Atari 1040STE
Revision as of 16:48, 12 August 2025 by Josh (talk | contribs) (Updated by RetroTechWikiBot - Generated page content)
Atari 1040STE
ManufacturerUnknown
TypeComputer
CPUMotorola 68000 @ 8 MHz[1]
Memory1 MB standard, expandable to 4 MB via 30‑pin SIMMs (early units sometimes used SIPPs)[2]
Display
Sound
OS / Firmware
Overview
The Atari 1040STE (often styled 1040ST^E or simply STE) is an enhanced member of the Atari ST family introduced in 1989 as a mid‑life update to the original ST platform. “STE” denotes “ST Enhanced.” Compared with the Atari 1040ST/STFM, the 1040STE adds a larger 4096‑color palette, a built‑in BLiTTER graphics coprocessor as standard equipment, hardware fine scrolling, stereo 8‑bit PCM “DMA sound,” two enhanced joystick/joypad ports, and easier memory expansion via SIMMs—while retaining the ST line’s familiar wedge case, TOS + GEM desktop, and hallmark MIDI I/O.[3][4] The model designation “1040” indicates a base RAM configuration of approximately one mebibyte; the STE implements this as 1 MB on SIMM modules and can be upgraded to 4 MB.[5]
In Europe, the 1040STE was on sale by September 1989 following unveilings at CeBIT (March) and Atari Messe (August). U.S. retail availability followed in mid‑1990, alongside various regional bundles and price promotions.[6][7]
Technical Specifications
The 1040STE maintains broad software compatibility with earlier STs, but exposes additional hardware for STE‑aware software. The following summarizes core specifications.
System
CPU Motorola 68000 (16/32‑bit CISC), 8 MHz (socketed PLCC on STE mainboard).[8]
Chipset (selected) • BLiTTER (block image transfer) coprocessor, standard on STE (max practical write rate circa 4 MB/s).[9]
• Shifter video generator with extended 12‑bit palette (4096 colors).[10]
• GSTMCU (combined GLUE/MMU), DMA controller, WD1772 floppy controller, YM2149F PSG, LMC1992 analog audio controller.[11]
RAM 1 MB standard; 30‑pin SIMM sockets (early SIPP), expandable to 4 MB in paired modules.[12]
ROM / OS TOS 1.06 (“STE TOS”) initially, quickly superseded by TOS 1.62 (bug‑fix release); later upgrades to TOS 2.06 were possible.[13]
Mass storage Internal 3.5‑inch DS‑DD floppy drive (720 KB nominal); external second floppy via 14‑pin DIN; hard disks via ACSI (DMA) port with appropriate host adapter.[14]
Video and Audio
Video modes ST‑Low 320×200 (16 colors), ST‑Medium 640×200 (4 colors), ST‑High 640×400 (mono with SM124/SM147 monitor).[15]
Palette 12‑bit RGB (4096 total), with the usual ST limits on simultaneously displayed colors per mode; hardware fine scrolling added on STE.[16]
Genlock support External sync support provided; STE allows clock injection without internal modification to facilitate genlock setups.[17]
Sound (PSG) Yamaha YM2149F/AY‑3‑8910 compatible, 3 tone + noise channels (as on earlier STs).[18]
Sound (DMA) Two‑channel 8‑bit PCM (“DMA sound”) at approx. 6.25/12.5/25/50 kHz; stereo RCA line‑outs on rear panel; mixed with PSG and monitor audio. Samples are signed and may be mono or interleaved stereo.[19]
I/O and expansion
Rear/side I/O 13‑pin monitor (RGB/mono), stereo RCA audio out (L/R), 19‑pin ACSI/DMA (hard disks, laser printers), RS‑232C (DB‑25M), Centronics printer (DB‑25F), MIDI In/Out (5‑pin DIN), external floppy (14‑pin DIN), cartridge port, power inlet. Some regional units also provided TV output via internal modulator.[20]
Input devices Integrated keyboard; 2 standard DE‑9 mouse/joystick ports retained; 2 Enhanced Joystick Ports (EJPs) using 15‑pin “Jagpad‑style” connectors, supporting multi‑button pads, paddles, light pens; electrically compatible with later Atari Jaguar controllers.[21]
Memory expansion User‑replaceable 30‑pin SIMMs (paired); typical configurations 1, 2, or 4 MB. Early boards sometimes fitted with pin‑based SIPPs.[22]
History
Atari previewed the STE hardware to the trade press at CeBIT (Hannover) in March 1989 and introduced it publicly at the August 1989 Atari Messe in Düsseldorf. Retail sales began in West Germany in September 1989, followed by other European territories through late 1989 and early 1990. In the United States the 1040STE reached retail in mid‑1990, with typical bundles advertised below US$800 including a color monitor.[23]
