg = self._cfg.msg
local ret = {self:makeProtectionCategory()}
if self:isIncorrect() then
ret[#ret + 1] = makeCategoryLink(
msg['tracking-category-incorrect'],
self.title.text
end
if self:isTemplateProtectedNonTemplate() then
msg['tracking-category-template'],
self.title.text
end
return table.concat(ret)
end
-- Blurb class
local Blurb = {}
Blurb.__index = Blurb
Blurb.bannerTextFields = {
text = true,
explanation = true,
tooltip = true,
alt = true,
link = true
function Blurb.new(protectionObj, args, cfg)
return setmetatable({
_cfg = cfg,
_protectionObj = protectionObj,
_args = args
}, Blurb)
end
-- Private methods --
function Blurb:_formatDate(num)
-- Formats a Unix timestamp into dd Month, YYYY format.
lang = lang or mw.language.getContentLanguage()
local success, date = pcall(
lang.formatDate,
lang,
self._cfg.msg['expiry-date-format'] or 'j F Y',
'@' .. tostring(num)
if success then
return date
end
end
function Blurb:_getExpandedMessage(msgKey)
return self:_substituteParameters(self._cfg.msg[msgKey])
end
function Blurb:_substituteParameters(msg)
if not self._params then
local parameterFuncs = {}
parameterFuncs.CURRENTVERSION = self._makeCurrentVersionParameter
parameterFuncs.EDITREQUEST = self._makeEditRequestParameter
parameterFuncs.EXPIRY = self._makeExpiryParameter
parameterFuncs.EXPLANATIONBLURB = self._makeExplanationBlurbParameter
parameterFuncs.IMAGELINK = self._makeImageLinkParameter
parameterFuncs.INTROBLURB = self._makeIntroBlurbParameter
parameterFuncs.INTROFRAGMENT = self._makeIntroFragmentParameter
parameterFuncs.PAGETYPE = self._makePagetypeParameter
parameterFuncs.PROTECTIONBLURB = self._makeProtectionBlurbParameter
parameterFuncs.PROTECTIONDATE = self._makeProtectionDateParameter
parameterFuncs.PROTECTIONLEVEL = self._makeProtectionLevelParameter
parameterFuncs.PROTECTIONLOG = self._makeProtectionLogParameter
parameterFuncs.TALKPAGE = self._makeTalkPageParameter
parameterFuncs.TOOLTIPBLURB = self._makeTooltipBlurbParameter
parameterFuncs.TOOLTIPFRAGMENT = self._makeTooltipFragmentParameter
parameterFuncs.VANDAL = self._makeVandalTemplateParameter
self._params = setmetatable({}, {
__index = function (t, k)
local param
if parameterFuncs[k] then
param = parameterFuncs[k](self)
end
param = param or ''
t[k] = param
return param
end
end
msg = msg:gsub('${(%u+)}', self._params)
return msg
end
function Blurb:_makeCurrentVersionParameter()
-- A link to the page history or the move log, depending on the kind of
-- protection.
local pagename = self._protectionObj.title.prefixedText
if self._protectionObj.action == 'move' then
-- We need the move log link.
return makeFullUrl(
'Special:Log',
{type = 'move', page = pagename},
self:_getExpandedMessage('current-version-move-display')
else
-- We need the history link.
return makeFullUrl(
pagename,
{action = 'history'},
self:_getExpandedMessage('current-version-edit-display')
end
end
function Blurb:_makeEditRequestParameter()
local mEditRequest = require('Module:Submit an edit request')
local action = self._protectionObj.action
local level = self._protectionObj.level
-- Get the edit request type.
local requestType
if action == 'edit' then
if level == 'autoconfirmed' then
requestType = 'semi'
elseif level == 'extendedconfirmed' then
requestType = 'extended'
elseif level == 'templateeditor' then
requestType = 'template'
end
end
requestType = requestType or 'full'
-- Get the display value.
local display = self:_getExpandedMessage('edit-request-display')
return mEditRequest._link{type = requestType, display = display}
end
function Blurb:_makeExpiryParameter()
local expiry = self._protectionObj.expiry
if type(expiry) == 'number' then
return self:_formatDate(expiry)
else
return expiry
end
end
function Blurb:_makeExplanationBlurbParameter()
-- Cover special cases first.
if self._protectionObj.title.namespace == 8 then
-- MediaWiki namespace
return self:_getExpandedMessage('explanation-blurb-nounprotect')
end
-- Get explanation blurb table keys
local talkKey = self._protectionObj.title.isTalkPage and 'talk' or 'subject'
-- Find the message in the explanation blurb table and substitute any
-- parameters.
