Macintosh Old World ROM
Old World ROM refers to Apple Macintosh computer systems that store the Macintosh Toolbox firmware and boot code in physical ROM chips—either socketed or soldered to the motherboard. Old World ROM, Wikipedia—link(accessed 2025-01-30)
This architecture encompasses all Motorola 68000-based Macintosh computers, NuBus-based Power Macintosh models, and first-generation PCI Power Macintosh systems including the "Beige" Power Macintosh G3. These machines utilize a unified, ROM-based boot sequence controlled entirely by Toolbox logic, in contrast to later New World ROM systems (beginning with the iMac and Blue & White Power Mac G3) which load the Toolbox from disk via Open Firmware 3.0.
Architecture Overview
ROM Organization and Contents
The Old World ROM contains several critical components that define the Macintosh computing experience: Macintosh Toolbox, Wikipedia—link(accessed 2025-01-30)
Core Components:
- Macintosh Toolbox routines: QuickDraw graphics engine, Window Manager, Menu Manager, Event Manager, Resource Manager, and other GUI managers
- Hardware initialization code: CPU configuration, memory controller setup, bus initialization
- POST diagnostics: Power-On Self-Test routines for memory, ROM checksum, and basic hardware verification
- Boot loader code: Device enumeration and System Folder location routines
- 68LC040 emulator (PowerPC models): Nanokernel providing transparent 68k compatibility
The ROM size evolved significantly across generations:
- 64 KB - Macintosh 128K/512K (1984)
- 128 KB - Macintosh Plus (1986)
- 256 KB - Macintosh SE, II series (1987)
- 512 KB - Macintosh IIci, IIfx (1989)
- 1 MB - Quadra series (1991)
- 4 MB - Power Macintosh (1994)
PowerPC Architecture and 68k Emulation
PowerPC-based Old World ROM systems implement a sophisticated dual-architecture environment: Old World ROM, HardwareBook—link(accessed 2025-01-30)
- Nanokernel initialization: The PowerPC processor begins execution in the Mac OS nanokernel stored in ROM
- 68LC040 emulation layer: The nanokernel implements a complete Motorola 68LC040 processor emulator
- Toolbox execution: The predominantly 68k-based Toolbox ROM code runs within the emulator
- Mixed-mode operation: Once Mac OS loads, both native PowerPC and emulated 68k applications execute transparently
- Performance optimization: Critical OS routines are progressively replaced with native PowerPC code via the Mixed-Mode Manager
This emulation approach allowed Apple to maintain complete backward compatibility while transitioning to the PowerPC architecture, ensuring all existing Macintosh software continued to function.
Open Firmware Implementation
PCI-based Old World ROM systems include a limited Open Firmware implementation: The Open Firmware Wiki– Martin Nobel, 2021-03-28—link(accessed 2025-01-30)
Characteristics:
- Version 1.0.5 - 2.4: Early, minimal implementations designed primarily to enumerate PCI devices
- Limited functionality: Cannot directly boot from HFS volumes or load Mac OS
- Toolbox as OF device: The Macintosh Toolbox appears as an Open Firmware device that is selected by default
- Bug-prone: Particularly on early machines (Power Macintosh 7200, 7500, 8500, 9500), requiring nvramrc patches or bootloader workarounds
- Access method: Hold ⌘ Cmd+⌥ Option+O+F at startup to enter OF prompt
The Open Firmware environment can be modified to boot alternative operating systems, but this requires either:
- Custom nvramrc scripts to load non-Mac OS bootloaders
- Specially-prepared boot floppies that trick the Toolbox into loading alternative kernels
- Bootloaders like BootX that run from within Mac OS
Detailed Boot Sequence
The Old World ROM boot process follows a deterministic sequence of hardware initialization, diagnostics, and system loading phases: Macintosh Boot Sequence—link(accessed 2025-01-30)
Phase 1: Power-On and Initial Hardware State
When power is applied or the reset button is pressed: Power-on self-test, Wikipedia—link(accessed 2025-01-30)