The aim of the STE refresh was to shore up the ST’s multimedia credentials relative to rivals like the Amiga 500, without breaking compatibility with the large installed base of ST software and peripherals. Accordingly, Atari kept resolution limits and screen formats unchanged, but expanded the palette to 4096 colors, standardized the BLiTTER, added hardware scrolling, and introduced stereo PCM audio and front‑accessible enhanced controller ports. Memory expansion moved to commodity SIMMs/SIPPs, making upgrades far simpler than on most STF/STFM boards.[24]
Initial STE units shipped with TOS 1.06 (also known as TOS 1.6), a ROM build specific to STE hardware. A widely encountered desktop bug in 1.06 led Atari to release TOS 1.62 in early 1990; many systems were updated in the field, and later runs shipped with 1.62 from the factory. Enthusiasts later upgraded many STEs to TOS 2.06, adding modest UI enhancements and better hard‑disk/HD‑floppy support.[25]
Atari produced the 520STE (512 KB base RAM in some markets) and 1040STE (1 MB) as the mainstream models; a 4160STE (4 MB) existed in small numbers primarily for developers, and dealer‑labeled “2080STE/4160STE” bundles occasionally appeared to denote fitted RAM. Production of 1040STE continued into the early 1990s alongside the Mega STe (1991) and until the line’s effective replacement by the Falcon 030 in 1992–1993.[26]
Software
Like earlier STs, the 1040STE boots Atari TOS into the GEM desktop from ROM, with typical bundled tools and a “desktop accessories” mechanism. The principal STE‑specific OS releases were TOS 1.06 and 1.62, with the latter correcting early bugs; TOS 2.06, though not an original factory standard on most 1040STEs, became a popular end‑user ROM upgrade.[27]
Because the STE preserved the ST’s resolutions and per‑mode color limits, most general‑purpose ST applications ran unmodified. STE‑aware programs, however, could exploit the BLiTTER, hardware scrolling, extended palette, and DMA sound. A few notable commercial titles were written for or significantly enhanced on STE hardware:
  • Obsession (1994) – a high‑end pinball simulation built specifically for the STe, often cited for its smooth scrolling and audio; later ported to the Amiga.[28]
  • Substation (1995) – first‑person shooter for STe (and Falcon), among the platform’s late‑era 3D showcases.[29]
  • Stardust (1994 STe release) – an STe‑targeted conversion of Bloodhouse’s Amiga blaster, distributed on the ST as an STe‑only title using the machine’s hardware features.[30]
On the productivity side, the ST line’s most enduring cultural impact was in music. Cubase (Steinberg, 1989) debuted on the ST platform and remained a studio staple; many composers and producers adopted Atari STs (and later STEs) for MIDI sequencing, taking advantage of the machine’s built‑in DIN MIDI ports and stable timing. Creator/Notator from C‑Lab/Emagic likewise originated on the ST and evolved into Logic.[31][32]
Demoscene productions and public‑domain/shareware games often led the way in exploiting STE‑only features (e.g., DMA audio at 50 kHz and extended palette tricks), and later “STE‑fix” patches for classic ST games became common community projects. Nonetheless, the number of commercial releases that required an STE remained modest compared to the broader ST catalog, reflecting the smaller installed base of STE machines relative to earlier STs.[33]
Legacy
The 1040STE occupies a distinctive place in Atari’s 16‑bit lineage. Technically, it is the most capable “classic” ST in the integrated keyboard case, with standard stereo DMA audio, BLiTTER, and the extended palette while remaining largely compatible with earlier software and peripherals. Its hardware served as a bridge toward the semi‑professional Mega STe and multimedia‑oriented Atari Falcon030, both of which retained and expanded on STE concepts (e.g., DMA audio, enhanced controllers).[34]
Within retro‑computing, the STE remains desirable for music sequencing (thanks to built‑in MIDI and stable timing), for STe‑targeted games and demos, and as a flexible base for upgrades. Common modern additions include solid‑state ACSI storage adapters, floppy emulators, and TOS ROM upgrades, as well as RAM and CPU accelerators; the SIMM‑based memory architecture makes maintenance comparatively straightforward.[35]
