Template:Main other/doc
Revision as of 23:03, 25 August 2025 by Josh (talk | contribs)
This is the {{main other}} meta-template.
This template helps other templates detect if they are on a main space (article) page or some "other" type of page.
Basic usage
[edit source]
This template usually takes two parameters, like this:
{{main other |result if in mainspace |result if elsewhere}}
If the template is on a main space (article) page, it will return this:
If the template is on any other page, it will return this:
result if elsewhere
A typical usage case would be to warn that a template should not be used on non-article pages:
{{main other | |This template should only be used in articles.}}
or vice versa:
{{main other |This template should not be used in articles.| }}
Note that in the first case above the "main" parameter was not used, and in the second example the "other" parameter was left empty.
Demospace
[edit source]
For testing and demonstration purposes, this template can take a parameter named demospace.
  • If it has the value main it returns the article text.
  • It if has the value other or any other value such as the name of some other namespace it returns the other pages text.
  • If the parameter is empty or undefined, the actual page type determines the result.
Like this:
{{main other |result if in mainspace |result if elsewhere |demospace=main}}
No matter on what kind of page the code above is used, it will return: result if in mainspace
You can make it so your template also understands the demospace parameter. That means you can demonstrate the different appearances of your template in the documentation for your template:
{{main other |result if in mainspace |result if elsewhere |demospace={{{demospace|}}} }}
Technical details
[edit source]
This template detects article "Talk:" pages as type other.
This template works like {{main talk other}}. For more examples and technical details, see the documentation there.
No description.
Template parameters
ParameterDescriptionTypeStatus
If mainspace1
Content if page is located in mainspace (i.e. article space)
Contentoptional
If not mainspace2
Content if page is not located in mainspace
Contentoptional
Redirects
[edit source]