- Reset vector execution: The CPU begins execution at the reset vector stored in ROM (address $000000 for 68k, specific to model for PPC)
- Hardware initialization: Basic hardware registers are configured to known states
- ROM overlay: On 68k systems, ROM is temporarily mapped to low memory ($000000-$3FFFFF) to provide exception vectors
- Clock stabilization: System waits for oscillators and PLLs to stabilize (typically 10-50ms)
Phase 2: Power-On Self-Test (POST)
The POST performs comprehensive hardware validation before attempting to boot: BIOS Power-On Self-Test (POST) Codes, Oracle—link(accessed 2025-01-30)
ROM Checksum Test
The first diagnostic verifies ROM integrity: 68k Mac ROM Boot Disk—link(accessed 2025-01-30)
- Algorithm: 32-bit checksum stored in first 4 bytes of ROM
- Calculation: XOR or CRC of entire ROM contents
- Failure response: System halt with no display (dead Mac)
- Bypass: Some modified ROMs disable this check for development purposes
CPU Diagnostics
Basic CPU functionality verification:
- Instruction test: Execute sample instructions from each class (arithmetic, logical, branch)
- Register test: Write/read patterns to all general-purpose and special registers
- Exception test: Verify proper exception handling for divide-by-zero, illegal instruction
- Cache test (68030/040): Validate instruction and data cache operation
Memory Test Sequence
The ROM performs extensive RAM testing using multiple algorithms: Hardware Diagnostics and Power on Self Tests, EventHelix—link(accessed 2025-01-30)
Test Patterns:
- Walking ones/zeros: Single bit moves through each memory location to detect stuck bits
- Address line test: Verifies each address line functions independently
- Data bus test: Alternating patterns (0x5555AAAA, 0xAAAA5555) verify all data lines
- March patterns: Sequential write/read with complementary patterns
- Refresh test: Verifies DRAM refresh circuitry maintains data integrity
68k Memory Test Specifics:
- Tests performed in ascending order from $00000000
- Each bank tested independently
- Failed addresses logged for Sad Mac error codes
- Test time increases linearly with RAM size (can be several minutes for 128MB+)
PowerPC Optimizations:
- Burst mode testing for faster validation
- Parallel testing of multiple banks
- Quick test option (samples rather than exhaustive)
Video Initialization
The ROM attempts to initialize video output: Macintosh startup, Wikipedia—link(accessed 2025-01-30)
- Onboard video check: If present, initialize built-in video controller
- Slot scan: Check NuBus slots 9-E or PCI slots for video cards
- Option ROM execution: Run initialization code from video card ROM
- Frame buffer setup: Allocate and clear video memory
- Gray screen: Display uniform gray pattern to indicate video functioning
Failure at this stage results in no video output but the system may continue booting "blind."
Phase 3: Device Enumeration and Boot Device Selection
After successful POST, the ROM searches for bootable devices: Old World ROM, HardwareBook—link(accessed 2025-01-30)
Search Order:
- Default startup device: Check PRAM for user-selected boot device
- Floppy drive: Check for inserted disk with System Folder
- Internal SCSI bus: Scan IDs 0-6 in ascending order
- External SCSI bus: Scan IDs 0-6 if no internal boot device found
- NuBus/PCI expansion ROMs: Check for bootable option ROMs
Boot Device Validation: For each potential boot device, the ROM verifies:
- Valid partition map: Apple Partition Map or MFS/HFS volume header
- Blessed System Folder: Directory entry with special attributes indicating bootability
- System and Finder files: Required files present in System Folder
Phase 4: Icon Display and Feedback
Based on the boot device search results:
Happy Mac Icon: Macintosh startup - Happy Mac, Wikipedia—link(accessed 2025-01-30)
- Displayed when valid System Folder found
- Indicates successful hardware initialization
- Control transfers to System file
Sad Mac Icon:
- Displayed when hardware failure detected
- Accompanied by error code (one or two lines of hexadecimal)