local explanations = self._cfg.explanationBlurbs
local msg
if explanations[action][level] and explanations[action][level][talkKey] then
msg = explanations[action][level][talkKey]
elseif explanations[action][level] and explanations[action][level].default then
msg = explanations[action][level].default
elseif explanations[action].default and explanations[action].default[talkKey] then
msg = explanations[action].default[talkKey]
elseif explanations[action].default and explanations[action].default.default then
msg = explanations[action].default.default
else
'could not find explanation blurb for action "%s", level "%s" and talk key "%s"',
action,
level,
talkKey
), 8)
end
return self:_substituteParameters(msg)
end
function Blurb:_makeImageLinkParameter()
local imageLinks = self._cfg.imageLinks
local msg
if imageLinks[action][level] then
msg = imageLinks[action][level]
elseif imageLinks[action].default then
msg = imageLinks[action].default
else
msg = imageLinks.edit.default
end
end
function Blurb:_makeIntroBlurbParameter()
if self._protectionObj:isTemporary() then
return self:_getExpandedMessage('intro-blurb-expiry')
else
return self:_getExpandedMessage('intro-blurb-noexpiry')
end
end
function Blurb:_makeIntroFragmentParameter()
return self:_getExpandedMessage('intro-fragment-expiry')
else
return self:_getExpandedMessage('intro-fragment-noexpiry')
end
end
function Blurb:_makePagetypeParameter()
local pagetypes = self._cfg.pagetypes
return pagetypes[self._protectionObj.title.namespace]
or pagetypes.default
or error('no default pagetype defined', 8)
end
function Blurb:_makeProtectionBlurbParameter()
local protectionBlurbs = self._cfg.protectionBlurbs
local msg
if protectionBlurbs[action][level] then
msg = protectionBlurbs[action][level]
elseif protectionBlurbs[action].default then
msg = protectionBlurbs[action].default
elseif protectionBlurbs.edit.default then
msg = protectionBlurbs.edit.default
else
error('no protection blurb defined for protectionBlurbs.edit.default', 8)
end
end
function Blurb:_makeProtectionDateParameter()
local protectionDate = self._protectionObj.protectionDate
if type(protectionDate) == 'number' then
return self:_formatDate(protectionDate)
else
return protectionDate
end
end
function Blurb:_makeProtectionLevelParameter()
local protectionLevels = self._cfg.protectionLevels
local msg
if protectionLevels[action][level] then
msg = protectionLevels[action][level]
elseif protectionLevels[action].default then
msg = protectionLevels[action].default
elseif protectionLevels.edit.default then
msg = protectionLevels.edit.default
else
error('no protection level defined for protectionLevels.edit.default', 8)
end
end
function Blurb:_makeProtectionLogParameter()
if self._protectionObj.action == 'autoreview' then
-- We need the pending changes log.
return makeFullUrl(
'Special:Log',
{type = 'stable', page = pagename},
self:_getExpandedMessage('pc-log-display')
else
-- We need the protection log.
return makeFullUrl(
'Special:Log',
{type = 'protect', page = pagename},
self:_getExpandedMessage('protection-log-display')
end
end
function Blurb:_makeTalkPageParameter()
'[[%s:%s#%s|%s]]',
mw.site.namespaces[self._protectionObj.title.namespace].talk.name,
self._protectionObj.title.text,
self._args.section or 'top',
self:_getExpandedMessage('talk-page-link-display')
end
function Blurb:_makeTooltipBlurbParameter()
return self:_getExpandedMessage('tooltip-blurb-expiry')
else
return self:_getExpandedMessage('tooltip-blurb-noexpiry')
end
end
function Blurb:_makeTooltipFragmentParameter()
return self:_getExpandedMessage('tooltip-fragment-expiry')
else
return self:_getExpandedMessage('tooltip-fragment-noexpiry')
end
end
function Blurb:_makeVandalTemplateParameter()
return mw.getCurrentFrame():expandTemplate{
title="vandal-m",
args={self._args.user or self._protectionObj.title.baseText}
end
-- Public methods --
function Blurb:makeBannerText(key)
-- Validate input.
if not key or not Blurb.bannerTextFields[key] then
'"%s" is not a valid banner config field',
tostring(key)
), 2)
end
-- Generate the text.
local msg = self._protectionObj.bannerConfig[key]
if type(msg) == 'string' then
elseif type(msg) == 'function' then
msg = msg(self._protectionObj, self._args)
if type(msg) ~= 'string' then
'bad output from banner config function with key "%s"'
.. ' (expected string, got %s)',
tostring(key),
type(msg)
), 4)
end
end
end
-- BannerTemplate class
local BannerTemplate = {}
BannerTemplate.__index = BannerTemplate
function BannerTemplate.new(protectionObj, cfg)
local obj = {}
obj._cfg = cfg
-- Set the image filename.
local imageFilename = protectionObj.bannerConfig.image
if imageFilename then
obj._imageFilename = imageFilename
else
-- If an image filename isn't specified explicitly in the banner config,
-- generate it from the protection status and the namespace.
local action = protectionObj.action
local level = protectionObj.level
local namespace = protectionObj.title.namespace
local reason = protectionObj.reason
-- Deal with special cases first.
if (
namespace == 10
or namespace == 828
or reason and obj._cfg.indefImageReasons[reason]
and action == 'edit'
and level == 'sysop'
and not protectionObj:isTemporary()
then
-- Fully protected modules and templates get the special red "indef"
-- padlock.
obj._imageFilename = obj._cfg.msg['image-filename-indef']
else
-- Deal with regular protection types.
