BBC Micro Model A/B Troubleshooting Guide
This guide details systematic troubleshooting for the BBC Micro Model A and Model B home computers. These classic 8-bit systems are robust but now decades old, so methodical diagnosis is essential for reliable restoration and repair.
Preliminary & Power-up Checks
Begin by confirming the BBC Micro receives correct voltages and basic startup conditions. Many faults stem from power or socket issues rather than failed chips.
Visual & Basic Checks
- Remove the top cover; inspect for burnt components, corrosion, or bulging capacitors.
- Check all socketed ICs are firmly seated.
- Inspect the power supply for leaking capacitors or burnt smell.
- Confirm the keyboard ribbon cable is securely connected.
Power Supply Voltages
| Test Point | Expected Voltage | Notes |
| 5V rail (IC pin 14/40, e.g. 6502 CPU) | +5 V DC (±5%) | Main logic supply |
| 12V rail (disk interface, if fitted) | +12 V DC | Only present on Model B or upgraded A |
| -5V rail (RAM, if fitted) | -5 V DC | Required for some DRAMs (early Issue 3/4 boards) |
| RESET line (IC pin 40, 6502) | Low → High | Should pulse low at power-on, then remain high |
- If any rail is missing or out of tolerance, recap or repair the PSU before further diagnosis.*
Power-up Sequence
- Switch on the unit.
- Confirm the red power LED lights.
- Listen for a single "beep" from the speaker.
- Observe the display for a white or black screen with a cursor and "BBC Computer" banner.
If any of these are missing, proceed to the next section.
Display & Chime Diagnostics
The BBC Micro provides clear visual and audio cues at startup. Use these to narrow down faults.
| Symptom | Probable Cause(s) | Diagnostic Action |
| No display, no beep | No power, PSU failure, blown fuse, shorted IC | Check PSU voltages, inspect fuses, feel for hot chips |
| No display, but beep present | Video circuit failure, ULA (IC6), bad socket | Check video output, swap ULA if possible |
| Display present, no beep | Speaker, sound IC (IC18), CPU not running code | Check speaker, test with external speaker, probe CPU activity |
| "Scrolling" or unstable display | Wrong video mode, bad crystal, ULA fault | Try MODE 7, check 16 MHz/8 MHz clock, swap ULA |
| Garbage or random characters | RAM fault, CPU fault, ROM not read | See memory/ROM section, check CPU clock/reset |
| "Language?" prompt or "No ROM at ..." | OS ROM or language ROM missing/faulty | Reseat ROMs, replace as needed |
Video Output Types
- Composite video (BNC or phono) – test with a known-good monitor.
- RGB output (6-pin DIN) – check cable and monitor compatibility.
- UHF output (RF modulator) – test with analogue TV, channel 36 (UK).
Memory & ROM Faults
RAM and ROM failures are common in ageing BBC Micros, especially with original DRAM chips.
RAM Faults
| Symptom | Likely Cause | Diagnostic Steps |
| No boot, continuous beep | Lower 16K RAM failure | Touch DRAMs for excess heat, piggy-back known-good 4116/4164, check -5V rail |
| "Bad RAM" message, random crashes | Upper 16K RAM fault (Model B) | Swap upper bank DRAMs, check for dry joints |
| Corrupt screen, random characters | Address/data bus fault, RAM chip | Logic probe address/data lines, swap suspected DRAM |
- Early Model A: only lower 16K fitted. Model B: both banks (32K total).*
ROM Faults
| Symptom | ROM Involved | Action |
| "Language?" prompt | BASIC ROM missing/faulty | Reseat or replace BASIC ROM (IC52) |
| "No ROM at ..." | Any sideways ROM | Reseat or replace named ROM |
| No boot, black screen | OS ROM (IC51) | Swap with known-good OS ROM |
- ROMs are typically 27128 or 27128-compatible EPROMs; always observe correct orientation.*
Connector & Socket Issues
Loose or oxidised sockets are a frequent cause of intermittent faults.
- Reseat all socketed ICs, especially the ULA (IC6), CPU (IC1), and ROMs (IC51/IC52).
- Clean edge connectors (user port, 1 MHz bus, Tube, etc.) with isopropyl alcohol.
- Inspect keyboard ribbon and connectors for cracks or poor contact.
- Check for broken solder joints on the power socket and video connectors.
Component-level Tests
Clock & Reset
- 6502 CPU (IC1) pin 37: should show a stable 2 MHz clock.
- ULA (IC6): generates system clocks; check for activity on pins 35 (16 MHz), 39 (8 MHz).
- RESET (CPU pin 40): should pulse low at power-on, then remain high.
Piggy-back & Substitution
- Carefully piggy-back a known-good DRAM on top of each suspect chip.
- Swap socketed chips (ULA, CPU, ROMs) one at a time with known-good parts.
Logic Probing
- Probe address/data lines for stuck-high or stuck-low signals.
- Check for activity on the NMI and IRQ lines (CPU pins 6 and 4).
Audio & I/O Failures
| Symptom | Probable Cause | Action |
| No beep or sound | Faulty speaker, sound IC (IC18), ULA | Test speaker, swap sound IC, check ULA |
| Keyboard dead | Faulty keyboard, ribbon, 6522 VIA (IC3) | Test keyboard on another BBC, check ribbon, swap VIA |
| Cassette not working | Faulty relay, op-amp (IC7), socket | Listen for relay click, check op-amp, clean sockets |
| Joystick/user port not working | 6522 VIA (IC3), bad port | Swap VIA, inspect port soldering |
Storage & Expansion Issues
Floppy Disk Problems (Model B or upgraded A)
- No drive activity: check 1770/8271 disk controller, drive power, ribbon cable.
- "Drive not ready" or "No drive": check drive select jumpers, cable orientation.
- Disk errors: clean drive heads, try known-good drive.
Cassette Interface
- "Loading" message but no progress: check cassette relay, op-amp (IC7), cable.
- No relay click: check relay driver transistor (Q2), 5V rail.
Cartridge/ROM Expansion
- "No ROM at ..." or language not found: check sideways ROM sockets, orientation, and supply voltage.
Error & Beep Code Table
The BBC Micro uses beep codes for basic error reporting at power-on.
| Beep Pattern | Meaning | Likely Cause |
| Continuous tone | RAM failure (lower 16K) | One or more DRAMs faulty |
| Single beep | Normal startup | System healthy |
| No beep | CPU, ULA, or ROM fault | Check CPU, ULA, OS ROM |
Final Notes
- Always start with power and visual checks before replacing chips.
- Fit sockets when replacing DRAMs or major ICs for future serviceability.
- Many faults are due to poor connections or aged sockets—reseating often cures intermittent issues.
- Never operate the BBC Micro with missing or incorrect voltage rails, especially -5V on early DRAM boards.