Design assessment and compatibility
Atari’s choice to avoid new display modes helped preserve compatibility but limited visible differentiation in many titles versus earlier STs. Where developers took advantage of the BLiTTER, fine scrolling, and DMA audio, STE software could look and sound substantially better than ST‑only versions. Conversely, some early software that accessed ST color registers directly ran poorly on unpatched TOS 1.06 machines until either program updates or the TOS 1.62 ROM became standard.[36]
Notes on connectors and controls
The STE adds two Enhanced Joystick Ports using 15‑pin high‑density connectors, mechanically and electrically compatible with later Atari Jaguar “JagPad” controllers and supporting analog paddles and lightpen devices. Adapters allow two standard DE‑9 controllers per EJP, in addition to the two traditional under‑keyboard DE‑9 ports.[37] Rear‑panel stereo RCA outputs carry the mixed DMA audio and PSG signals; audio processing (master/left/right volume, bass/treble EQ) is handled by a National LMC1992 under the GSTMCU’s Microwire control.[38] As with earlier STs, RGB/mono video is provided on a 13‑pin DIN, and hard‑disk peripherals connect via the 19‑pin ACSI/DMA port.[39]
  1. Atari 520/1040 STe Field Service Manual: “The STE uses the Motorola MC68000 …” (Section 2.4). ([manualslib.com](https://www.manualslib.com/manual/2170364/Atari-520ste.html))
  2. Atari‑Museum technical section notes SIMM/SIPP memory and 4 MB maximum; also lists model distinctions (520/1040/4160). ([atarimuseum.info](https://www.atarimuseum.info/1040ste.htm))
  3. General STE feature set and differences vs. ST summarized in the Atari ST article; see “ST^E” section. ([en.wikipedia.org](https://en.wikipedia.org/wiki/Atari_ST?utm_source=chatgpt.com))
  4. Atari 520/1040 STe Field Service Manual, chapters “Audio/Video Subsystem,” “Digitized Sound,” and “Input/Output Subsystems.” ([manualslib.com](https://www.manualslib.com/manual/2170364/Atari-520ste.html))
  5. Memory configuration and expansion via 30‑pin SIMMs/SIPPs; 4 MB limit. ([atarimuseum.info](https://www.atarimuseum.info/1040ste.htm))
  6. Release timeline and regional availability. ([atarimuseum.info](https://www.atarimuseum.info/1040ste.htm))
  7. Contemporary report on early North American pricing/availability, “Time Capsule: News — Jan.90–Mar.90.” ([atariarchives.org](https://www.atariarchives.org/cfn/12/03/0021.php?utm_source=chatgpt.com))
  8. CPU and packaging change noted in STE coverage; also see Atari‑Museum chip descriptions. ([en.wikipedia.org](https://en.wikipedia.org/wiki/Atari_ST?utm_source=chatgpt.com)) [atarimuseum.info](https://www.atarimuseum.info/1040ste.htm))
  9. BLiTTER standard on STE and quoted fill rate. ([en.wikipedia.org](https://en.wikipedia.org/wiki/Atari_ST?utm_source=chatgpt.com))
  10. STE 4096‑color palette vs. 512 on ST. ([en.wikipedia.org](https://en.wikipedia.org/wiki/Atari_ST?utm_source=chatgpt.com))
  11. Chip set list and roles. ([atarimuseum.info](https://www.atarimuseum.info/1040ste.htm))
  12. SIMM/SIPP arrangement and capacities. ([atarimuseum.info](https://www.atarimuseum.info/1040ste.htm))
  13. TOS version matrix listing 1.06 (ROM 29‑Jul‑1989) and 1.62 (1‑Jan‑1990) for 520/1040STE; 2.06 as later ST/STE upgrade. ([en.wikipedia.org](https://en.wikipedia.org/wiki/Atari_TOS?utm_source=chatgpt.com))
  14. DS‑DD 720 KB floppy and external drive; ACSI “hard disk” DMA port. ([atarimuseum.info](https://www.atarimuseum.info/1040ste.htm)) [en.wikipedia.org](https://en.wikipedia.org/wiki/Atari_ST?utm_source=chatgpt.com))
  15. Standard ST/STE resolutions and color depths. ([en.wikipedia.org](https://en.wikipedia.org/wiki/Atari_ST?utm_source=chatgpt.com))
  16. 4096‑color palette and hardware scrolling. ([en.wikipedia.org](https://en.wikipedia.org/wiki/Atari_ST?utm_source=chatgpt.com))
  17. Service manual section “Genlock and the STE.” ([manualslib.com](https://www.manualslib.com/manual/2170364/Atari-520ste.html?page=15))