local images = obj._cfg.images
if images[action] then
if images[action][level] then
obj._imageFilename = images[action][level]
elseif images[action].default then
obj._imageFilename = images[action].default
end
end
end
end
return setmetatable(obj, BannerTemplate)
end
function BannerTemplate:renderImage()
local filename = self._imageFilename
or self._cfg.msg['image-filename-default']
or 'Transparent.gif'
return makeFileLink{
file = filename,
size = (self.imageWidth or 20) .. 'px',
alt = self._imageAlt,
link = self._imageLink,
caption = self.imageCaption
end
-- Banner class
local Banner = setmetatable({}, BannerTemplate)
Banner.__index = Banner
function Banner.new(protectionObj, blurbObj, cfg)
local obj = BannerTemplate.new(protectionObj, cfg) -- This doesn't need the blurb.
obj.imageWidth = 40
obj.imageCaption = blurbObj:makeBannerText('alt') -- Large banners use the alt text for the tooltip.
obj._reasonText = blurbObj:makeBannerText('text')
obj._explanationText = blurbObj:makeBannerText('explanation')
obj._page = protectionObj.title.prefixedText -- Only makes a difference in testing.
return setmetatable(obj, Banner)
end
function Banner:__tostring()
-- Renders the banner.
makeMessageBox = makeMessageBox or require('Module:Message box').main
local reasonText = self._reasonText or error('no reason text set', 2)
local explanationText = self._explanationText
local mbargs = {
page = self._page,
type = 'protection',
image = self:renderImage(),
text = string.format(
"'''%s'''%s",
reasonText,
explanationText and '<br />' .. explanationText or ''
return makeMessageBox('mbox', mbargs)
end
-- Padlock class
local Padlock = setmetatable({}, BannerTemplate)
Padlock.__index = Padlock
function Padlock.new(protectionObj, blurbObj, cfg)
obj.imageWidth = 20
obj.imageCaption = blurbObj:makeBannerText('tooltip')
obj._imageAlt = blurbObj:makeBannerText('alt')
obj._imageLink = blurbObj:makeBannerText('link')
obj._indicatorName = cfg.padlockIndicatorNames[protectionObj.action]
or cfg.padlockIndicatorNames.default
or 'pp-default'
return setmetatable(obj, Padlock)
end
function Padlock:__tostring()
-- The nowiki tag helps prevent whitespace at the top of articles.
return frame:extensionTag{name = 'nowiki'} .. frame:extensionTag{
name = 'indicator',
args = {name = self._indicatorName},
content = self:renderImage()
end
-- Exports
local p = {}
function p._exportClasses()
-- This is used for testing purposes.
return {
Protection = Protection,
Blurb = Blurb,
BannerTemplate = BannerTemplate,
Banner = Banner,
Padlock = Padlock,
end
function p._main(args, cfg, title)
args = args or {}
cfg = cfg or require(CONFIG_MODULE)
local protectionObj = Protection.new(args, cfg, title)
local ret = {}
-- If a page's edit protection is equally or more restrictive than its
-- protection from some other action, then don't bother displaying anything
-- for the other action (except categories).
if not yesno(args.catonly) and (protectionObj.action == 'edit' or
args.demolevel or
not getReachableNodes(
cfg.hierarchy,
protectionObj.level
)[effectiveProtectionLevel('edit', protectionObj.title)])
then
-- Initialise the blurb object
local blurbObj = Blurb.new(protectionObj, args, cfg)
-- Render the banner
if protectionObj:shouldShowLock() then
ret[#ret + 1] = tostring(
(yesno(args.small) and Padlock or Banner)
end
end
-- Render the categories
if yesno(args.category) ~= false then
ret[#ret + 1] = protectionObj:makeCategoryLinks()
end
-- For arbitration enforcement, flagging [[WP:PIA]] pages to enable [[Special:AbuseFilter/1339]] to flag edits to them
if protectionObj.level == "extendedconfirmed" then
if require("Module:TableTools").inArray(protectionObj.title.talkPageTitle.categories, "Wikipedia pages subject to the extended confirmed restriction related to the Arab-Israeli conflict") then
ret[#ret + 1] = "<p class='PIA-flag' style='display:none; visibility:hidden;' title='This page is subject to the extended confirmed restriction related to the Arab-Israeli conflict.'></p>"
end
end
end
function p.main(frame, cfg)
-- Find default args, if any.
local parent = frame.getParent and frame:getParent()
local defaultArgs = parent and cfg.wrappers[parent:getTitle():gsub('/sandbox$', '')]
-- Find user args, and use the parent frame if we are being called from a
-- wrapper template.
getArgs = getArgs or require('Module:Arguments').getArgs
local userArgs = getArgs(frame, {
parentOnly = defaultArgs,
frameOnly = not defaultArgs
-- Build the args table. User-specified args overwrite default args.
local args = {}
for k, v in pairs(defaultArgs or {}) do
args[k] = v
end
for k, v in pairs(userArgs) do
args[k] = v
end
return p._main(args, cfg)
end
return p