- System halts requiring power cycle
- Later models play distinctive death chimes
Question Mark Disk:
- Flashing disk icon with question mark
- No bootable device found
- System continues searching for boot device
- User can insert bootable floppy or CD
Phase 5: System Loading
Once a valid boot device is found: Macintosh Boot Sequence—link(accessed 2025-01-30)
- Boot blocks execution: First 1024 bytes of boot device contain boot code
- System heap initialization: Allocate memory for system data structures
- System file loading: Load System suitcase into RAM
- ROM patches: Apply bug fixes and updates to ROM routines
- Manager initialization: Start Memory Manager, File Manager, Device Manager
- Extension loading: Load INITs and CDEVs from System Folder
- Finder launch: Start Finder application for user interface
Diagnostic Indicators and Error Conditions
POST Failure Symptoms
Different failure modes produce distinct symptoms that aid in diagnosis: Macintosh startup, Wikipedia—link(accessed 2025-01-30)
| Symptom | Likely Cause | Diagnostic Approach |
| No power LED, no fan | Power supply failure | Check fuses, test PSU voltages |
| Power on but black screen | ROM failure, CPU failure | Reseat ROM if socketed, test with known-good chips |
| Gray screen, no icons | ROM checksum failure, severe RAM failure | Check first bank of RAM, verify ROM chips |
| Simasimac pattern | Address line failure, memory controller | Test RAM chips individually, check for corrosion |
| Chimes of Death | RAM failure detected by POST | Identify failed bank by chime pattern |
| Sad Mac with code | Specific hardware failure | Decode error code for component identification |
| Question mark disk | No boot device | Check SCSI chain, verify disk has System Folder |
| Gray screen with cursor | System software corruption | Boot from known-good disk, reinstall system |
Chimes of Death
Old World ROM Power Macintosh models use distinctive error sounds: Chimes of Death, Wikipedia—link(accessed 2025-01-30)
Sound Patterns:
- Car crash sound: General hardware failure (most common)
- Breaking glass: Specific to certain PowerBook models
- Brass instruments: PowerPC upgrade card systems
- Simple beeps: Late Old World ROM models
Diagnostic Value:
- Number of tones can indicate which memory bank failed
- Timing between tones may indicate failure severity
- Absence of any sound suggests ROM or CPU failure
Memory Test Optimizations
Due to the lengthy memory test times with large RAM configurations: 68k Mac ROM Boot Disk—link(accessed 2025-01-30)
Bypass Methods:
- Command-Option-P-R: Reset PRAM and skip extended tests
- Modified ROMs: Some third-party ROMs disable memory test
- Warm boot: Restart preserves memory contents, skips full test
Alternative Operating Systems
Boot Method Limitations
The ROM-centric boot process creates challenges for alternative operating systems: Booting a Linux CD on Your Old World PowerPC Mac, 2014-05-17—link(accessed 2025-01-30)
68k and NuBus Power Macs:
- Must boot Mac OS first
- No direct boot from alternative OS
- Requires Mac OS-based boot loader
- Examples: BootX for Linux, Basilisk II for Mac OS on Mac OS
PCI Power Macs:
- Can modify Open Firmware settings
- Possible to boot directly with proper OF configuration
- Requires compatible boot loader (quik, yaboot)
- Still defaults to Toolbox boot without intervention
BootX Boot Loader
The most common solution for running Linux on Old World ROM systems:
- Mac OS application: Runs from within System 7/8/9
- Kernel loading: Loads Linux kernel and initrd into memory
- Hardware takeover: Disables Mac OS and transfers control to Linux
- System extension option: Can intercept boot process automatically
A/UX Compatibility
Apple's Unix implementation required special consideration:
- Mac OS dependency: A/UX required Mac OS ROM Toolbox
- Modified boot sequence: Special boot blocks load A/UX kernel
- Toolbox emulation: A/UX provided Mac OS compatibility layer
- Hardware requirements: Only specific 68030/040 models supported
