Template:AfC draft editintro
Page semi-protected
This page is "edit" protected. The "autoconfirmed" right is required to "edit" this page.<ul class='mw-logevent-loglines'> <li data-mw-logid="6038" data-mw-logaction="protect/modify" class="mw-logline-protect"> <a href="/index.php?title=Special:Log&amp;logid=6038" title="Special:Log">04:38, 5 September 2025</a> <a href="/User:Josh" class="mw-userlink" title="User:Josh"><bdi>Josh</bdi></a> <span class="mw-usertoollinks mw-changeslist-links"><span><a href="/User_talk:Josh" class="mw-usertoollinks-talk" title="User talk:Josh">talk</a></span> <span><a href="/Special:Contributions/Josh" class="mw-usertoollinks-contribs" title="Special:Contributions/Josh">contribs</a></span></span> changed protection settings for <a href="/Template:AfC_draft_editintro" title="Template:AfC draft editintro">Template:AfC draft editintro</a> [Edit=Allow only autoconfirmed users] (indefinite) [Move=Allow only autoconfirmed users] (indefinite) <span class="mw-logevent-actionlink">(<a href="/index.php?title=Template:AfC_draft_editintro&amp;action=history&amp;offset=20250905033806" title="Template:AfC draft editintro">hist</a>)</span> <span class="mw-logevent-tool"></span></li> </ul></ul> <ul class="mw-logevent-footer"><li><a href="/index.php?title=Special:Log&amp;page=Template%3AAfC_draft_editintro&amp;type=protect" title="Special:Log">View full log</a></li></ul>
This page is "move" protected. The "autoconfirmed" right is required to "move" this page.<ul class='mw-logevent-loglines'> <li data-mw-logid="6038" data-mw-logaction="protect/modify" class="mw-logline-protect"> <a href="/index.php?title=Special:Log&amp;logid=6038" title="Special:Log">04:38, 5 September 2025</a> <a href="/User:Josh" class="mw-userlink" title="User:Josh"><bdi>Josh</bdi></a> <span class="mw-usertoollinks mw-changeslist-links"><span><a href="/User_talk:Josh" class="mw-usertoollinks-talk" title="User talk:Josh">talk</a></span> <span><a href="/Special:Contributions/Josh" class="mw-usertoollinks-contribs" title="Special:Contributions/Josh">contribs</a></span></span> changed protection settings for <a href="/Template:AfC_draft_editintro" title="Template:AfC draft editintro">Template:AfC draft editintro</a> [Edit=Allow only autoconfirmed users] (indefinite) [Move=Allow only autoconfirmed users] (indefinite) <span class="mw-logevent-actionlink">(<a href="/index.php?title=Template:AfC_draft_editintro&amp;action=history&amp;offset=20250905033806" title="Template:AfC draft editintro">hist</a>)</span> <span class="mw-logevent-tool"></span></li> </ul></ul> <ul class="mw-logevent-footer"><li><a href="/index.php?title=Special:Log&amp;page=Template%3AAfC_draft_editintro&amp;type=protect" title="Special:Log">View full log</a></li></ul>
Revision as of 04:37, 5 September 2025 by Josh (talk | contribs) (Protected "Template:AfC draft editintro" ([Edit=⧼protect-level-templateeditor⧽] (indefinite) [Move=⧼protect-level-templateeditor⧽] (indefinite)))
Instructions
Creating a draft article takes three steps. Please read carefully.
  1. Enter the content of your article in the blank area as illustrated.
    • Remember to use your own words. Do not copy content from another website.
  2. If you need help with your submission, you can visit forum.retrotechcollection.com or the RTC Discord.
  3. When you are finished writing, click the "Publish page" button. You are all done! We appreciate your submission.
Important
  • Please note: Once you click the "publish" button, your draft is saved in a public drafting area. You may continue to work on your draft as long as you like; there is no deadline, but bear in mind that if the draft isn't edited in six months, it may be deleted.
  • If the draft is declined, you will still be able to edit it. It is simply marked as declined.
  • When you feel your draft is ready to become an article, you can request a review (or a re-review). To do so, edit your draft, by clicking on its "Edit" button, and add {{subst:submit}} at the beginning of your draft.
