Module:Pagetype/config
Revision as of 03:14, 5 September 2025 by Josh (talk | contribs) (Created page with "-------------------------------------------------------------------------------- -- Module:Pagetype configuration data -- -- This page holds localisation and configuration data for Module:Pagetype. -- -------------------------------------------------------------------------------- local cfg = {} -- Don't edit this line. -------------------------------------------------------------------------------- -- St...")
Documentation for this module may be created at Module:Pagetype/config/doc
--                        Start configuration data                            --
-- This table holds the default page types for each namespace. Keys to this
-- table should be integers that can be used as keys to mw.site.namespaces.
cfg.pagetypes = {
	[0]    = 'article', -- Main namespace
	[2]    = 'user page',
	[4]    = 'project page',
	[6]    = 'file',
	[8]    = 'interface page', -- MediaWiki namespace
	[10]   = 'template',
	[12]   = 'help page',
	[14]   = 'category',
	[100]  = 'portal',
	[118]  = 'draft',
	[710]  = 'Timed Text page',
	[828]  = 'module',
	[2300] = 'gadget',
	[2302] = 'gadget definition',
	[3000] = 'rtc',
	[-1]   = 'special page',
	[-2]   = 'file', -- Media namespace
-- This table holds the namespaces to be looked up from cfg.pagetypes by
-- default.
cfg.defaultNamespaces = {
	[0] = true,   -- main
	[6] = true,   -- file
	[10] = true,  -- template
	[14] = true,  -- category
	[828] = true, -- module
-- This table holds the namespaces to be looked up from cfg.pagetypes if
-- cfg.defaultnsExtended is set.
cfg.extendedNamespaces = {
	[0] = true,   -- main
	[2] = true,   -- user
	[4] = true,   -- project
	[6] = true,   -- file
	[8] = true,   -- mediawiki
	[12] = true,  -- help
	[100] = true, -- portal
	[118] = true, -- draft
	[3000] = true -- template
-- This table holds custom aliases for each namespace.
cfg.customNamespaceAliases = {
	[0] = {'main'},
-- The parameter name to set which default namespace values to be looked up from
-- cfg.pagetypes.
cfg.defaultns = 'defaultns'
-- The value of cfg.defaultns to set all namespaces, including talk.
cfg.defaultnsAll = 'all'
-- The value of cfg.defaultns to set the namespaces listed in
-- cfg.extendedNamespaces
cfg.defaultnsExtended = 'extended'
-- The value of cfg.defaultns to set no default namespaces.
cfg.defaultnsNone = 'none'
-- The parameter name to use for talk pages.
cfg.talk = 'talk'
-- The default value for talk pages.
cfg.talkDefault = 'talk page'
-- The parameter name to use for disambiguation pages page.
cfg.dab = 'dab'
-- The parameter name to use for non-existent pages.
cfg.ne = 'nonexistent'
cfg.neDefault = 'page'
cfg.softRedirect = 'soft_redirect'
cfg.softRedirectDefault = 'redirect'
cfg.sia = 'sia'
cfg.siaDefault = 'article'
cfg.rfd = 'redirect'
cfg.rfdDefault = 'redirect'
-- This table holds the different possible aliases for disambiguation-class
-- pages. These should be lower-case.
cfg.dabAliases = {
	['disambiguation'] = true,
	['disambig'] = true,
	['disamb'] = true,
	['dab'] = true,
-- The default value for disambiguation pages.
cfg.dabDefault = 'page'
-- The parameter name to use for N/A-class page.
cfg.na = 'na'
-- This table holds the different possible aliases for N/A-class pages. These
-- should be lower-case.
cfg.naAliases = {
	['na'] = true,
	['n/a'] = true,
-- The default value for N/A-class pages.
cfg.naDefault = 'page'
-- The parameter name to use for redirects.
cfg.redirect = 'redirect'
-- The default value to use for redirects.
cfg.redirectDefault = 'redirect'
-- The parameter name for undefined namespaces.
cfg.other = 'other'
-- The value used if the module detects an undefined namespace.
cfg.otherDefault = 'page'
-- The usual suffix denoting a plural.
cfg.plural = 's'
-- This table holds plurals not formed by a simple suffix.
cfg.irregularPlurals = {
	["category"] = "categories"
--                        End configuration data                              --
return cfg -- Don't edit this line