Hardware Identification
Distinguishing Features
Key characteristics that identify Old World ROM systems: Old World ROM, Wikipedia—link(accessed 2025-01-30)
Physical Indicators:
- No built-in USB ports: The definitive identifier (except PowerBook G3 Lombard)
- ADB ports: Apple Desktop Bus for keyboard/mouse
- Serial ports: RS-232/422 for printers and modems
- SCSI ports: Either DB-25 or HDI-30 connectors
- Beige or platinum cases: Pre-translucent design era
Technical Indicators:
- Boot chime timing: Immediate on power-on (New World has delay)
- Maximum Mac OS version: Generally limited to Mac OS 9.1 or earlier
- Mac OS X support: Only Beige G3 and PowerBook G3 Wallstreet officially supported
Model Categories
68000 Family (1984-1994):
- Compact Macs: 128K through Classic II
- Modular Macs: Mac II family, Quadra series
- PowerBooks: 100 series through 500 series
- All boot directly to Toolbox
NuBus Power Macintosh (1994-1995):
- Power Macintosh 6100, 7100, 8100
- No Open Firmware present
- Direct Toolbox boot only
PCI Power Macintosh (1995-1998):
- Power Macintosh 7200, 7500, 7600, 8500, 9500, 9600
- Beige Power Macintosh G3
- PowerBook G3 Series (Wallstreet/PDQ)
- Limited Open Firmware 1.0.5-2.4
ROM Modifications and Development
ROM SIMM Modules
Many Old World ROM systems use socketed ROM modules:
- 72-pin SIMMs: Similar to RAM but containing ROM/EPROM chips
- Capacity options: 1MB, 2MB, 4MB depending on system
- Update capability: Apple could ship ROM updates as replacement modules
- Third-party modifications: Enthusiasts created custom ROMs with patches
Development and Debug Features
Apple engineering samples included special capabilities:
- ROM SIMM sockets with VPP: Voltage for programming EPROMs in-system
- Debug ROM versions: Additional diagnostic output and breakpoints
- Dual ROM sockets: Switch between production and development ROMs
- Serial console output: Diagnostic messages during boot
Common ROM Patches
The enthusiast community developed various ROM modifications:
- Memory test bypass: Significantly faster boot times
- Checksum disable: Allow further ROM modifications
- Boot device patches: Support for non-standard boot devices
- Gestalt ID changes: Enable features on lower-end models
Transition to New World ROM
Architectural Changes
The New World ROM architecture introduced fundamental changes:
- ROM in RAM: Toolbox loaded from disk into RAM
- Open Firmware 3.0: Full-featured IEEE-1275 implementation
- Reduced ROM size: Only 1MB boot ROM vs 4MB Old World
- Flexible updates: Toolbox updates via software instead of hardware
Timeline
- August 1998: iMac introduces New World ROM
- October 1998: iBook continues New World adoption
- January 1999: Blue & White Power Mac G3 brings New World to towers
- May 1999: PowerBook G3 (Bronze/Lombard) - last PowerBook transition
- 1999-2001: All new Macs use New World ROM architecture
Compatibility Bridge
The Mac OS ROM file provided compatibility:
- Contents: Toolbox code previously in physical ROM
- Loading: Open Firmware loads file into RAM at boot
- Updates: New versions distributed with Mac OS updates
Technical Specifications
ROM Addressing
Old World ROM systems map ROM at specific addresses:
68k Systems:
- Physical location: Typically $400000-$4FFFFF (varies by size)
- Boot overlay: ROM temporarily mapped to $000000 during POST
- Vector table: Exception vectors copied from ROM to RAM
PowerPC Systems:
- Physical location: $FFC00000-$FFFFFFFF (4MB window)
- Exception vectors: PowerPC vectors at $FFF00000
- 68k emulation space: Virtual 68k addresses mapped by emulator
Performance Characteristics
ROM access speeds varied by generation:
- 68000-68020: 150-250ns ROM chips, no wait states
- 68030-68040: 120-150ns ROM, possible cache hits
- PowerPC 601-604: 70-120ns ROM, instruction cache crucial
- PowerPC G3: 60-70ns ROM, large L2 cache mitigates slow ROM
- Macintosh Toolbox
- New World ROM
- Sad Mac
- Open Firmware
- Mac OS nanokernel
- Macintosh startup
- Power-On Self-Test
- Chimes of Death
