Nintendo Famicom General Maintenance
The iconic Nintendo Family Computer (Famicom, ファミリーコンピュータ, HVC-001) is a foundational 8-bit console. Most surviving units are now 35–40 years old, and face risks from aging capacitors, brittle plastics, and unreliable power supplies.
This page compiles best-practice hardware care, preventive maintenance, and periodic checks for all Famicom board revisions (HVC-CPU-01 to HVC-CPU-07). Follow these guidelines to keep your Famicom running for decades to come.
Identify Your Board Revision
| Board Marking | Years | Notable Features |
| HVC-CPU-01 / -02 | 1983–84 | Early revisions, large discrete components, “rainbow” AV mod possible, 2A03 CPU, 2C02 PPU |
| HVC-CPU-03 / -04 | 1985–86 | Improved layout, smaller RAM chips, minor circuit refinements |
| HVC-CPU-05 / -06 | 1986–88 | Further integration, smaller PCB, revised power circuit |
| HVC-CPU-07 | 1989–93 | Final revision, compact layout, revised RF modulator, improved reliability |
Find the HVC-CPU-xx code silkscreened near the cartridge slot or edge of the PCB.
Regular Cleaning
Case & Controllers
- Wipe exterior ABS with a damp microfiber cloth & mild dish soap.
- Remove yellowing with retro-brite only if you can monitor temperature and UV exposure.
- For controller buttons, remove screws, pop off the shell, and clean rubber pads with warm soapy water.
- Lubricate D-pad pivots and button wells with a plastic-safe silicone grease if sticky.
PCB Dust & Oxidation
- Unplug AC adapter and wait 5 minutes for capacitors to discharge.
- Use compressed air or a soft brush to remove dust.
- Clean edge connectors (cartridge slot, controller ports) with 99% isopropyl alcohol and a lint-free swab.
- Inspect for green/white corrosion; gently remove with a fiberglass pen or contact cleaner.
Power Supply & Voltage
- Original Famicom PSUs are unregulated and prone to failure.
- Measure output: should be DC 10V, center negative.
- Replace with a modern, regulated 9–10V DC supply (≥850mA, center negative) for safety.
- Check the 5V rail on the mainboard (test at C15 or C17): should read 5.0–5.1V DC.
Preventive Maintenance
Capacitors
- Famicom uses through-hole electrolytic capacitors, which may dry out after 30+ years.
- Replace all electrolytics with quality, low-ESR types (e.g., Nichicon, Panasonic).
- Typical values (verify on your board):
- C15, C17: 220μF 16V (power filter)
- C9, C10: 10μF 16V (audio, video)
- C7: 47μF 16V (reset circuit)
Cartridge Slot & Connectors
- If games don’t boot, clean cartridge contacts and slot with IPA.
- Avoid abrasive tools; use a credit card wrapped in cloth for stubborn grime.
- If pins are bent, gently realign with a dental pick.
Fault Prevention
- Never use unregulated or reversed-polarity adapters—risk of instant damage.
- Avoid excessive force when inserting/removing cartridges or controllers.
- Store in a dry, cool place to prevent plastic brittleness and PCB corrosion.
Periodic Checks
- Inspect for leaking capacitors (bulging tops, brown residue).
- Check for burnt or cracked traces, especially near the power circuit.
- Test controllers for stuck buttons or unresponsive D-pad.
- Confirm video/audio output is stable; noise or rolling image may indicate capacitor or RF modulator issues.