  18. PSG details. ([atarimuseum.info](https://www.atarimuseum.info/1040ste.htm))
  19. Sampling rates, signed samples, mixing path, and RCA outputs described in service manual and Atari Compendium. ([manualslib.com](https://www.manualslib.com/manual/2170364/Atari-520ste.html?page=15)) [bus-error.nokturnal.pl](https://bus-error.nokturnal.pl/atari_compendium/html/chap5.htm?utm_source=chatgpt.com))
  20. Port roster; stereo RCA outputs; ACSI; monitor port; and note on television output in certain markets. ([atarimuseum.info](https://www.atarimuseum.info/1040ste.htm)) [manualslib.com](https://www.manualslib.com/manual/2170364/Atari-520ste.html?page=15))
  21. Enhanced 15‑pin joystick/joypad pinout and supported devices on STE/Falcon/Jaguar. ([allpinouts.org](https://allpinouts.org/pinouts/connectors/input_device/joystick-atari-enhanced-15-pin/?utm_source=chatgpt.com))
  22. SIMM/SIPP and upgrade options. ([atarimuseum.info](https://www.atarimuseum.info/1040ste.htm))
  23. Chronology and pricing indicators: Atari‑Museum STE page (CeBIT/Atari Messe dates; European and U.S. availability) and contemporary North American commentary on availability and “street price.” ([atarimuseum.info](https://www.atarimuseum.info/1040ste.htm)) [atariarchives.org](https://www.atariarchives.org/cfn/12/03/0021.php?utm_source=chatgpt.com))
  24. Hardware additions and palette; memory change; controller ports. ([en.wikipedia.org](https://en.wikipedia.org/wiki/Atari_ST?utm_source=chatgpt.com)) [atarimuseum.info](https://www.atarimuseum.info/1040ste.htm))
  25. TOS 1.06/1.62 details, dates, and notes on 2.06. ([en.wikipedia.org](https://en.wikipedia.org/wiki/Atari_TOS?utm_source=chatgpt.com))
  26. STE model variants and production notes. ([atarimuseum.info](https://www.atarimuseum.info/1040ste.htm))
  27. TOS version timeline for STE models. ([en.wikipedia.org](https://en.wikipedia.org/wiki/Atari_TOS?utm_source=chatgpt.com))
  28. Obsession development and reception; original release 2 December 1994 for Atari STe. ([en.wikipedia.org](https://en.wikipedia.org/wiki/Obsession_%28video_game%29?utm_source=chatgpt.com))
  29. Substation platform and release information. ([en.wikipedia.org](https://en.wikipedia.org/wiki/Substation_%28video_game%29?utm_source=chatgpt.com))
  30. Stardust STe release notes (1994/1995) and STe/Falcon targeting. ([mobygames.com](https://www.mobygames.com/game/13043/stardust/releases/?utm_source=chatgpt.com)) [atariuptodate.de](https://www.atariuptodate.de/en/7098/stardust?utm_source=chatgpt.com))
  31. Cubase history: first release on Atari ST (1989). ([en.wikipedia.org](https://en.wikipedia.org/wiki/Cubase?utm_source=chatgpt.com))
  32. Emagic lineage from C‑Lab Creator/Notator on Atari ST to Logic/Notator Logic. ([en.wikipedia.org](https://en.wikipedia.org/wiki/Emagic?utm_source=chatgpt.com))
  33. Assessment of STE‑specific commercial software volume relative to overall ST catalog. ([en.wikipedia.org](https://en.wikipedia.org/wiki/Atari_ST?utm_source=chatgpt.com))
  34. Lineage from STE to Mega STe and Falcon 030; shared concepts and enhancements. ([bus-error.nokturnal.pl](https://bus-error.nokturnal.pl/atari_compendium/html/chap1.htm?utm_source=chatgpt.com)) [en.wikipedia.org](https://en.wikipedia.org/wiki/Atari_ST?utm_source=chatgpt.com))
  35. General legacy usage patterns; upgrade culture and storage adapters are widely documented across Atari community resources; SIMM‑based memory noted in contemporary and museum documentation. ([atarimuseum.info](https://www.atarimuseum.info/1040ste.htm))
  36. Compatibility considerations: unchanged resolutions, extended palette, and TOS 1.06 bugs fixed by 1.62. ([en.wikipedia.org](https://en.wikipedia.org/wiki/Atari_ST?utm_source=chatgpt.com))
  37. Enhanced 15‑pin ports: presence on STE, Falcon, Jaguar; pinout and supported peripherals. ([allpinouts.org](https://allpinouts.org/pinouts/connectors/input_device/joystick-atari-enhanced-15-pin/?utm_source=chatgpt.com))
  38. Service manual description of audio path and LMC1992 role. ([manualslib.com](https://www.manualslib.com/manual/2170364/Atari-520ste.html?page=15))
  39. Port descriptions. ([en.wikipedia.org](https://en.wikipedia.org/wiki/Atari_ST?utm_source=chatgpt.com))
